User, Display and SSH issues related to the Thor Kit
Issue Description: After power outage at the office where our Thor kit is located, the user we created after DriveOS update did not exist anymore, display output on the display-port external screen was not available and ssh service failed to start due to no hostkeys available. We had to login using the serial console interface (via USB) from a laptop using the nvidia user/password combination - that’s how we were able to see that our own user did not exist anymore. We had to recreate the ssh keys and our user + add it to the sudoers group to have things how they were before with regards to remote (ssh) access. This exact same issue happened in the past with another Thor kit after we moved it to another place (so we removed power from the kit). Do you have any knowledge of issues related to the Thor kit once power is removed? Is there anything we need to do in order to preserve the user/settings that we configured after DriveOS update? Error string was copied from journalctl from the time the Thor rebooted after power outage - we can extract any other logs that could be relevant for what has happened and could relate to the issues we have observed.**
DRIVE OS Version:**
DriveOS 7.2.5
Error String:
Oct 10 23:18:46 tegra-ubuntu systemd[1]: Starting ssh.service - OpenBSD Secure Shell server...
Oct 10 23:18:46 tegra-ubuntu sshd[3927]: sshd: no hostkeys available -- exiting.
Oct 10 23:18:46 tegra-ubuntu systemd[1]: ssh.service: Control process exited, code=exited, status=1/FAILURE
Oct 10 23:18:46 tegra-ubuntu systemd[1]: ssh.service: Failed with result 'exit-code'.
Thank you!
Best regards,
Lucian
Dear @lucpo ,
I am not aware of such issue. Was this issue reported earlier? Can the issue be reproduced by turning off the switch on the switchboard connected to the power supply?
Since we had the same issue on two units that we had to reconfigure but they are still operational, we are not in the position to switch it off and on again since we are working on the kit - the idea of creating this item on the forum was to ask NVIDIA as well as the community for any advice in case it is a known issue or someone else encountered the same behavior and to receive advice how to proceed so we would not end up with the same problem again on any of the kits we are using. In case we add a journalctl log here, could it be analyzed by NVIDIA to see what happened?
Thank you!
Best regards,
Lucian
Dear @lucpo ,
Please attach the logs here. Let me inspect the logs.
nvidia-thor-syslog.1-restart-after-power-outage.txt (5.9 MB)
I have attached the log showing the boot area after power outage - I have commented out multiple lines that printed the same thing related to mgbe2_0
2026-10-10T22:35:33.683334+00:00 tegra-ubuntu phc2sys: [30.937] mgbe2_0 phc offset 5 s2 freq +1 delay 2000
Please let us know if you see something unusual in the log - and as FYI before this happened, the kit was fully operational.
Thank you!
Best regards,
Lucian
Also, can you please let us know steps required to make the display available from the thor (display output on the display-port external screen)
Thank you,
Lucian
Do you have still have display issue?
Hello, display issue was solved, did you manage to check the attached logs?
