I am seeking guidance how I can use the jetson util tools like the gstCamera that use CUDA and GStreamer in my Qt app for jetson nano. If I copy the header files into my Qt app will they work or are there build steps I need to take.
If you are looking for a solution of running deep learning inference, you may consider to use DeepStream SDK. The package can be installed through SDKManager.
I would recommend building/installing jetson-utils as per it’s CMakeLists.txt, as opposed to try and copying the headers into your own project. Also, if you build/install the top-level jetson-inference project, jetson-utils will be built/installed as a submodule.
Then see this example CMakeLists.txt as an example of an external application that links to jetson-inference / jetson-utils libraries using cmake find_package() command.
Thanks dusty_nv for the recommendation. I will try it. But I have one question. Is there an equivalent of find_package() in qmake or how would I link the libraries
Thanks too Collince, Very similar to what I need, let me look at it further and see if it can be useful to me.
QMake doesn’t appear to be compatible with the .cmake config files that get installed under /usr/local/share, however when you do the “sudo make install” step of jetson-inference, it installs the libraries to /usr/local/lib and the headers under /usr/local/include (both paths are included by the compiler/linker by default I believe). So you should be able to add jetson-inference and jetson-utils to you QMake LIBS variable.
