Hi Tuan,
My question is if I can just declare a C-pointer to the 3D array, and then using cuda copy to copy linear array to this C-pointer which is pointing to the first element in the 3D array?
Sure. You can use “integer(c_devptr)” for CUDA C device pointers and “integer(c_ptr)” for host C pointers. Then use “c_f_pointer” to create the association between you 3D arrays and the C pointer. You can grab the C pointer from a Fortran host array using “c_loc”. I wrote a basic example below.
Though, I’m wondering if you really need to do all this. If you’re just using CUDA Fortran and your arrays are contiguous, a simple “arr1 = arr2” statement will perform the same thing.
Hope this helps,
Mat
% cat test.cuf
module test_mod
integer, device, allocatable :: x(:,:,:)
contains
attributes(global) subroutine kernel(l,m,n)
integer, value :: l, m, n
i = (blockidx%x-1)*blockdim%x + threadidx%x
j = (blockidx%y-1)*blockdim%y + threadidx%y
if (i <= l .and. j <= m ) then
do k=1,N
x(i,j,k) = ((i-1)*L*M)+((j-1)*M)+k
enddo
end if
return
end subroutine
end module test_mod
program test
use cudafor
use test_mod
implicit none
integer, parameter :: L = 64
integer, parameter :: M = 64
integer, parameter :: N = 64
integer size
integer istat
integer, target, allocatable, dimension(:,:,:) :: y
type(dim3) :: blocks
type(dim3) :: threads
type(c_ptr) :: h1
type(c_devptr) :: cd1
allocate(y(L,M,N))
size = L*M*N
istat = cudaMalloc(cd1, size*4)
call c_f_pointer(cd1, x, (/ L, M, N /))
blocks = dim3((L+31)/32, (M+31)/32, 1)
threads = dim3(32, 32, 1)
call kernel<<<blocks,threads>>>(L,M,N)
istat = cudaThreadSynchronize()
print *, cudaGetErrorString(cudaGetLastError())
h1 = c_loc(y)
istat = cudaMemcpy(h1, cd1, size*4, cudaMemcpyDeviceToHost)
print *, y(1,1,:)
print *, y(64,64,:)
deallocate(y)
istat = cudaFree(cd1)
end
% pgf90 test.cuf ; a.out
no error
1 2 3 4 5 6
7 8 9 10 11 12
13 14 15 16 17 18
19 20 21 22 23 24
25 26 27 28 29 30
31 32 33 34 35 36
37 38 39 40 41 42
43 44 45 46 47 48
49 50 51 52 53 54
55 56 57 58 59 60
61 62 63 64
262081 262082 262083 262084 262085 262086
262087 262088 262089 262090 262091 262092
262093 262094 262095 262096 262097 262098
262099 262100 262101 262102 262103 262104
262105 262106 262107 262108 262109 262110
262111 262112 262113 262114 262115 262116
262117 262118 262119 262120 262121 262122
262123 262124 262125 262126 262127 262128
262129 262130 262131 262132 262133 262134
262135 262136 262137 262138 262139 262140
262141 262142 262143 262144
