Use YUY2 format as input
Hello DaneLLL,
Thank you for your help. Here is the experiment result for the pipeline test:
1). gst-launch-1.0 v4l2src device=/dev/video0 ! video/x-raw,format=YUY2,width=640,height=480,framerate=30/1 ! videoconvert ! nvvideoconvert ! ‘video/x-raw(memory:NVMM),format=NV12’ ! fakesink
The terminal showed below result:
Setting pipeline to PAUSED …
Pipeline is live and does not need PREROLL …
Setting pipeline to PLAYING …
New clock: GstSystemClock
2). gst-launch-1.0 v4l2src device=/dev/video0 ! video/x-raw, format=YUY2, width=640, height=480, framerate=30/1 ! videoconvert ! nvvideoconvert ! nveglglessink –e
test result: worked well.
3). gst-launch-1.0 v4l2src device=/dev/video0 ! video/x-raw, format=YUY2, width=640, height=480, framerate=30/1 ! videoconvert ! ‘video/x-raw, format=NV12’ ! nvvideoconvert ! nvdsosd ! nveglglessink –e
4). gst-launch-1.0 v4l2src device=/dev/video0 ! video/x-raw, format=YUY2, width=640, height=480, framerate=30/1 ! videoconvert ! ‘video/x-raw(memory:NVMM), format=NV12’ ! nvvideoconvert ! nvdsosd ! nveglglessink –e
test result: failed with the following warning.
WARNING: erroneous pipeline: could not link videoconvert0 to nvvideoconvert0, videoconvert0 can’t handle caps video/x-raw(memory:NVMM), format=(string)NV12
5). gst-launch-1.0 v4l2src device=/dev/video0 ! video/x-raw, format=YUY2, width=640, height=480, framerate=30/1 ! videoconvert ! nvvideoconvert ! ‘video/x-raw, format=NV12’ ! nvvideoconvert ! nvdsosd ! nveglglessink –e
test result: pop up the black window, no image showed up.
Thank you.
For 5). gst-launch-1.0 v4l2src device=/dev/video0 ! video/x-raw, format=YUY2, width=640, height=480, framerate=30/1 ! videoconvert ! nvvideoconvert ! ‘video/x-raw, format=NV12’ ! nvvideoconvert ! nvdsosd ! nveglglessink –e
The terminal showed the following message while popped up the black window:
Creating LL OSD context new
Got context from element ‘eglglessink0’: gst.egl.EGLDisplay=context, display=(GstEGLDisplay)NULL;
ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Internal data stream error.
Additional debug info:
gstbasesrc.c(3055): gst_base_src_loop (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
streaming stopped, reason error (-5)
EOS on shutdown enabled – waiting for EOS after Error
Waiting for EOS…
Thank you.
Hi DaneLLL,
I modified the code to run the pipeline “v4l2src device=/dev/video0 ! video/x-raw,format=YUY2,width=640,height=480,framerate=30/1 ! videoconvert ! nvvideoconvert ! ‘video/x-raw(memory:NVMM),format=NV12’ ! fakesink”.
gst_bin_add_many (GST_BIN (pipeline), source, conv1, nvconv, fsink, NULL);
It failed in the test:
(deepstream-test1-app:64164): GStreamer-WARNING **: 11:53:27.038: Trying to link elements capsfilter2 and stream-muxer that don’t share a common ancestor: stream-muxer hasn’t been added to a bin or pipeline, and capsfilter2 is in dstest1-pipeline
Running…
ERROR from element v4l2-source: Internal data stream error.
Error details: gstbasesrc.c(3055): gst_base_src_loop (): /GstPipeline:dstest1-pipeline/GstV4l2Src:v4l2-source:
streaming stopped, reason not-linked (-1)
Returned, stopping playback
Deleting pipeline
Is the program not able to convert the video from YUY2 to NV12?
Thank you.
Hi dipeshadekar,
For the error:
ERROR from element stream-muxer: memory type configured and i/p buffer mismatch ip_surf 0 muxer 3
Please add one line and try again.
g_object_set (G_OBJECT (nvconv),"nvbuf-memory-type", 3, NULL);
Hi laomao,
Not sure why you are not able to launch it. We have RocketFish USB camera that supports YUYV 640x480p30.
[63994.031169] usb 1-8: Product: Rocketfish HD Webcam Pro
[63994.031171] usb 1-8: Manufacturer: Rocketfish
[63994.031173] usb 1-8: SerialNumber: 2011071800171
By modifying width, height, and format accordingly, it works well.
You may try deepstream-app. source1_usb_dec_infer_resnet_int8.txt is for USB camera. The default resolution is 1280x720. Please modify to 640x480 and give it a try.
Hi DaneLLL,
My camera worked with deepstream-app -c source1_usb_dec_infer_resnet_int8.txt with 640X480 resolution. I just wonder why it did not work with the code in #11. Thank you for your help.
Hi DaneLLL,
I modified my code as you have suggested in #24. It is working as expected right now.
Thank you!
Hi DaneLLL,
  I tried deepstream-app -c source1_usb_dec_infer_resnet_int8.txt with 640X480,framerate=25/1,and i also changed model-engine-file=../../models/Primary_Detector/resnet10.caffemodel_b30_int8.engine to resnet10.caffemodel_b1_int8.engine.
cuGraphicsGLRegisterBuffer failed with error(304) gst_eglglessink_cuda_init texture = 1
0:00:02.009169656 889 0x55a265008190 WARN nvinfer gstnvinfer.cpp:1830:gst_nvinfer_output_loop:<primary_gie_classifier> error: Internal data stream error.
0:00:02.009236147 889 0x55a265008190 WARN nvinfer gstnvinfer.cpp:1830:gst_nvinfer_output_loop:<primary_gie_classifier> error: streaming stopped, reason not-negotiated (-4)
ERROR from primary_gie_classifier: Internal data stream error.
Debug info: gstnvinfer.cpp(1830): gst_nvinfer_output_loop (): /GstPipeline:pipeline/GstBin:primary_gie_bin/GstNvInfer:primary_gie_classifier:
Quitting
ERROR from sink_bin_queue: Internal data stream error.
Debug info: gstqueue.c(988): gst_queue_handle_sink_event (): /GstPipeline:pipeline/GstBin:processing_bin_0/GstBin:sink_bin/GstQueue:sink_bin_queue:
ERROR from src_elem: Internal data stream error.
Debug info: gstbasesrc.c(3055): gst_base_src_loop (): /GstPipeline:pipeline/GstBin:multi_src_bin/GstBin:src_sub_bin0/GstV4l2Src:src_elem:
ERROR from primary_gie_queue: Internal data stream error.
Hi @Jeff_Bond
You may refer to
And make sure your USB camera can be successfully launched in gst-launch-1.0 first.
Hi laomao,
I tried 3) gst-launch-1.0 v4l2src device=/dev/video0 ! video/x-raw, format=YUY2, width=640, height=480, framerate=25/1 ! videoconvert ! “video/x-raw, format=NV12” ! nvvideoconvert ! nvdsosd ! nveglglessink –e
didn’t work:
When I tried gst-launch-1.0 v4l2src device=/dev/video0 ! video/x-raw, format=YUY2, width=640, height=480, framerate=25/1 ! videoconvert ! “video/x-raw, format=NV12” ! nvvideoconvert ! nveglglessink –e
did work, it seems due to nvdsosd plugin
Hi DaneLLL,
Thanks for your quick reply.
I already did some test.
ioctl: VIDIOC_ENUM_FMT
Index : 0
Type : Video Capture
Pixel Format: ‘MJPG’ (compressed)
Interval: Discrete 0.040s (25.000 fps)
Size: Discrete 1920x1080
Size: Discrete 1280x1024
Index       : 1
Pixel Format: 'YUYV'
		Interval: Discrete 0.200s (5.000 fps)
		Interval: Discrete 0.167s (6.000 fps)
gst-launch-1.0 v4l2src device=/dev/video0 ! video/x-raw, format=YUY2, width=640, height=480, framerate=25/1 ! videoconvert ! nvvideoconvert ! nveglglessink –e It did work and display.
I run in the container 4.0.1 and 4.0.2 , it all worked.
But after added nvdsosd it didn’t work.
gst-launch-1.0 v4l2src device=/dev/video0 ! video/x-raw,format=YUY2, width=640, height=480, framerate=25/1 ! videoconvert ! “video/x-raw, format=NV12” ! nvvideoconvert ! nvdsosd ! nveglglessink –e
Hi DaneLLL,
I modified test1-app to use camera. If use fakesink it could run, use nveglglessink would failed. I added g_object_set(G_OBJECT(sink),“sync”,0,NULL).
Do you know how to deal with it?
If you run on Jetson platforms, you should need nvegltransform
We have a reference sample in
Dear DaneLLL,
What I want to are tracking objects, displaying the number of object and counting the number of objects with Jetson nano and Deepstream SDK.
At first, I used your #11 code to track objects and display the number of object. Because your #11 code didn’t work in my environment, Would you mind helping me?
The following is the result of running of ./deepstream-test1.app
(deepstream-test1-app:27279): GLib-GObject-WARNING **: 14:40:39.846: cannot register existing type 'GstInterpolationMethod'
(deepstream-test1-app:27279): GLib-GObject-CRITICAL **: 14:40:39.846: g_param_spec_enum: assertion 'G_TYPE_IS_ENUM (enum_type)' failed
(deepstream-test1-app:27279): GLib-GObject-CRITICAL **: 14:40:39.846: validate_pspec_to_install: assertion 'G_IS_PARAM_SPEC (pspec)' failed
Using winsys: x11
Running...
Deleting pipeline
Also, I will share the information for ‘# v4l2-ctl -d /dev/video0 --list-formats-ext’ in my system.
        Index       : 0
                        Interval: Discrete 0.033s (30.000 fps)
                        Interval: Discrete 0.042s (24.000 fps)
                        Interval: Discrete 0.050s (20.000 fps)
                        Interval: Discrete 0.067s (15.000 fps)
                        Interval: Discrete 0.100s (10.000 fps)
                        Interval: Discrete 0.133s (7.500 fps)
                Size: Discrete 2304x1296
                        Interval: Discrete 0.500s (2.000 fps)
                Size: Discrete 2304x1536
        Index       : 1
        Pixel Format: 'MJPG' (compressed)
                        Interval: Discrete 0.017s (60.000 fps)
And the following is my code based on #11 code. I change the value of MUXER_OUTPUT_WIDTH, MUXER_OUTPUT_HEIGHT, MUXER_BATCH_TIMEOUT_USEC, G_OBJECT (source) and caps_uyvy to fit my code.
 * Copyright (c) 2018-2019, NVIDIA CORPORATION. All rights reserved.
 * Permission is hereby granted, free of charge, to any person obtaining a
 * copy of this software and associated documentation files (the "Software"),
 * to deal in the Software without restriction, including without limitation
 * the rights to use, copy, modify, merge, publish, distribute, sublicense,
 * and/or sell copies of the Software, and to permit persons to whom the
 * Software is furnished to do so, subject to the following conditions:
 * The above copyright notice and this permission notice shall be included in
 * all copies or substantial portions of the Software.
 * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
 * IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
 * FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT.  IN NO EVENT SHALL
 * THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
 * LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
 * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
 * DEALINGS IN THE SOFTWARE.
#include <gst/gst.h>
#include <glib.h>
#include <stdio.h>
#include "gstnvdsmeta.h"
#define MAX_DISPLAY_LEN 64
#define PGIE_CLASS_ID_VEHICLE 0
#define PGIE_CLASS_ID_PERSON 2
/* The muxer output resolution must be set if the input streams will be of
 * different resolution. The muxer will scale all the input frames to this
 * resolution. */
#define MUXER_OUTPUT_WIDTH 640 //I changed from 1920
#define MUXER_OUTPUT_HEIGHT 480 //I changed from 1080
/* Muxer batch formation timeout, for e.g. 40 millisec. Should ideally be set
 * based on the fastest source's framerate. */
#define MUXER_BATCH_TIMEOUT_USEC 3000000 // I changed 4000000
#define NVVIDCONV
gint frame_number = 0;
gchar pgie_classes_str[4][32] = { "Vehicle", "TwoWheeler", "Person",
  "Roadsign"
/* osd_sink_pad_buffer_probe  will extract metadata received on OSD sink pad
 * and update params for drawing rectangle, object information etc. */
static GstPadProbeReturn
osd_sink_pad_buffer_probe (GstPad * pad, GstPadProbeInfo * info,
    gpointer u_data)
    GstBuffer *buf = (GstBuffer *) info->data;
    guint num_rects = 0;
    NvDsObjectMeta *obj_meta = NULL;
    guint vehicle_count = 0;
    guint person_count = 0;
    NvDsMetaList * l_frame = NULL;
    NvDsMetaList * l_obj = NULL;
    NvDsDisplayMeta *display_meta = NULL;
    NvDsBatchMeta *batch_meta = gst_buffer_get_nvds_batch_meta (buf);
    for (l_frame = batch_meta->frame_meta_list; l_frame != NULL;
      l_frame = l_frame->next) {
        NvDsFrameMeta *frame_meta = (NvDsFrameMeta *) (l_frame->data);
        int offset = 0;
        for (l_obj = frame_meta->obj_meta_list; l_obj != NULL;
                l_obj = l_obj->next) {
            obj_meta = (NvDsObjectMeta *) (l_obj->data);
            if (obj_meta->class_id == PGIE_CLASS_ID_VEHICLE) {
                vehicle_count++;
                num_rects++;
            if (obj_meta->class_id == PGIE_CLASS_ID_PERSON) {
                person_count++;
                num_rects++;
        display_meta = nvds_acquire_display_meta_from_pool(batch_meta);
        NvOSD_TextParams *txt_params  = &display_meta->text_params[0];
        display_meta->num_labels = 1;
        txt_params->display_text = g_malloc0 (MAX_DISPLAY_LEN);
        offset = snprintf(txt_params->display_text, MAX_DISPLAY_LEN, "Person = %d ", person_count);
        offset = snprintf(txt_params->display_text + offset , MAX_DISPLAY_LEN, "Vehicle = %d ", vehicle_count);
        /* Now set the offsets where the string should appear */
        txt_params->x_offset = 10;
        txt_params->y_offset = 12;
        /* Font , font-color and font-size */
        txt_params->font_params.font_name = "Serif";
        txt_params->font_params.font_size = 10;
        txt_params->font_params.font_color.red = 1.0;
        txt_params->font_params.font_color.green = 1.0;
        txt_params->font_params.font_color.blue = 1.0;
        txt_params->font_params.font_color.alpha = 1.0;
        /* Text background color */
        txt_params->set_bg_clr = 1;
        txt_params->text_bg_clr.red = 0.0;
        txt_params->text_bg_clr.green = 0.0;
        txt_params->text_bg_clr.blue = 0.0;
        txt_params->text_bg_clr.alpha = 1.0;
        nvds_add_display_meta_to_frame(frame_meta, display_meta);
    g_print ("Frame Number = %d Number of objects = %d "
            "Vehicle Count = %d Person Count = %d\n",
            frame_number, num_rects, vehicle_count, person_count);
    frame_number++;
    return GST_PAD_PROBE_OK;
static gboolean
bus_call (GstBus * bus, GstMessage * msg, gpointer data)
  GMainLoop *loop = (GMainLoop *) data;
  switch (GST_MESSAGE_TYPE (msg)) {
    case GST_MESSAGE_EOS:
      g_print ("End of stream\n");
      g_main_loop_quit (loop);
      break;
    case GST_MESSAGE_ERROR:{
      gchar *debug;
      GError *error;
      gst_message_parse_error (msg, &error, &debug);
      g_printerr ("ERROR from element %s: %s\n",
          GST_OBJECT_NAME (msg->src), error->message);
      if (debug)
        g_printerr ("Error details: %s\n", debug);
      g_free (debug);
      g_error_free (error);
      break;
    default:
      break;
  return TRUE;
int
main (int argc, char *argv[])
  GMainLoop *loop = NULL;
  GstElement *pipeline = NULL, *source = NULL,
      *streammux = NULL, *sink = NULL, *pgie = NULL, *nvvidconv = NULL,
      *nvosd = NULL;
  GstElement *conv1 = NULL, *conv2 = NULL, *nvconv = NULL;
  GstCaps *caps_uyvy = NULL, *caps_nv12_nvmm = NULL, *caps_nv12 = NULL;
  GstCapsFeatures *feature = NULL;
#ifdef PLATFORM_TEGRA
  GstElement *transform = NULL;
#endif
  GstBus *bus = NULL;
  guint bus_watch_id;
  GstPad *osd_sink_pad = NULL;
  /* Standard GStreamer initialization */
  gst_init (&argc, &argv);
  loop = g_main_loop_new (NULL, FALSE);
  /* Create gstreamer elements */
  /* Create Pipeline element that will form a connection of other elements */
  pipeline = gst_pipeline_new ("dstest1-pipeline");
  /* Source element for reading from the file */
  source = gst_element_factory_make ("v4l2src", "v4l2-source");
#ifdef NVVIDCONV
  conv1 = gst_element_factory_make ("nvvidconv", "conv1");
  conv2 = gst_element_factory_make ("nvvidconv", "conv2");
#else
  conv1 = gst_element_factory_make ("videoconvert", "conv1");
#endif
  nvconv = gst_element_factory_make ("nvvideoconvert", "nvconv");
  /* Create nvstreammux instance to form batches from one or more sources. */
  streammux = gst_element_factory_make ("nvstreammux", "stream-muxer");
  if (!pipeline || !streammux) {
    g_printerr ("One element could not be created. Exiting.\n");
    return -1;
  /* Use nvinfer to run inferencing on decoder's output,
   * behaviour of inferencing is set through config file */
  pgie = gst_element_factory_make ("nvinfer", "primary-nvinference-engine");
  /* Use convertor to convert from NV12 to RGBA as required by nvosd */
  nvvidconv = gst_element_factory_make ("nvvideoconvert", "nvvideo-converter");
  /* Create OSD to draw on the converted RGBA buffer */
  nvosd = gst_element_factory_make ("nvdsosd", "nv-onscreendisplay");
  /* Finally render the osd output */
  transform = gst_element_factory_make ("nvegltransform", "nvegl-transform");
#endif
  sink = gst_element_factory_make ("nveglglessink", "nvvideo-renderer");
  if (!source || !pgie
      || !nvvidconv || !nvosd || !sink) {
    return -1;
  if(!transform) {
    g_printerr ("One tegra element could not be created. Exiting.\n");
    return -1;
#endif
  g_object_set (G_OBJECT (streammux), "width", MUXER_OUTPUT_WIDTH, "height",
      MUXER_OUTPUT_HEIGHT, "batch-size", 1, "live-source", 1,
      "batched-push-timeout", MUXER_BATCH_TIMEOUT_USEC, NULL);
  /* Set all the necessary properties of the nvinfer element,
   * the necessary ones are : */
  g_object_set (G_OBJECT (pgie),
      "config-file-path", "dstest1_pgie_config.txt", NULL);
 // I removed ""num-buffers", 900"
  g_object_set (G_OBJECT (source), "device", "/dev/video0", NULL);
 // I changed "width" from 1920 to 640, "height" from 1080 to 480 and "format" from UYVY to YUYV
  caps_uyvy = gst_caps_new_simple ("video/x-raw", "format", G_TYPE_STRING, "YUYV",
      "width", G_TYPE_INT, 640, "height", G_TYPE_INT,
      480, "framerate", GST_TYPE_FRACTION,
      30, 1, NULL);
  caps_nv12_nvmm = gst_caps_new_simple ("video/x-raw", "format", G_TYPE_STRING, "NV12", NULL);
  feature = gst_caps_features_new ("memory:NVMM", NULL);
  gst_caps_set_features (caps_nv12_nvmm, 0, feature);
  caps_nv12 = gst_caps_new_simple ("video/x-raw", "format", G_TYPE_STRING, "NV12", NULL);
  /* we add a message handler */
  bus = gst_pipeline_get_bus (GST_PIPELINE (pipeline));
  bus_watch_id = gst_bus_add_watch (bus, bus_call, loop);
  gst_object_unref (bus);
  /* Set up the pipeline */
  /* we add all elements into the pipeline */
      source, conv1, nvconv, streammux, pgie,
      nvvidconv, nvosd, transform, sink, NULL);
  gst_element_link_filtered(source, conv1, caps_uyvy);
#ifdef NVVIDCONV
  gst_bin_add (GST_BIN (pipeline), conv2);
  gst_element_link_filtered(conv1, conv2, caps_nv12_nvmm);
  gst_element_link_filtered(conv2, nvconv, caps_nv12);
#else
  gst_element_link_filtered(conv1, nvconv, caps_nv12);
#endif
  gst_element_link_pads_filtered(nvconv, "src", streammux, "sink_0", caps_nv12_nvmm);
  gst_caps_unref(caps_uyvy);
  gst_caps_unref(caps_nv12_nvmm);
  gst_caps_unref(caps_nv12);
  if (!gst_element_link_many (streammux, pgie,
      nvvidconv, nvosd, transform, sink, NULL)) {
    g_printerr ("Elements could not be linked: 2. Exiting.\n");
    return -1;
  /* Lets add probe to get informed of the meta data generated, we add probe to
   * the sink pad of the osd element, since by that time, the buffer would have
   * had got all the metadata. */
  osd_sink_pad = gst_element_get_static_pad (nvosd, "sink");
  if (!osd_sink_pad)
    g_print ("Unable to get sink pad\n");
  else
    gst_pad_add_probe (osd_sink_pad, GST_PAD_PROBE_TYPE_BUFFER,
        osd_sink_pad_buffer_probe, NULL, NULL);
  /* Set the pipeline to "playing" state */
  gst_element_set_state (pipeline, GST_STATE_PLAYING);
  /* Wait till pipeline encounters an error or EOS */
  g_print ("Running...\n");
  g_main_loop_run (loop);
  /* Out of the main loop, clean up nicely */
  g_print ("Returned, stopping playback\n");
  gst_element_set_state (pipeline, GST_STATE_NULL);
  g_print ("Deleting pipeline\n");
  gst_object_unref (GST_OBJECT (pipeline));
  g_source_remove (bus_watch_id);
  g_main_loop_unref (loop);
  return 0;
Sincerely,
I could run #11 code in my environment.
The following are parts which I adjusted in #11 code.
  • Parameter of MUXER_BATCH_TIMEOUT_USEC to fit my device.
  • Parameter of “format”, “width”, “height” and “framerate” in “caps_uyvu” to fit my device. Although my device format is YUYV, it was good to set YUY2 instead of YUYV.
  • If you don’t use “tranform” element, you will have to add to the pipeline and link which remove “tranform” element.
