Use ros2 foxy control turtlebot3 failed
I’m using the latest version of Isaac Sim, 23.1.1. I loaded a simple room environment and followed a tutorial to load the turtlebot3 from GitHub using the command git clone -b foxy-devel https://github.com/ROBOTIS-GIT/turtlebot3.git turtlebot3 . I downloaded the URDF files and found turtlebot3_burger.urdf in the URDF folder, so I did not use the conversion command rosrun xacro xacro -o <output_name>.urdf <input_file>.urdf.xacro . I was able to import this robot and set up the parameters according to the tutorial, and I added an Action Graph. However, when I pressed play, I received an error message on Pattern ‘/World/turtlebot3_burger’ did not match any articulations.Naturally, the robot did not move.
