I’m using 2 different sensors in 2 CaptureSessions under one CameraProvider, when run one camera at a time it never fails, but when run together it works about 5 times out of 6, it always fails with this error:
[ 2712.261882] host1x 13e10000.host1x: cdma_handle_timeout: timeout: 22 (15700000.vi_0) clientid 454, HW thresh 161, done 162
[ 2712.272941] ---- mlocks ----
[ 2712.272971] ---- syncpts ----
[ 2712.272989] id 11 (15600000.isp__visiond_0) min 2046 max 2046 refs 1 (previous client : 15600000.isp__visiond_0)
[ 2712.272993] id 12 (15600000.isp__visiond_1) min 1743 max 1743 refs 1 (previous client : 15600000.isp__visiond_1)
[ 2712.272997] id 13 (15600000.isp__visiond_2) min 1383 max 1383 refs 1 (previous client : 15600000.isp__visiond_2)
[ 2712.273001] id 14 (15600000.isp__visiond_3) min 1383 max 1383 refs 1 (previous client : 15600000.isp__visiond_3)
[ 2712.273004] id 15 (15600000.isp__visiond_4) min 7843 max 7843 refs 1 (previous client : 15600000.isp__visiond_4)
[ 2712.273008] id 16 (15600000.isp__visiond_5) min 3665 max 3665 refs 1 (previous client : 15600000.isp__visiond_5)
[ 2712.273011] id 17 (gp10b_507) min 360 max 360 refs 1 (previous client : gp10b_507)
[ 2712.273015] id 18 (gp10b_506) min 1410 max 1410 refs 1 (previous client : gp10b_506)
[ 2712.273018] id 19 (gp10b_505) min 390 max 390 refs 1 (previous client : gp10b_505)
[ 2712.273023] id 22 (15700000.vi_0) min 161 max 168 refs 9 (previous client : 15700000.vi_0)
[ 2712.273625] ---- channels ----
[ 2712.273636]
channel 2 - 15820000.se
[ 2712.273638] NvHost basic channel registers:
[ 2712.273641] CMDFIFO_STAT_0: 00002040
[ 2712.273643] CMDFIFO_RDATA_0: 04202050
[ 2712.273647] CMDP_OFFSET_0: 00000000
[ 2712.273650] CMDP_CLASS_0: 00000000
[ 2712.273652] CHANNELSTAT_0: 00000000
[ 2712.273671] The CDMA sync queue is empty.
[ 2712.273676]
channel 3 - 15830000.se
[ 2712.273677] NvHost basic channel registers:
[ 2712.273680] CMDFIFO_STAT_0: 00002040
[ 2712.273683] CMDFIFO_RDATA_0: 0a024c28
[ 2712.273687] CMDP_OFFSET_0: 00000000
[ 2712.273689] CMDP_CLASS_0: 00000000
[ 2712.273692] CHANNELSTAT_0: 00000000
[ 2712.273694] The CDMA sync queue is empty.
[ 2712.273698]
channel 4 - 15840000.se
[ 2712.273699] NvHost basic channel registers:
[ 2712.273702] CMDFIFO_STAT_0: 00002040
[ 2712.273704] CMDFIFO_RDATA_0: 02300840
[ 2712.273708] CMDP_OFFSET_0: 00000000
[ 2712.273713] CMDP_CLASS_0: 00000000
[ 2712.273715] CHANNELSTAT_0: 00000000
[ 2712.273717] The CDMA sync queue is empty.
[ 2712.273722]
channel 1 - 15700000.vi
[ 2712.273723] NvHost basic channel registers:
[ 2712.273725] CMDFIFO_STAT_0: 00000000
[ 2712.273728] CMDFIFO_RDATA_0: 00000000
[ 2712.273731] CMDP_OFFSET_0: 00000000
[ 2712.273734] CMDP_CLASS_0: 00000000
[ 2712.273736] CHANNELSTAT_0: 00000004
[ 2712.273740]
ffffffc0ea351400: JOB, syncpt_id=22, syncpt_val=162, first_get=00000d10, timeout=10000, num_slots=4
[ 2712.273746] GATHER at ffb08000+0000, 16 words
[ 2712.273748] 1110000d
[ 2712.273750] 00000020
[ 2712.273752] 00000020
[ 2712.273753] 00000020
[ 2712.273755] 00000020
[ 2712.273756] 00000020
[ 2712.273757] 00000020
[ 2712.273759] 00000002
[ 2712.273760] 00000002
[ 2712.273762] 00000002
[ 2712.273763] 00000002
[ 2712.273765] 00000002
[ 2712.273766] 00000002
[ 2712.273767] 00000000
[ 2712.273769] 11440001
[ 2712.273770] 00543210
[ 2712.273775] GATHER at ffb08000+0040, 2 words
[ 2712.273776] 20000001
[ 2712.273778] 00000016
[ 2712.273783]
---- host general irq ----
[ 2712.273785] sync_intc0mask = 0x00000001
[ 2712.273788] sync_intmask = 0x50000003
[ 2712.273789]
---- host syncpt irq mask ----
[ 2712.273790]
---- host syncpt irq status ----
[ 2712.273793] syncpt_thresh_cpu0_int_status(0) = 0x00000000
[ 2712.273796] syncpt_thresh_cpu0_int_status(1) = 0x00000000
[ 2712.273799] syncpt_thresh_cpu0_int_status(2) = 0x00000000
[ 2712.273801] syncpt_thresh_cpu0_int_status(3) = 0x00000000
[ 2712.273804] syncpt_thresh_cpu0_int_status(4) = 0x00000000
[ 2712.273806] syncpt_thresh_cpu0_int_status(5) = 0x00000000
[ 2712.273809] syncpt_thresh_cpu0_int_status(6) = 0x00000000
[ 2712.273811] syncpt_thresh_cpu0_int_status(7) = 0x00000000
[ 2712.273814] syncpt_thresh_cpu0_int_status(8) = 0x00000000
[ 2712.273816] syncpt_thresh_cpu0_int_status(9) = 0x00000000
[ 2712.273819] syncpt_thresh_cpu0_int_status(10) = 0x00000000
[ 2712.273821] syncpt_thresh_cpu0_int_status(11) = 0x00000000
[ 2712.273824] syncpt_thresh_cpu0_int_status(12) = 0x00000000
[ 2712.273827] syncpt_thresh_cpu0_int_status(13) = 0x00000000
[ 2712.273829] syncpt_thresh_cpu0_int_status(14) = 0x00000000
[ 2712.273832] syncpt_thresh_cpu0_int_status(15) = 0x00000000
[ 2712.273834] syncpt_thresh_cpu0_int_status(16) = 0x00000000
[ 2712.273837] syncpt_thresh_cpu0_int_status(17) = 0x00000000
[ 2712.273846] tegra-vi4 15700000.vi: SYNCPT_ID 22
[ 2712.273848] tegra-vi4 15700000.vi: SYNCPT_VAL 162
[ 2712.273851] tegra-vi4 15700000.vi: FIRST_GET 0xd10
[ 2712.273853] tegra-vi4 15700000.vi: TIMEOUT 10000
[ 2712.273855] tegra-vi4 15700000.vi: NUM_SLOTS 4
[ 2712.273857] tegra-vi4 15700000.vi: NUM_HANDLES 1
[ 2712.273863] tegra-vi4 15700000.vi: SYNCPT_ID 22
[ 2712.273865] tegra-vi4 15700000.vi: SYNCPT_VAL 163
[ 2712.273867] tegra-vi4 15700000.vi: FIRST_GET 0xd30
[ 2712.273869] tegra-vi4 15700000.vi: TIMEOUT 10000
[ 2712.273872] tegra-vi4 15700000.vi: NUM_SLOTS 4
[ 2712.273874] tegra-vi4 15700000.vi: NUM_HANDLES 1
[ 2712.273878] tegra-vi4 15700000.vi: SYNCPT_ID 22
[ 2712.273880] tegra-vi4 15700000.vi: SYNCPT_VAL 164
[ 2712.273882] tegra-vi4 15700000.vi: FIRST_GET 0xd50
[ 2712.273884] tegra-vi4 15700000.vi: TIMEOUT 10000
[ 2712.273886] tegra-vi4 15700000.vi: NUM_SLOTS 4
[ 2712.273888] tegra-vi4 15700000.vi: NUM_HANDLES 1
[ 2712.273893] tegra-vi4 15700000.vi: SYNCPT_ID 22
[ 2712.273895] tegra-vi4 15700000.vi: SYNCPT_VAL 165
[ 2712.273897] tegra-vi4 15700000.vi: FIRST_GET 0xd70
[ 2712.273898] tegra-vi4 15700000.vi: TIMEOUT 10000
[ 2712.273900] tegra-vi4 15700000.vi: NUM_SLOTS 4
[ 2712.273902] tegra-vi4 15700000.vi: NUM_HANDLES 1
[ 2712.273907] tegra-vi4 15700000.vi: SYNCPT_ID 22
[ 2712.273909] tegra-vi4 15700000.vi: SYNCPT_VAL 166
[ 2712.273911] tegra-vi4 15700000.vi: FIRST_GET 0xd90
[ 2712.273913] tegra-vi4 15700000.vi: TIMEOUT 10000
[ 2712.273915] tegra-vi4 15700000.vi: NUM_SLOTS 4
[ 2712.273917] tegra-vi4 15700000.vi: NUM_HANDLES 1
[ 2712.273922] tegra-vi4 15700000.vi: SYNCPT_ID 22
[ 2712.273924] tegra-vi4 15700000.vi: SYNCPT_VAL 167
[ 2712.273925] tegra-vi4 15700000.vi: FIRST_GET 0xdb0
[ 2712.273927] tegra-vi4 15700000.vi: TIMEOUT 10000
[ 2712.273929] tegra-vi4 15700000.vi: NUM_SLOTS 4
[ 2712.273931] tegra-vi4 15700000.vi: NUM_HANDLES 1
[ 2712.273936] tegra-vi4 15700000.vi: SYNCPT_ID 22
[ 2712.273938] tegra-vi4 15700000.vi: SYNCPT_VAL 168
[ 2712.273940] tegra-vi4 15700000.vi: FIRST_GET 0xdd0
[ 2712.273942] tegra-vi4 15700000.vi: TIMEOUT 10000
[ 2712.273944] tegra-vi4 15700000.vi: NUM_SLOTS 4
[ 2712.273946] tegra-vi4 15700000.vi: NUM_HANDLES 1
Is there anything specific that has to be done when using 2 different sensors in argus?
