My platform is “pgf77 6.1-6 64-bit target on x86-64 Linux”.
I downloaded and installed ACML directly from AMD into a separate directory so as to have access to the _int64 and _mv variants of the lib in addition to the scalar and _mp variants.
Invoking the separately installed shared acml libs using the command line given in the documentation doesn’t seem to work properly.
$ pgf77 -mcmodel=medium dgetrf_example.f -L/usr/local/acml3.5.0/pgi64 -lacml
dgetrf_example.f:
$ ldd a.out
libacml.so => /share/apps/portland6.1/linux86-64/6.1/libso/libacml.so (0x0000002a95557000)
It appears that the version of libacml.so that comes with the Portland installation is being linked instead.
What’s the proper way of linking with an ACML that’s located in a separate directory.
Ed
