Using cusparseDgtsv2_nopivot() with OpenACC in Fortran code
I have written a test code that calls cusparseDgtsv2_nopivot function in cusparse library to solve tridiagonal matrix, in which openacc is used for data transmission, mainly referring to tcusparse3.f90.
Here is my program:
PROGRAM TDMA
  use openacc
  use cusparse
  implicit none
  integer, parameter :: npts = 31
  integer :: cusparseCreate_status
  type(cusparseHandle) :: handle
  integer :: m, n, ldb
  real(8) :: dl(npts), d(npts), du(npts)
  real(8) :: B(npts, 1)
  integer :: i
  integer :: istat
  integer(8) :: bufferSizeInBytes
  integer(1), pointer:: buffer(:)
  !$acc data create(dl,d,du,B)
  m = npts
  n = 1
  ldb = npts
  dl = 1.0
  dl(1) = 0.0
  d = 2.0
  du = 1.0
  du(npts) = 0.0
  !$acc kernels
  do i = 1, 16
    B(i, 1) = i
    B(32 - i, 1) = i
  end do
  !$acc end kernels
  cusparseCreate_status = cusparseCreate(handle)
  print *, 'CREATE cusparseCreate_status: '
  if (cusparseCreate_status == CUSPARSE_STATUS_SUCCESS) then
    print *, 'CUSPARSE_STATUS_SUCCESS'
  elseif (cusparseCreate_status == CUSPARSE_STATUS_NOT_INITIALIZED) then
    print *, 'CUSPARSE_STATUS_NOT_INITIALIZED'
  elseif (cusparseCreate_status == CUSPARSE_STATUS_ALLOC_FAILED) then
    print *, 'CUSPARSE_STATUS_ALLOC_FAILED'
  elseif (cusparseCreate_status == CUSPARSE_STATUS_ARCH_MISMATCH) then
    print *, 'CUSPARSE_STATUS_ARCH_MISMATCHED'
  end if
  istat = cusparseDgtsv2_nopivot_buffersizeext(handle, m, n, dl, d, du, B, ldb, bufferSizeInBytes)
  allocate(buffer(bufferSizeInBytes))
  istat = cusparseDgtsv2_nopivot(handle, m, n, dl, d, du, B, ldb, buffer)
    print *, 'Dgtsv STATUS: '
  if (istat == CUSPARSE_STATUS_SUCCESS) then
  elseif (istat == CUSPARSE_STATUS_NOT_INITIALIZED) then
  elseif (istat == CUSPARSE_STATUS_ALLOC_FAILED) then
  elseif (istat == CUSPARSE_STATUS_INVALID_VALUE) then
    print *, 'CUSPARSE_STATUS_INVALID_VALUE'
  elseif (istat == CUSPARSE_STATUS_ARCH_MISMATCH) then
  elseif (istat == CUSPARSE_STATUS_EXECUTION_FAILED) then
    print *, 'CUSPARSE_STATUS_EXECUTION_FAILED'
  elseif (istat == CUSPARSE_STATUS_INTERNAL_ERROR) then
    print *, 'CUSPARSE_STATUS_INTERNAL_ERROR'
  end if
  !$acc update host(B)
  !$acc end data
  print *, 'The solution is: '
  do i = 1, npts
    print *, 'SOL(', i, '):', B(i, 1)
  end do
END PROGRAM TDMA
After running, it displays:
 Dgtsv STATUS:
Failing in Thread:1
Accelerator Fatal Error: call to cuMemcpyDtoHAsync returned error 700: Illegal address during kernel execution
 File: /home/lixinyu/5555/5555/gtsv2acc.f90
 Function: tdma:1
 Line: 64
make: *** [makefile:15: run] Error 1
 The result shows that the cusparseDgtsv2_nopivot function seems to have been called successfully, but I am still not sure how to transfer the result of the function to the host and print it.
If you have any other recommendation for the code, it would be helpful.
Looking forward your replies,thanks!
Hi. This is a CUDA Fortran question, not for cuSparse. You can discuss this in Fortran forum nvc, nvc++ and nvfortran - NVIDIA Developer Forums.
Thank you!
