I am trying to get Jetson to show video input from a CSI generator. The CSI generator is outputing a 4-lane CSI data. I am using Argus and modifying one of the example code (multiStream) to show the output.
Here are my questions:
Will cameraDevices able to get the camera device? If not, what else would I need to do?
What settings about the CSI output would I need to specify to the code to generate the correct outputs? How do I set them?
I tried to follow the instructions to create a camera driver but it’s still telling me No cameras available.
When I run v4l2-compliance, it returns “Failed to open /dev/video0: No such file or directory”.
Is there anything else I have to do after adding the dts/dtsi files and the .c files? Such as building the code perhaps? If so, do you have instructions on how to do that?
