Using "AMD Radeon R9 200 Series"
How to use pgi/fortran/openacc to create an executable for “AMD Radeon R9 200 Series”?
Compilerversion: 14.10; OS: Windows 8.1
I tried using
pgi -tp=p7 -ta=radeon simple.for
The executable crashes with
E:\hydroas>simple_radeon.exe
call to clEnqueueTask returned error -4: memory object allocation failure
Device-info:
C:\temp\pgi>pgaccelinfo.exe
OpenCL Platform:               AMD Accelerated Parallel Processing
OpenCL Vendor:                 Advanced Micro Devices, Inc.
Device Number:                 0
Device Name:                   Hawaii
Available:                     Yes
Compiler Available:            Yes
Board Name:                    AMD Radeon R9 200 Series
Device Version:                OpenCL 1.2 AMD-APP (1642.5)
Global Memory Size:            3221225472
Maximum Object Size:           2899102924
Global Cache Size:             16384
Free Memory:                   4158681000
Max Clock (MHz):               1000
Compute Units:                 44
SIMD Units:                    4
SIMD Width:                    16
GPU Cores:                     2816
Wavefront Width:               64
Constant Memory Size:          65536
Local Memory Size:             32768
Workgroup Size:                256
Address Bits:                  32
ECC Support:                   No
Best regards
Benedikt
Hi Benedikt,
Support for the “Hawaii” architecture which your Radeon uses was added in PGI 15.1 . Once you have updated compiler, you’ll then use the “-ta=radeon:hawaii” to target your device.
Hope this helps,
Mat
Hi Mat,
thanks for the quick reply. I still get the same error message even with Compilerversion 15.4 .
I tried:
pgf90.exe -tp=p7 -acc -ta=radeon:hawaii -Mbackslash -Minfo -Mpreprocess simple.for -o simplehawaii32.exe
Here is my code
!$acc data copy (SUMME)
!$acc kernels
!$acc loop vector reduction(+:SUMME)
      DO 77 M=1,ANZ
          SUMME = SUMME + sin(REAL(M))**5
 77   CONTINUE
!$acc end kernels
!$acc end data
      TEST = SUMME
My compiler machine has no amd graphics installed. I am crosscompiling for a test system. Maybe a problem?
Any suggestions?
Best regards
Benedikt
x:\hydro\Hydro_AS\tests>…\pgi\pgaccelinfo.exe
Device Number: 0
Device Name: Hawaii
Available: Yes
Device Version: OpenCL 2.0 AMD-APP (1642.5)
Global Memory Size: 4294967296
Maximum Object Size: 3018326016
Free Memory: 4154442000
Compute Units: 44
SIMD Units: 4
SIMD Width: 16
GPU Cores: 2816
Wavefront Width: 64
Workgroup Size: 256
Address Bits: 64
ECC Support: No
PGI Compiler Option: -ta=radeon:hawaii
Unfortunately the AMD OCL runtime library that was used to build the binary must be copied over to the other system. You don’t need to replace what’s installed, but just need to have the directory where the DLL is in your PATH environment.
The DLL can be found in: C:\Program Files\PGI\win64\2015\radeon\1310\lib\amdocl64.dll
Granted, I don’t know if this is actually the issue your encountering, but please give it a try.
Thanks,
Mat
Hi Mat,
thanks for the hints. Benedikt is happy and I have a maschine to test our application.
Brilliant.
Maybe I have to dig more deeper into the manuals.
Best Regards
Frank
