Hello, teachers, I would like to ask a question. That is.
orin has a flashing SDK with a graphical interface, where you can directly configure the username and password, and then directly enter the system after flashing, and using the command to flash the machine will let you configure the language, time zone, user name, and password once before flashing the system. Use the command line to configure user information in advance like a graphical interface, which file should be modified.
The SDK manager is for all NVIDIA SDKs/products, not only for Jetson platform.
I don’t want to configure user information every time after flashing, I hope to set up a custom account in advance, and you can see the login interface after the first launch.
Please check the section in developer guide:
Flashing Support — Jetson Linux Developer Guide documentation
