using cuda libraries with OpenACC
Here is an attempt to calculate pi using cuRand and OpenACC.
This example works fine with PGI 12.3 and CUDA 4.0.
Compiled program by PGI 12.5 and CUDA 4.0 always give 0 as the result.
Compiling this example with CUDA 4.1 give the following error:
$ make
pgcc -acc -ta=nvidia -Minfo=all main.c pi.c -I /opt/pgi/linux86-64/2012/cuda/4.1/include -L /opt/pgi/linux86-64/2012/cuda/4.1/lib64 -lcudart -lcurand -o pi_acc
main.c:
PGC-F-0249-#error --  --- !!! UNKNOWN COMPILER: please provide a CUDA compatible definition for '__align__' !!! --- (/opt/pgi/linux86-64/2012/cuda/4.1/include/host_defines.h: 128)
PGC/x86-64 Linux 12.3-0: compilation aborted
pi.c:
pi:
     10, Generating compute capability 1.3 binary
         Generating compute capability 2.0 binary
     11, Loop is parallelizable
         Accelerator kernel generated
         11, #pragma acc loop gang, vector(32) /* blockIdx.x threadIdx.x */
             CC 1.3 : 10 registers; 312 shared, 28 constant, 0 local memory bytes; 25% occupancy
             CC 2.0 : 12 registers; 264 shared, 72 constant, 0 local memory bytes; 16% occupancy
         14, Sum reduction generated for s
make: *** [pi_acc] Error 2
cat pi.c
#include <math.h>
// Iterate over pairs of (x,y) from [0,1] x [0,1]
// Increment pointer only if (x,y) is inside a circle with R = 0.5
long pi(float *dx, float *dy, long n)
    long i, s = 0;
    #pragma acc data deviceptr(dx, dy)
    #pragma acc kernels
    for (i = 0; i < n; i++) {
	float x = dx[i] - 0.5;
	float y = dy[i] - 0.5;
	s += (x*x + y*y < 0.25);
    return s;
#include <stdio.h>
#include <stdlib.h>
#include <curand.h>
#include "common.h"
int main(int argc, char **argv) {
    float *dx, *dy; // device arrays
    long s; // counter of successful tries
    long n; // number of tries
    if (argc < 2) {
	fprintf(stderr, "Usage: %s N\n", argv[0]);
	return EXIT_FAILURE;
    if ((n = atol(argv[1])) <= 0) {
	fprintf(stderr, "N must be positive\n");
    // Allocate memory for device arrays to be filled with random values
    CUDA_CALL(cudaMalloc((void *)&dx, n * sizeof(float)));
    CUDA_CALL(cudaMalloc((void *)&dy, n * sizeof(float)));
    // Initialize CURAND generator, seed it and generate data
    curandGenerator_t g;
    CURAND_CALL(curandCreateGenerator(&g, CURAND_RNG_PSEUDO_DEFAULT));
    CURAND_CALL(curandSetPseudoRandomGeneratorSeed(g, time(NULL)));
    CURAND_CALL(curandGenerateUniform(g, dx, n));
    CURAND_CALL(curandGenerateUniform(g, dy, n));
    // Perform computations
    s = pi(dx, dy, n);
    // Free memory
    CUDA_CALL(cudaFree(dx));
    CUDA_CALL(cudaFree(dy));
    // Print out the result
    printf("%lf\n", (double) s / n * 4.0);
    return EXIT_SUCCESS;
#include <stdio.h>
#include <stdlib.h>
#include <time.h>
#include <curand.h>
long pi(float *, float *, long);
inline long int clock_difftime(struct timespec t1, struct timespec t0) {
    return (t1.tv_sec - t0.tv_sec) + (float) (t1.tv_nsec - t0.tv_nsec);
// Convenience macros for CUDA and CURAND calls
#define CUDA_CALL(x) { cudaError_t rc = ( x ); if (rc != cudaSuccess) { \
        fprintf(stderr, "CUDA error %d (%s) at %s:%d\n", rc, cudaGetErrorString(rc), __FILE__, __LINE__); \
        exit(EXIT_FAILURE); \
#define CURAND_CALL(x) { cudaError_t rc = ( x ); if (rc != cudaSuccess) { \
// Convert CURAND error code to string
char *curandGetErrorString(curandStatus_t rc) {
    switch(rc) {
	case CURAND_STATUS_SUCCESS:
	    return "No errors";
	case CURAND_STATUS_VERSION_MISMATCH:
	    return "Header file and linked library version do not match";
	case CURAND_STATUS_NOT_INITIALIZED:
	    return "Generator not initialized";
	case CURAND_STATUS_ALLOCATION_FAILED:
	    return "Memory allocation failed";
	case CURAND_STATUS_TYPE_ERROR:
	    return "Generator is wrong type";
	case CURAND_STATUS_OUT_OF_RANGE:
	    return "Argument out of range";
	case CURAND_STATUS_LENGTH_NOT_MULTIPLE:
	    return "Length requested is not a multple of dimension";
// In CUDA >= 4.1 only
#if CUDART_VERSION >= 4010
	case CURAND_STATUS_DOUBLE_PRECISION_REQUIRED:
	    return "GPU does not have double precision required by MRG32k3a";
#endif
	case CURAND_STATUS_LAUNCH_FAILURE:
	    return "Kernel launch failure";
	case CURAND_STATUS_PREEXISTING_FAILURE:
	    return "Preexisting failure on library entry";
	case CURAND_STATUS_INITIALIZATION_FAILED:
	    return "Initialization of CUDA failed";
	case CURAND_STATUS_ARCH_MISMATCH:
	    return "Architecture mismatch, GPU does not support requested feature";
	case CURAND_STATUS_INTERNAL_ERROR:
	    return "Internal library error";
	default:
	    return "Unknown error";
Would you please tell me what I have to do to make it work with newer CUDA versions?
Hi conqueror,
There are two separate issues here. First, it does appear that 12.5 introduced a problem where your use of a “long” data type as the sum reduction variable no longer works correctly. If you change “s” to be an “int” or “float”, it will work around the issue. I have sent a report (TPR#18815) to our engineers for further investigation.
For example:
long pi2(float *dx, float *dy, long n)
  long i;
  int s = 0;
#pragma acc kernels
    s+= ((x*x + y*y) < 0.25);
  return (long) s;
% pgcc -acc main.c pi.c -I/opt/pgi/linux86-64/2012/cuda/4.0/include -L/opt/pgi/linux86-64/2012/cuda/4.0/lib64 -lcurand -o pi_acc -V12.5
main.c:
pi.c:
% pi_acc   100000000
Both should print 3.141...
Using Long: 0.000000
Using Int: 3.141509
Using CUDA C calls from pgcc compiled code is not actually supported. It happens to work in this case since we ported NVIDIA’s CUDA 4.0 header files for use with our CUDA X86 C++ compiler. In our 12.6 release, CUDA X86 will switch to using CUDA 4.1, so you should be able to uses these headers as well.
Mat
