We are using Deepstream on our Orin NX connect via LAN to a host computer. We are trying to send the video via RTSP, and experience packet drops. The stream is 25FPS video 1280X720 so the packet drop does not make sense. We did see in Deepstream NVIDIA Q&A a recommendation to use TCP instead. It does fix the stream but the TCP bandwidth overhead does not work for us. What can be done to get UDP transport to work without drops?
Thanks for your reply,
I’ve added :
g_object_set (G_OBJECT (bin->encoder), “vbv-size”, 2000000 , NULL);
in create_udpsink_bin method in the common of deepstream app. I think it has a small improvement bust still packets are dropped when there are changes in the image. Looking in wireshark the dropped packets are related to burst udp packets sent ( a few packets with 1 ms).
I’ve also tried reducing bitrate to 2000000 and increase buffers:
net.core.rmem_max
net.core.wmem_max
Hi, no we use a CSI camera source. I’ve updated the profile to 0 (it was 4=high) and it works much better. I see approx ~2 packet drop in a minute now. But again that’s for 2000000 bit rate. for 3000000 there are more drops so if you have any additional recommendations for improvement it would be great.
But the stream is much more stable now
EnableTwopassCBR : Enable two pass CBR while encoding
flags: readable, writable, changeable only in NULL or READY state
Boolean. Default: false
disable-cabac : Set Entropy Coding Type CAVLC(TRUE) or CABAC(FALSE)
Try poc-type=2:
poc-type : Set Picture Order Count type value
Unsigned Integer. Range: 0 - 2 Default: 0
Or try to adjust IDR/I frame interval:
idrinterval : Encoding IDR Frame occurance frequency
Unsigned Integer. Range: 0 - 4294967295 Default: 256
iframeinterval : Encoding Intra Frame occurance frequency
Unsigned Integer. Range: 0 - 4294967295 Default: 30
