Using a CUDA buffer with visionworks
I was reviewing the Visionworks documentation and the samples/demos and ran into the following question:
Let us assume I have an array that is allocated using cudaMallocManaged which is an image. How can I pass this into Visionworks for let’s say feature tracking, OR,
let us say I have 2 arrays (ie. 2 frames of a video). How can I pass these into Visionworks to do motion estimation?
You can find some information in our document here:
https://developer.nvidia.com/embedded/dlc/visionworks-1-6-documentation-for-l4t-27-1
VisionWorks API
> Tutorials
> NVX CUDA API Tutorial
> Data Object Creation
nvxcu_pitch_linear_image_t createImageU8(uint32_t width, uint32_t height)
    void *dev_ptr = NULL;
    size_t pitch = 0;
    cudaMallocPitch(&dev_ptr, &pitch, width * sizeof(uint8_t), height);
    nvxcu_pitch_linear_image_t image;
    image.base.image_type = NVXCU_PITCH_LINEAR_IMAGE;
    image.base.format = NVXCU_DF_IMAGE_U8;
    image.base.width = width;
    image.base.height = height;
    image.planes[0].dev_ptr = dev_ptr;
    image.planes[0].pitch_in_bytes = pitch;
    return image;
Thanks for your reply. This talks about creating an image buffer right?
I have already created a buffer using cudaMallocManaged. How do I use this as my image buffer and pass it to nvx? Does this make sense?
So you can replace this line to your buffer information:
