What do I have to do to use the jetson tx2 with orbitty carrierboard? I saw a post saying BSP should be placed. How do you install BSP in jetson?
I don’t have an Orbitty, but the general idea is that you get the matching version of NVIDIA’s software for flashing a normal dev board, then you unpack some of the Orbitty software on top of this prior to flashing. Mostly this will change the device tree, perhaps the kernel, and maybe add some other custom software. Orbitty probably has instructions, and the first thing you would do is find out what NVIDIA software release goes with their BSP.
A list of JetPack/SDKM versions and a list of L4T versions (JetPack/SDKM is a front end to the L4T software, and L4T is just Ubuntu with some extra drivers…it is L4T which actually goes into the flash, the rest are tools):
https://developer.nvidia.com/linux-tegra
https://developer.nvidia.com/embedded/jetpack-archive
(you will probably have to hit the URL, log in, and then click the URL again)
