Jetpack 3.1
Here is an output from the sensor around the time it begins to fail. It streams successfully for approximately 30 seconds to 4 minutes before failing generally.
kworker/4:1-152 [004] ...1 364.010088: rtos_queue_peek_from_isr_failed: tstamp:11674902751 queue:0x0b4a3c58
kworker/4:1-152 [004] ...1 364.010097: rtcpu_vinotify_handle_msg: tstamp:11675205579 tag:CHANSEL_PXL_EOF channel:0x00 frame:131 vi_tstamp:3085270590 data:0x0da70002
kworker/4:1-152 [004] ...1 364.010100: rtcpu_vinotify_handle_msg: tstamp:11675206139 tag:ISPBUF_FE channel:0x00 frame:131 vi_tstamp:3085271147 data:0x00000000
kworker/4:1-152 [004] ...1 364.010102: rtcpu_vinotify_handle_msg: tstamp:11675755256 tag:ISPBUF_FS channel:0x00 frame:132 vi_tstamp:3085820254 data:0x00000000
kworker/4:1-152 [004] ...1 364.010105: rtcpu_vinotify_handle_msg: tstamp:11675762975 tag:CHANSEL_PXL_SOF channel:0x00 frame:132 vi_tstamp:3085827985 data:0x00000001
kworker/4:1-152 [004] ...1 364.062092: rtcpu_vinotify_handle_msg: tstamp:11676770949 tag:CHANSEL_PXL_EOF channel:0x00 frame:132 vi_tstamp:3086835953 data:0x0da70002
kworker/4:1-152 [004] ...1 364.062100: rtcpu_vinotify_handle_msg: tstamp:11676771513 tag:ISPBUF_FE channel:0x00 frame:132 vi_tstamp:3086836511 data:0x00000000
kworker/4:1-152 [004] ...1 364.062102: rtcpu_vinotify_handle_msg: tstamp:11677320621 tag:ISPBUF_FS channel:0x00 frame:133 vi_tstamp:3087385618 data:0x00000000
kworker/4:1-152 [004] ...1 364.062105: rtcpu_vinotify_handle_msg: tstamp:11677328335 tag:CHANSEL_PXL_SOF channel:0x00 frame:133 vi_tstamp:3087393349 data:0x00000001
kworker/4:1-152 [004] ...1 364.114077: rtcpu_vinotify_handle_msg: tstamp:11678336325 tag:CHANSEL_PXL_EOF channel:0x00 frame:133 vi_tstamp:3088401317 data:0x0da70002
kworker/4:1-152 [004] ...1 364.114085: rtcpu_vinotify_handle_msg: tstamp:11678336888 tag:ISPBUF_FE channel:0x00 frame:133 vi_tstamp:3088401875 data:0x00000000
kworker/4:1-152 [004] ...1 364.114087: rtcpu_vinotify_handle_msg: tstamp:11678885979 tag:ISPBUF_FS channel:0x00 frame:134 vi_tstamp:3088950983 data:0x00000000
kworker/4:1-152 [004] ...1 364.114090: rtcpu_vinotify_handle_msg: tstamp:11678893703 tag:CHANSEL_PXL_SOF channel:0x00 frame:134 vi_tstamp:3088958713 data:0x00000001
kworker/4:1-152 [004] ...1 364.166093: rtcpu_vinotify_handle_msg: tstamp:11679901677 tag:CHANSEL_PXL_EOF channel:0x00 frame:134 vi_tstamp:3089966681 data:0x0da70002
kworker/4:1-152 [004] ...1 364.166100: rtcpu_vinotify_handle_msg: tstamp:11679902241 tag:ISPBUF_FE channel:0x00 frame:134 vi_tstamp:3089967239 data:0x00000000
kworker/4:1-152 [004] ...1 364.166105: rtos_queue_peek_from_isr_failed: tstamp:11679903249 queue:0x0b4a3c58
kworker/4:1-152 [004] ...1 364.166107: rtcpu_vinotify_handle_msg: tstamp:11680451351 tag:ISPBUF_FS channel:0x00 frame:135 vi_tstamp:3090516346 data:0x00000000
kworker/4:1-152 [004] ...1 364.166110: rtcpu_vinotify_handle_msg: tstamp:11680459065 tag:CHANSEL_PXL_SOF channel:0x00 frame:135 vi_tstamp:3090524077 data:0x00000001
kworker/4:1-152 [004] ...1 364.218092: rtcpu_vinotify_handle_msg: tstamp:11681467042 tag:CHANSEL_PXL_EOF channel:0x00 frame:135 vi_tstamp:3091532045 data:0x0da70002
kworker/4:1-152 [004] ...1 364.218099: rtcpu_vinotify_handle_msg: tstamp:11681467606 tag:ISPBUF_FE channel:0x00 frame:135 vi_tstamp:3091532603 data:0x00000000
kworker/4:1-152 [004] ...1 364.218102: rtcpu_vinotify_handle_msg: tstamp:11682016723 tag:ISPBUF_FS channel:0x00 frame:136 vi_tstamp:3092081711 data:0x00000000
kworker/4:1-152 [004] ...1 364.218104: rtcpu_vinotify_handle_msg: tstamp:11682024431 tag:CHANSEL_PXL_SOF channel:0x00 frame:136 vi_tstamp:3092089439 data:0x00000001
kworker/4:1-152 [004] ...1 364.270077: rtcpu_vinotify_handle_msg: tstamp:11683032420 tag:CHANSEL_PXL_EOF channel:0x00 frame:136 vi_tstamp:3093097409 data:0x0da70002
kworker/4:1-152 [004] ...1 364.270083: rtcpu_vinotify_handle_msg: tstamp:11683032983 tag:ISPBUF_FE channel:0x00 frame:136 vi_tstamp:3093097967 data:0x00000000
kworker/4:1-152 [004] ...1 364.270086: rtcpu_vinotify_handle_msg: tstamp:11683582075 tag:ISPBUF_FS channel:0x00 frame:137 vi_tstamp:3093647074 data:0x00000000
kworker/4:1-152 [004] ...1 364.270088: rtcpu_vinotify_handle_msg: tstamp:11683589794 tag:CHANSEL_PXL_SOF channel:0x00 frame:137 vi_tstamp:3093654803 data:0x00000001
kworker/4:1-152 [004] ...1 364.322077: rtcpu_vinotify_handle_msg: tstamp:11684597773 tag:CHANSEL_PXL_EOF channel:0x00 frame:137 vi_tstamp:3094662773 data:0x0da70002
kworker/4:1-152 [004] ...1 364.322084: rtcpu_vinotify_handle_msg: tstamp:11684598337 tag:ISPBUF_FE channel:0x00 frame:137 vi_tstamp:3094663330 data:0x00000000
kworker/4:1-152 [004] ...1 364.322089: rtos_queue_peek_from_isr_failed: tstamp:11684903763 queue:0x0b4a3c58
kworker/4:1-152 [004] ...1 364.322092: rtcpu_vinotify_handle_msg: tstamp:11685147430 tag:ISPBUF_FS channel:0x00 frame:138 vi_tstamp:3095212438 data:0x00000000
kworker/4:1-152 [004] ...1 364.322094: rtcpu_vinotify_handle_msg: tstamp:11685155151 tag:CHANSEL_PXL_SOF channel:0x00 frame:138 vi_tstamp:3095220167 data:0x00000001
kworker/4:1-152 [004] ...1 364.374076: rtcpu_vinotify_handle_msg: tstamp:11686163133 tag:CHANSEL_PXL_EOF channel:0x00 frame:138 vi_tstamp:3096228137 data:0x0da70002
kworker/4:1-152 [004] ...1 364.374083: rtcpu_vinotify_handle_msg: tstamp:11686163697 tag:ISPBUF_FE channel:0x00 frame:138 vi_tstamp:3096228695 data:0x00000000
kworker/4:1-152 [004] ...1 364.374086: rtcpu_vinotify_handle_msg: tstamp:11686712798 tag:ISPBUF_FS channel:0x00 frame:139 vi_tstamp:3096777802 data:0x00000000
kworker/4:1-152 [004] ...1 364.374088: rtcpu_vinotify_handle_msg: tstamp:11686720521 tag:CHANSEL_PXL_SOF channel:0x00 frame:139 vi_tstamp:3096785533 data:0x00000001
kworker/4:1-152 [004] ...1 364.426077: rtcpu_vinotify_handle_msg: tstamp:11687728500 tag:CHANSEL_PXL_EOF channel:0x00 frame:139 vi_tstamp:3097793501 data:0x0da70002
kworker/4:1-152 [004] ...1 364.426083: rtcpu_vinotify_handle_msg: tstamp:11687729064 tag:ISPBUF_FE channel:0x00 frame:139 vi_tstamp:3097794059 data:0x00000000
kworker/4:1-152 [004] ...1 364.426086: rtcpu_vinotify_handle_msg: tstamp:11688278163 tag:ISPBUF_FS channel:0x00 frame:140 vi_tstamp:3098343166 data:0x00000000
kworker/4:1-152 [004] ...1 364.426088: rtcpu_vinotify_handle_msg: tstamp:11688285886 tag:CHANSEL_PXL_SOF channel:0x00 frame:140 vi_tstamp:3098350896 data:0x00000001
kworker/4:1-152 [004] ...1 364.478105: rtcpu_vinotify_handle_msg: tstamp:11689293862 tag:CHANSEL_PXL_EOF channel:0x00 frame:140 vi_tstamp:3099358865 data:0x0da70002
kworker/4:1-152 [004] ...1 364.478111: rtcpu_vinotify_handle_msg: tstamp:11689294427 tag:ISPBUF_FE channel:0x00 frame:140 vi_tstamp:3099359422 data:0x00000000
kworker/4:1-152 [004] ...1 364.478114: rtcpu_vinotify_handle_msg: tstamp:11689843541 tag:ISPBUF_FS channel:0x00 frame:141 vi_tstamp:3099908529 data:0x00000000
kworker/4:1-152 [004] ...1 364.478116: rtcpu_vinotify_handle_msg: tstamp:11689851247 tag:CHANSEL_PXL_SOF channel:0x00 frame:141 vi_tstamp:3099916259 data:0x00000001
kworker/4:1-152 [004] ...1 364.478121: rtos_queue_peek_from_isr_failed: tstamp:11689904263 queue:0x0b4a3c58
kworker/4:1-152 [004] ...1 364.530073: rtcpu_vinotify_handle_msg: tstamp:11690859222 tag:CHANSEL_PXL_EOF channel:0x00 frame:141 vi_tstamp:3100924228 data:0x0da70002
kworker/4:1-152 [004] ...1 364.530079: rtcpu_vinotify_handle_msg: tstamp:11690859787 tag:ISPBUF_FE channel:0x00 frame:141 vi_tstamp:3100924787 data:0x00000000
kworker/4:1-152 [004] ...1 364.530082: rtcpu_vinotify_handle_msg: tstamp:11691408893 tag:ISPBUF_FS channel:0x00 frame:142 vi_tstamp:3101473894 data:0x00000000
kworker/4:1-152 [004] ...1 364.530084: rtcpu_vinotify_handle_msg: tstamp:11691416613 tag:CHANSEL_PXL_SOF channel:0x00 frame:142 vi_tstamp:3101481623 data:0x00000001
kworker/4:1-152 [004] ...1 364.582078: rtcpu_vinotify_handle_msg: tstamp:11692424587 tag:CHANSEL_PXL_EOF channel:0x00 frame:142 vi_tstamp:3102489593 data:0x0da70002
kworker/4:1-152 [004] ...1 364.582085: rtcpu_vinotify_handle_msg: tstamp:11692425152 tag:ISPBUF_FE channel:0x00 frame:142 vi_tstamp:3102490150 data:0x00000000
kworker/4:1-152 [004] ...1 364.582087: rtcpu_vinotify_handle_msg: tstamp:11692974259 tag:ISPBUF_FS channel:0x00 frame:143 vi_tstamp:3103039257 data:0x00000000
kworker/4:1-152 [004] ...1 364.582090: rtcpu_vinotify_handle_msg: tstamp:11692981977 tag:CHANSEL_PXL_SOF channel:0x00 frame:143 vi_tstamp:3103046986 data:0x00000001
kworker/4:1-152 [004] ...1 364.634077: rtcpu_vinotify_handle_msg: tstamp:11693989956 tag:CHANSEL_PXL_EOF channel:0x00 frame:143 vi_tstamp:3104054956 data:0x0da70002
kworker/4:1-152 [004] ...1 364.634084: rtcpu_vinotify_handle_msg: tstamp:11693990516 tag:ISPBUF_FE channel:0x00 frame:143 vi_tstamp:3104055514 data:0x00000000
kworker/4:1-152 [004] ...1 364.634087: rtcpu_vinotify_handle_msg: tstamp:11694539623 tag:ISPBUF_FS channel:0x00 frame:144 vi_tstamp:3104604621 data:0x00000000
kworker/4:1-152 [004] ...1 364.634089: rtcpu_vinotify_handle_msg: tstamp:11694547344 tag:CHANSEL_PXL_SOF channel:0x00 frame:144 vi_tstamp:3104612352 data:0x00000001
kworker/4:1-152 [004] ...1 364.634094: rtos_queue_peek_from_isr_failed: tstamp:11694904771 queue:0x0b4a3c58
kworker/4:1-152 [004] ...1 364.686065: rtcpu_vinotify_handle_msg: tstamp:11695555314 tag:CHANSEL_PXL_EOF channel:0x00 frame:144 vi_tstamp:3105620320 data:0x0da70002
kworker/4:1-152 [004] ...1 364.686071: rtcpu_vinotify_handle_msg: tstamp:11695555879 tag:ISPBUF_FE channel:0x00 frame:144 vi_tstamp:3105620878 data:0x00000000
kworker/4:1-152 [004] ...1 364.686074: rtcpu_vinotify_handle_msg: tstamp:11696104986 tag:ISPBUF_FS channel:0x00 frame:145 vi_tstamp:3106169985 data:0x00000000
kworker/4:1-152 [004] ...1 364.686076: rtcpu_vinotify_handle_msg: tstamp:11696112704 tag:CHANSEL_PXL_SOF channel:0x00 frame:145 vi_tstamp:3106177715 data:0x00000001
kworker/4:1-152 [004] ...1 364.738092: rtcpu_vinotify_handle_msg: tstamp:11697120684 tag:CHANSEL_PXL_EOF channel:0x00 frame:145 vi_tstamp:3107185684 data:0x0da70002
kworker/4:1-152 [004] ...1 364.738100: rtcpu_vinotify_handle_msg: tstamp:11697121247 tag:ISPBUF_FE channel:0x00 frame:145 vi_tstamp:3107186242 data:0x00000000
kworker/4:1-152 [004] ...1 364.738103: rtcpu_vinotify_handle_msg: tstamp:11697670361 tag:ISPBUF_FS channel:0x00 frame:146 vi_tstamp:3107735349 data:0x00000000
kworker/4:1-152 [004] ...1 364.738105: rtcpu_vinotify_handle_msg: tstamp:11697678071 tag:CHANSEL_PXL_SOF channel:0x00 frame:146 vi_tstamp:3107743080 data:0x00000001
kworker/4:1-152 [004] ...1 364.738108: rtcpu_vinotify_handle_msg: tstamp:11698686058 tag:CHANSEL_PXL_EOF channel:0x00 frame:146 vi_tstamp:3108751048 data:0x0da70002
kworker/4:1-152 [004] ...1 364.738110: rtcpu_vinotify_handle_msg: tstamp:11698686621 tag:ISPBUF_FE channel:0x00 frame:146 vi_tstamp:3108751606 data:0x00000000
kworker/4:1-152 [004] ...1 364.790098: rtcpu_vinotify_handle_msg: tstamp:11699235715 tag:ISPBUF_FS channel:0x00 frame:147 vi_tstamp:3109300714 data:0x00000000
kworker/4:1-152 [004] ...1 364.790106: rtcpu_vinotify_handle_msg: tstamp:11699243432 tag:CHANSEL_PXL_SOF channel:0x00 frame:147 vi_tstamp:3109308442 data:0x00000001
kworker/4:1-152 [004] ...1 364.790111: rtos_queue_peek_from_isr_failed: tstamp:11699905284 queue:0x0b4a3c58
kworker/4:1-152 [004] ...1 364.790113: rtcpu_vinotify_handle_msg: tstamp:11700251403 tag:CHANSEL_PXL_EOF channel:0x00 frame:147 vi_tstamp:3110316412 data:0x0da70002
kworker/4:1-152 [004] ...1 364.790116: rtcpu_vinotify_handle_msg: tstamp:11700251962 tag:ISPBUF_FE channel:0x00 frame:147 vi_tstamp:3110316970 data:0x00000000
kworker/4:1-152 [004] ...1 364.946066: rtcpu_vinotify_handle_msg: tstamp:11703931804 tag:ISPBUF_FS channel:0x00 frame:150 vi_tstamp:3113996805 data:0x00000000
kworker/4:1-152 [004] ...1 364.946075: rtcpu_vinotify_handle_msg: tstamp:11703939527 tag:CHANSEL_PXL_SOF channel:0x00 frame:150 vi_tstamp:3114004533 data:0x00000001
kworker/4:1-152 [004] ...1 364.946080: rtos_queue_peek_from_isr_failed: tstamp:11704905790 queue:0x0b4a3c58
kworker/4:1-152 [004] ...1 364.946083: rtcpu_vinotify_handle_msg: tstamp:11704947497 tag:CHANSEL_PXL_EOF channel:0x00 frame:150 vi_tstamp:3115012504 data:0x0da70002
kworker/4:1-152 [004] ...1 364.946085: rtcpu_vinotify_handle_msg: tstamp:11704948054 tag:ISPBUF_FE channel:0x00 frame:150 vi_tstamp:3115013061 data:0x00000000
kworker/4:1-152 [004] ...1 364.998073: rtcpu_vinotify_handle_msg: tstamp:11705497171 tag:ISPBUF_FS channel:0x00 frame:151 vi_tstamp:3115562168 data:0x00000000
kworker/4:1-152 [004] ...1 364.998082: rtcpu_vinotify_handle_msg: tstamp:11705504889 tag:CHANSEL_PXL_SOF channel:0x00 frame:151 vi_tstamp:3115569898 data:0x00000001
kworker/4:1-152 [004] ...1 364.998084: rtcpu_vinotify_handle_msg: tstamp:11706512876 tag:CHANSEL_PXL_EOF channel:0x00 frame:151 vi_tstamp:3116577867 data:0x0da70002
kworker/4:1-152 [004] ...1 364.998087: rtcpu_vinotify_handle_msg: tstamp:11706513440 tag:ISPBUF_FE channel:0x00 frame:151 vi_tstamp:3116578425 data:0x00000000
kworker/4:1-152 [004] ...1 365.050063: rtcpu_vinotify_handle_msg: tstamp:11707062535 tag:ISPBUF_FS channel:0x00 frame:152 vi_tstamp:3117127532 data:0x00000000
kworker/4:1-152 [004] ...1 365.050071: rtcpu_vinotify_handle_msg: tstamp:11707070249 tag:CHANSEL_PXL_SOF channel:0x00 frame:152 vi_tstamp:3117135262 data:0x00000001
kworker/4:1-152 [004] ...1 365.050074: rtcpu_vinotify_handle_msg: tstamp:11708078228 tag:CHANSEL_PXL_EOF channel:0x00 frame:152 vi_tstamp:3118143231 data:0x0da70002
kworker/4:1-152 [004] ...1 365.050076: rtcpu_vinotify_handle_msg: tstamp:11708078792 tag:ISPBUF_FE channel:0x00 frame:152 vi_tstamp:3118143789 data:0x00000000
kworker/4:1-152 [004] ...1 365.102082: rtcpu_vinotify_handle_msg: tstamp:11708627897 tag:ISPBUF_FS channel:0x00 frame:153 vi_tstamp:3118692897 data:0x00000000
kworker/4:1-152 [004] ...1 365.102090: rtcpu_vinotify_handle_msg: tstamp:11708635616 tag:CHANSEL_PXL_SOF channel:0x00 frame:153 vi_tstamp:3118700627 data:0x00000001
kworker/4:1-152 [004] ...1 365.102092: rtcpu_vinotify_handle_msg: tstamp:11709643593 tag:CHANSEL_PXL_EOF channel:0x00 frame:153 vi_tstamp:3119708595 data:0x0da70002
kworker/4:1-152 [004] ...1 365.102094: rtcpu_vinotify_handle_msg: tstamp:11709644149 tag:ISPBUF_FE channel:0x00 frame:153 vi_tstamp:3119709153 data:0x00000000
kworker/4:1-152 [004] ...1 365.102099: rtos_queue_peek_from_isr_failed: tstamp:11709906298 queue:0x0b4a3c58
kworker/4:1-152 [004] ...1 365.154070: rtcpu_vinotify_handle_msg: tstamp:11710193253 tag:ISPBUF_FS channel:0x00 frame:154 vi_tstamp:3120258260 data:0x00000000
kworker/4:1-152 [004] ...1 365.154078: rtcpu_vinotify_handle_msg: tstamp:11710200980 tag:CHANSEL_PXL_SOF channel:0x00 frame:154 vi_tstamp:3120265990 data:0x00000001
kworker/4:1-152 [004] ...1 365.154080: rtcpu_vinotify_handle_msg: tstamp:11711208956 tag:CHANSEL_PXL_EOF channel:0x00 frame:154 vi_tstamp:3121273959 data:0x0da70002
kworker/4:1-152 [004] ...1 365.154083: rtcpu_vinotify_handle_msg: tstamp:11711209519 tag:ISPBUF_FE channel:0x00 frame:154 vi_tstamp:3121274516 data:0x00000000
kworker/4:1-152 [004] ...1 365.206593: rtcpu_vinotify_handle_msg: tstamp:11711758624 tag:ISPBUF_FS channel:0x00 frame:155 vi_tstamp:3121823624 data:0x00000000
kworker/4:1-152 [004] ...1 365.206602: rtcpu_vinotify_handle_msg: tstamp:11711766341 tag:CHANSEL_PXL_SOF channel:0x00 frame:155 vi_tstamp:3121831353 data:0x00000001
kworker/4:1-152 [004] ...1 365.206604: rtcpu_vinotify_handle_msg: tstamp:11712774322 tag:CHANSEL_PXL_EOF channel:0x00 frame:155 vi_tstamp:3122839323 data:0x0da70002
kworker/4:1-152 [004] ...1 365.206606: rtcpu_vinotify_handle_msg: tstamp:11712774884 tag:ISPBUF_FE channel:0x00 frame:155 vi_tstamp:3122839881 data:0x00000000
kworker/4:1-152 [004] ...1 365.206609: rtcpu_vinotify_handle_msg: tstamp:11713323985 tag:ISPBUF_FS channel:0x00 frame:156 vi_tstamp:3123388988 data:0x00000000
kworker/4:1-152 [004] ...1 365.206611: rtcpu_vinotify_handle_msg: tstamp:11713331707 tag:CHANSEL_PXL_SOF channel:0x00 frame:156 vi_tstamp:3123396717 data:0x00000001
kworker/4:1-152 [004] ...1 365.258094: rtcpu_vinotify_handle_msg: tstamp:11714339691 tag:CHANSEL_PXL_EOF channel:0x00 frame:156 vi_tstamp:3124404687 data:0x0da70002
kworker/4:1-152 [004] ...1 365.258101: rtcpu_vinotify_handle_msg: tstamp:11714340254 tag:ISPBUF_FE channel:0x00 frame:156 vi_tstamp:3124405244 data:0x00000000
kworker/4:1-152 [004] ...1 365.258107: rtcpu_vinotify_handle_msg: tstamp:11714889364 tag:ISPBUF_FS channel:0x00 frame:157 vi_tstamp:3124954352 data:0x00000000
kworker/4:1-152 [004] ...1 365.258110: rtcpu_vinotify_handle_msg: tstamp:11714897072 tag:CHANSEL_PXL_SOF channel:0x00 frame:157 vi_tstamp:3124962082 data:0x00000001
kworker/4:1-152 [004] ...1 365.258115: rtos_queue_peek_from_isr_failed: tstamp:11714906794 queue:0x0b4a3c58
kworker/4:1-152 [004] ...1 365.310086: rtcpu_vinotify_handle_msg: tstamp:11715905064 tag:CHANSEL_PXL_EOF channel:0x00 frame:157 vi_tstamp:3125970051 data:0x0da70002
kworker/4:1-152 [004] ...1 365.310093: rtcpu_vinotify_handle_msg: tstamp:11715905629 tag:ISPBUF_FE channel:0x00 frame:157 vi_tstamp:3125970609 data:0x00000000
kworker/4:1-152 [004] ...1 365.310096: rtcpu_vinotify_handle_msg: tstamp:11716454719 tag:ISPBUF_FS channel:0x00 frame:158 vi_tstamp:3126519716 data:0x00000000
kworker/4:1-152 [004] ...1 365.310099: rtcpu_vinotify_handle_msg: tstamp:11716462437 tag:CHANSEL_PXL_SOF channel:0x00 frame:158 vi_tstamp:3126527446 data:0x00000001
kworker/4:1-152 [004] ...1 365.362140: rtcpu_vinotify_handle_msg: tstamp:11717470412 tag:CHANSEL_PXL_EOF channel:0x00 frame:158 vi_tstamp:3127535415 data:0x0da70002
kworker/4:1-152 [004] ...1 365.362148: rtcpu_vinotify_handle_msg: tstamp:11717470974 tag:ISPBUF_FE channel:0x00 frame:158 vi_tstamp:3127535973 data:0x00000000
kworker/4:1-152 [004] ...1 365.362150: rtcpu_vinotify_handle_msg: tstamp:11718020077 tag:ISPBUF_FS channel:0x00 frame:159 vi_tstamp:3128085080 data:0x00000000
kworker/4:1-152 [004] ...1 365.362153: rtcpu_vinotify_handle_msg: tstamp:11718027799 tag:CHANSEL_PXL_SOF channel:0x00 frame:159 vi_tstamp:3128092809 data:0x00000001
kworker/4:1-152 [004] ...1 365.414089: rtcpu_vinotify_handle_msg: tstamp:11719035774 tag:CHANSEL_PXL_EOF channel:0x00 frame:159 vi_tstamp:3129100779 data:0x0da70002
kworker/4:1-152 [004] ...1 365.414096: rtcpu_vinotify_handle_msg: tstamp:11719036336 tag:ISPBUF_FE channel:0x00 frame:159 vi_tstamp:3129101336 data:0x00000000
kworker/4:1-152 [004] ...1 365.414098: rtcpu_vinotify_handle_msg: tstamp:11719585443 tag:ISPBUF_FS channel:0x00 frame:160 vi_tstamp:3129650443 data:0x00000000
kworker/4:1-152 [004] ...1 365.414101: rtcpu_vinotify_handle_msg: tstamp:11719593161 tag:CHANSEL_PXL_SOF channel:0x00 frame:160 vi_tstamp:3129658173 data:0x00000001
kworker/4:1-152 [004] ...1 365.466059: rtos_queue_peek_from_isr_failed: tstamp:11719907311 queue:0x0b4a3c58
kworker/4:1-152 [004] ...1 365.466065: rtcpu_vinotify_handle_msg: tstamp:11720601144 tag:CHANSEL_PXL_EOF channel:0x00 frame:160 vi_tstamp:3130666142 data:0x0da70002
kworker/4:1-152 [004] ...1 365.466068: rtcpu_vinotify_handle_msg: tstamp:11720601711 tag:ISPBUF_FE channel:0x00 frame:160 vi_tstamp:3130666701 data:0x00000000
kworker/4:1-152 [004] ...1 365.466070: rtcpu_vinotify_handle_msg: tstamp:11721150808 tag:ISPBUF_FS channel:0x00 frame:161 vi_tstamp:3131215808 data:0x00000000
kworker/4:1-152 [004] ...1 365.466071: rtcpu_vinotify_handle_msg: tstamp:11721158530 tag:CHANSEL_PXL_SOF channel:0x00 frame:161 vi_tstamp:3131223538 data:0x00000001
kworker/4:1-152 [004] ...1 365.518113: rtcpu_vinotify_handle_msg: tstamp:11722166502 tag:CHANSEL_PXL_EOF channel:0x00 frame:161 vi_tstamp:3132231507 data:0x0da70002
kworker/4:1-152 [004] ...1 365.518120: rtcpu_vinotify_handle_msg: tstamp:11722167067 tag:ISPBUF_FE channel:0x00 frame:161 vi_tstamp:3132232064 data:0x00000000
kworker/4:1-152 [004] ...1 365.518123: rtcpu_vinotify_handle_msg: tstamp:11722716169 tag:ISPBUF_FS channel:0x00 frame:162 vi_tstamp:3132781172 data:0x00000000
kworker/4:1-152 [004] ...1 365.518126: rtcpu_vinotify_handle_msg: tstamp:11722723892 tag:CHANSEL_PXL_SOF channel:0x00 frame:162 vi_tstamp:3132788902 data:0x00000001
kworker/4:1-152 [004] ...1 365.570091: rtcpu_vinotify_handle_msg: tstamp:11723731870 tag:CHANSEL_PXL_EOF channel:0x00 frame:162 vi_tstamp:3133796870 data:0x0da70002
kworker/4:1-152 [004] ...1 365.570098: rtcpu_vinotify_handle_msg: tstamp:11723732434 tag:ISPBUF_FE channel:0x00 frame:162 vi_tstamp:3133797428 data:0x00000000
kworker/4:1-152 [004] ...1 365.570101: rtcpu_vinotify_handle_msg: tstamp:11724281538 tag:ISPBUF_FS channel:0x00 frame:163 vi_tstamp:3134346535 data:0x00000000
kworker/4:1-152 [004] ...1 365.570104: rtcpu_vinotify_handle_msg: tstamp:11724289254 tag:CHANSEL_PXL_SOF channel:0x00 frame:163 vi_tstamp:3134354264 data:0x00000001
kworker/4:1-152 [004] ...1 365.622072: rtos_queue_peek_from_isr_failed: tstamp:11724907816 queue:0x0b4a3c58
kworker/4:1-152 [004] ...1 365.622080: rtcpu_vinotify_handle_msg: tstamp:11725297235 tag:CHANSEL_PXL_EOF channel:0x00 frame:163 vi_tstamp:3135362234 data:0x0da70002
kworker/4:1-152 [004] ...1 365.622083: rtcpu_vinotify_handle_msg: tstamp:11725297801 tag:ISPBUF_FE channel:0x00 frame:163 vi_tstamp:3135362792 data:0x00000000
kworker/4:1-152 [004] ...1 365.622085: rtcpu_vinotify_handle_msg: tstamp:11725846912 tag:ISPBUF_FS channel:0x00 frame:164 vi_tstamp:3135911899 data:0x00000000
kworker/4:1-152 [004] ...1 365.622088: rtcpu_vinotify_handle_msg: tstamp:11725854618 tag:CHANSEL_PXL_SOF channel:0x00 frame:164 vi_tstamp:3135919628 data:0x00000001
kworker/4:1-152 [004] ...1 365.674066: rtcpu_vinotify_handle_msg: tstamp:11726862593 tag:CHANSEL_PXL_EOF channel:0x00 frame:164 vi_tstamp:3136927598 data:0x0da70002
kworker/4:1-152 [004] ...1 365.674072: rtcpu_vinotify_handle_msg: tstamp:11726863156 tag:ISPBUF_FE channel:0x00 frame:164 vi_tstamp:3136928156 data:0x00000000
kworker/4:1-152 [004] ...1 365.674075: rtcpu_vinotify_handle_msg: tstamp:11727412264 tag:ISPBUF_FS channel:0x00 frame:165 vi_tstamp:3137477263 data:0x00000000
kworker/4:1-152 [004] ...1 365.674078: rtcpu_vinotify_handle_msg: tstamp:11727419983 tag:CHANSEL_PXL_SOF channel:0x00 frame:165 vi_tstamp:3137484994 data:0x00000001
kworker/4:1-152 [004] ...1 365.726060: rtcpu_vinotify_handle_msg: tstamp:11728427955 tag:CHANSEL_PXL_EOF channel:0x00 frame:165 vi_tstamp:3138492962 data:0x0da70002
kworker/4:1-152 [004] ...1 365.726067: rtcpu_vinotify_handle_msg: tstamp:11728428528 tag:ISPBUF_FE channel:0x00 frame:165 vi_tstamp:3138493519 data:0x00000000
kworker/4:1-152 [004] ...1 365.726070: rtcpu_vinotify_handle_msg: tstamp:11728977630 tag:ISPBUF_FS channel:0x00 frame:166 vi_tstamp:3139042627 data:0x00000000
kworker/4:1-152 [004] ...1 365.726072: rtcpu_vinotify_handle_msg: tstamp:11728985346 tag:CHANSEL_PXL_SOF channel:0x00 frame:166 vi_tstamp:3139050357 data:0x00000001
kworker/4:1-152 [004] ...1 365.778074: rtos_queue_peek_from_isr_failed: tstamp:11729908337 queue:0x0b4a3c58
kworker/4:1-152 [004] ...1 365.778082: rtcpu_vinotify_handle_msg: tstamp:11729993323 tag:CHANSEL_PXL_EOF channel:0x00 frame:166 vi_tstamp:3140058325 data:0x0da70002
kworker/4:1-152 [004] ...1 365.778085: rtcpu_vinotify_handle_msg: tstamp:11729993882 tag:ISPBUF_FE channel:0x00 frame:166 vi_tstamp:3140058884 data:0x00000000
kworker/4:1-152 [004] ...1 365.778088: rtcpu_vinotify_handle_msg: tstamp:11730542991 tag:ISPBUF_FS channel:0x00 frame:167 vi_tstamp:3140607991 data:0x00000000
kworker/4:1-152 [004] ...1 365.778090: rtcpu_vinotify_handle_msg: tstamp:11730550711 tag:CHANSEL_PXL_SOF channel:0x00 frame:167 vi_tstamp:3140615720 data:0x00000001
kworker/4:1-152 [004] ...1 365.830066: rtcpu_vinotify_handle_msg: tstamp:11731558685 tag:CHANSEL_PXL_EOF channel:0x00 frame:167 vi_tstamp:3141623690 data:0x0da70002
kworker/4:1-152 [004] ...1 365.830073: rtcpu_vinotify_handle_msg: tstamp:11731559249 tag:ISPBUF_FE channel:0x00 frame:167 vi_tstamp:3141624247 data:0x00000000
kworker/4:1-152 [004] ...1 365.830076: rtcpu_vinotify_handle_msg: tstamp:11732108365 tag:ISPBUF_FS channel:0x00 frame:168 vi_tstamp:3142173355 data:0x00000000
kworker/4:1-152 [004] ...1 365.830078: rtcpu_vinotify_handle_msg: tstamp:11732116075 tag:CHANSEL_PXL_SOF channel:0x00 frame:168 vi_tstamp:3142181083 data:0x00000001
kworker/4:1-152 [004] ...1 365.882072: rtcpu_vinotify_handle_msg: tstamp:11733124050 tag:CHANSEL_PXL_EOF channel:0x00 frame:168 vi_tstamp:3143189053 data:0x0da70002
kworker/4:1-152 [004] ...1 365.882079: rtcpu_vinotify_handle_msg: tstamp:11733124614 tag:ISPBUF_FE channel:0x00 frame:168 vi_tstamp:3143189612 data:0x00000000
kworker/4:1-152 [004] ...1 365.882081: rtcpu_vinotify_handle_msg: tstamp:11733673736 tag:ISPBUF_FS channel:0x00 frame:169 vi_tstamp:3143738719 data:0x00000000
kworker/4:1-152 [004] ...1 365.882084: rtcpu_vinotify_handle_msg: tstamp:11733681442 tag:CHANSEL_PXL_SOF channel:0x00 frame:169 vi_tstamp:3143746449 data:0x00000001
kworker/4:1-152 [004] ...1 365.934065: rtcpu_vinotify_handle_msg: tstamp:11734689416 tag:CHANSEL_PXL_EOF channel:0x00 frame:169 vi_tstamp:3144754418 data:0x0da70002
kworker/4:1-152 [004] ...1 365.934072: rtcpu_vinotify_handle_msg: tstamp:11734689981 tag:ISPBUF_FE channel:0x00 frame:169 vi_tstamp:3144754975 data:0x00000000
kworker/4:1-152 [004] ...1 365.934077: rtos_queue_peek_from_isr_failed: tstamp:11734908827 queue:0x0b4a3c58
kworker/4:1-152 [004] ...1 365.934080: rtcpu_vinotify_handle_msg: tstamp:11735239080 tag:ISPBUF_FS channel:0x00 frame:170 vi_tstamp:3145304083 data:0x00000000
kworker/4:1-152 [004] ...1 365.934083: rtcpu_vinotify_handle_msg: tstamp:11735246802 tag:CHANSEL_PXL_SOF channel:0x00 frame:170 vi_tstamp:3145311812 data:0x00000001
kworker/4:1-152 [004] ...1 365.986064: rtcpu_vinotify_handle_msg: tstamp:11736254777 tag:CHANSEL_PXL_EOF channel:0x00 frame:170 vi_tstamp:3146319782 data:0x0da70002
kworker/4:1-152 [004] ...1 365.986071: rtcpu_vinotify_handle_msg: tstamp:11736255341 tag:ISPBUF_FE channel:0x00 frame:170 vi_tstamp:3146320339 data:0x00000000
kworker/4:1-152 [004] ...1 365.986073: rtcpu_vinotify_handle_msg: tstamp:11736804448 tag:ISPBUF_FS channel:0x00 frame:171 vi_tstamp:3146869446 data:0x00000000
kworker/4:1-152 [004] ...1 365.986076: rtcpu_vinotify_handle_msg: tstamp:11736812165 tag:CHANSEL_PXL_SOF channel:0x00 frame:171 vi_tstamp:3146877177 data:0x00000001
kworker/4:1-152 [004] ...1 366.038063: rtcpu_vinotify_handle_msg: tstamp:11737820140 tag:CHANSEL_PXL_EOF channel:0x00 frame:171 vi_tstamp:3147885145 data:0x0da70002
kworker/4:1-152 [004] ...1 366.038070: rtcpu_vinotify_handle_msg: tstamp:11737820702 tag:ISPBUF_FE channel:0x00 frame:171 vi_tstamp:3147885703 data:0x00000000
kworker/4:1-152 [004] ...1 366.038073: rtcpu_vinotify_handle_msg: tstamp:11738369814 tag:ISPBUF_FS channel:0x00 frame:172 vi_tstamp:3148434811 data:0x00000000
kworker/4:1-152 [004] ...1 366.038076: rtcpu_vinotify_handle_msg: tstamp:11738377532 tag:CHANSEL_PXL_SOF channel:0x00 frame:172 vi_tstamp:3148442539 data:0x00000001
kworker/4:1-152 [004] ...1 366.090079: rtcpu_vinotify_handle_msg: tstamp:11739385504 tag:CHANSEL_PXL_EOF channel:0x00 frame:172 vi_tstamp:3149450509 data:0x0da70002
kworker/4:1-152 [004] ...1 366.090088: rtcpu_vinotify_handle_msg: tstamp:11739386067 tag:ISPBUF_FE channel:0x00 frame:172 vi_tstamp:3149451067 data:0x00000000
kworker/4:1-152 [004] ...1 366.090094: rtos_queue_peek_from_isr_failed: tstamp:11739909337 queue:0x0b4a3c58
kworker/4:1-152 [004] ...1 366.090096: rtcpu_vinotify_handle_msg: tstamp:11739935163 tag:ISPBUF_FS channel:0x00 frame:173 vi_tstamp:3150000174 data:0x00000000
kworker/4:1-152 [004] ...1 366.090099: rtcpu_vinotify_handle_msg: tstamp:11739942900 tag:CHANSEL_PXL_SOF channel:0x00 frame:173 vi_tstamp:3150007905 data:0x00000001
kworker/4:1-152 [004] ...1 366.090102: rtcpu_vinotify_handle_msg: tstamp:11740950873 tag:CHANSEL_PXL_EOF channel:0x00 frame:173 vi_tstamp:3151015873 data:0x0da70002
kworker/4:1-152 [004] ...1 366.090104: rtcpu_vinotify_handle_msg: tstamp:11740951438 tag:ISPBUF_FE channel:0x00 frame:173 vi_tstamp:3151016430 data:0x00000000
kworker/4:1-152 [004] ...1 366.142087: rtcpu_vinotify_handle_msg: tstamp:11741500545 tag:ISPBUF_FS channel:0x00 frame:174 vi_tstamp:3151565538 data:0x00000000
kworker/4:1-152 [004] ...1 366.142094: rtcpu_vinotify_handle_msg: tstamp:11741508259 tag:CHANSEL_PXL_SOF channel:0x00 frame:174 vi_tstamp:3151573269 data:0x00000001
kworker/4:1-152 [004] ...1 366.142097: rtcpu_vinotify_handle_msg: tstamp:11742516231 tag:CHANSEL_PXL_EOF channel:0x00 frame:174 vi_tstamp:3152581236 data:0x0da70002
kworker/4:1-152 [004] ...1 366.142100: rtcpu_vinotify_handle_msg: tstamp:11742516791 tag:ISPBUF_FE channel:0x00 frame:174 vi_tstamp:3152581795 data:0x00000000
kworker/4:1-152 [004] ...1 366.194089: rtcpu_vinotify_handle_msg: tstamp:11743065914 tag:ISPBUF_FS channel:0x00 frame:175 vi_tstamp:3153130902 data:0x00000000
kworker/4:1-152 [004] ...1 366.194100: rtcpu_vinotify_handle_msg: tstamp:11743073620 tag:CHANSEL_PXL_SOF channel:0x00 frame:175 vi_tstamp:3153138631 data:0x00000001
kworker/4:1-152 [004] ...1 366.194103: rtcpu_vinotify_handle_msg: tstamp:11744081606 tag:CHANSEL_PXL_EOF channel:0x00 frame:175 vi_tstamp:3154146601 data:0x0da70002
kworker/4:1-152 [004] ...1 366.194105: rtcpu_vinotify_handle_msg: tstamp:11744082169 tag:ISPBUF_FE channel:0x00 frame:175 vi_tstamp:3154147158 data:0x00000000
Here is the output of DMESG at the point of failure.
[code]
[ 394.504413] misc tegra_camera_ctrl: ISO BW req 4761972 > 4500000 (max) capping to max
[ 568.472033] fence timeout on [ffffffc15e474500] after 1500ms
[ 568.472045] fence timeout on [ffffffc15e7b7200] after 1500ms
[ 568.472056] fence timeout on [ffffffc15e474700] after 1500ms
[ 568.472066] name=[nvhost_sync:63], current value=9271 waiting value=9272
[ 568.472085] name=[nvhost_sync:35], current value=9270 waiting value=9271
[ 568.472088] ---- mlocks ----
[ 568.472093] ---- mlocks ----
[ 568.472108] 8: locked by channel 6
[ 568.472111] 8: locked by channel 6
[ 568.472136] ---- syncpts ----
[ 568.472138] ---- syncpts ----
[ 568.472154] id 1 (disp_a) min 6 max 6 refs 1 (previous client : )
[ 568.472168] id 4 (disp_d) min 11662 max 11662 refs 1 (previous client : )
[ 568.472178] id 5 (disp_e) min 1 max 1 refs 1 (previous client : )
[ 568.472189] id 7 (vblank0) min 2796 max 0 refs 1 (previous client : )
[ 568.472201] id 9 (dsi) min 496 max 0 refs 1 (previous client : )
[ 568.472212] id 11 (vblank1) min 31559 max 0 refs 1 (previous client : )
[ 568.472236] id 21 (17000000.gp10b_507) min 115846 max 115846 refs 1 (previous client : )
[ 568.472247] id 22 (17000000.gp10b_506) min 192 max 192 refs 1 (previous client : )
[ 568.472259] id 23 (17000000.gp10b_505) min 60492 max 60492 refs 1 (previous client : 17000000.gp10b_505)
[ 568.472269] id 24 (17000000.gp10b_504) min 8 max 8 refs 1 (previous client : )
[ 568.472281] id 25 (17000000.gp10b_503) min 2686 max 2686 refs 1 (previous client : 17000000.gp10b_503)
[ 568.472293] id 28 (17000000.gp10b_502) min 14 max 14 refs 1 (previous client : )
[ 568.472304] id 29 (17000000.gp10b_501) min 7940 max 7940 refs 1 (previous client : )
[ 568.472314] id 30 (17000000.gp10b_500) min 36 max 36 refs 1 (previous client : 17000000.gp10b_500)
[ 568.472325] id 31 (17000000.gp10b_499) min 10820 max 10820 refs 1 (previous client : )
[ 568.472338] id 32 (15600000.isp_nvcamera-daemon_0) min 18640 max 18644 refs 4 (previous client : 17000000.gp10b_498)
[ 568.472349] id 33 (15600000.isp_nvcamera-daemon_1) min 9286 max 9288 refs 4 (previous client : 17000000.gp10b_497)
[ 568.472359] id 34 (15600000.isp_nvcamera-daemon_2) min 9270 max 9272 refs 4 (previous client : )
[ 568.472369] id 35 (15600000.isp_nvcamera-daemon_3) min 9270 max 9272 refs 4 (previous client : )
[ 568.472379] id 36 (15600000.isp_nvcamera-daemon_4) min 64907 max 64916 refs 8 (previous client : )
[ 568.472389] id 37 (15600000.isp_nvcamera-daemon_5) min 9271 max 9272 refs 4 (previous client : )
[ 568.472405] id 42 (17000000.gp10b_494) min 2 max 2 refs 1 (previous client : )
[ 568.472417] id 44 (15340000.vic_gst-launch-1.0_0) min 27798 max 27798 refs 1 (previous client : )
[ 568.472428] id 45 (17000000.gp10b_490) min 7 max 7 refs 1 (previous client : 15700000.vi_0)
[ 568.472440] id 47 (17000000.gp10b_488) min 2 max 2 refs 1 (previous client : 15700000.vi_1)
[ 568.472450] id 48 (17000000.gp10b_487) min 8 max 8 refs 1 (previous client : 15700000.vi_2)
[ 568.472460] id 49 (17000000.gp10b_486) min 16 max 16 refs 1 (previous client : 150c0000.nvcsi_0)
[ 568.472478] id 56 (17000000.gp10b_485) min 6 max 6 refs 1 (previous client : )
[ 568.472488] id 57 (17000000.gp10b_484) min 6 max 6 refs 1 (previous client : )
[ 568.472497] id 58 (17000000.gp10b_483) min 6 max 6 refs 1 (previous client : )
[ 568.472506] id 59 (17000000.gp10b_482) min 6 max 6 refs 1 (previous client : )
[ 568.472515] id 60 (17000000.gp10b_481) min 6 max 6 refs 1 (previous client : )
[ 568.472524] id 61 (15700000.vi_0) min 7 max 7 refs 2 (previous client : )
[ 568.472534] id 62 (15700000.vi_0) min 9367 max 9368 refs 4 (previous client : )
[ 568.472544] id 63 (15700000.vi_1) min 9271 max 9272 refs 4 (previous client : )
[ 568.472554] id 64 (15700000.vi_2) min 9270 max 9272 refs 4 (previous client : )
[ 568.472563] id 65 (150c0000.nvcsi_0) min 20 max 20 refs 2 (previous client : )
[ 568.473265] ---- channels ----
[ 568.473272] id 1 (disp_a) min 6 max 6 refs 1 (previous client : )
[ 568.473288] id 4 (disp_d) min 11662 max 11662 refs 1 (previous client : )
[ 568.473291]
channel 1 - 15820000.se
[ 568.473297] NvHost basic channel registers:
[ 568.473300] id 5 (disp_e) min 1 max 1 refs 1 (previous client : )
[ 568.473305] CMDFIFO_STAT_0: 00002040
[ 568.473311] CMDFIFO_RDATA_0: 0194451b
[ 568.473314] id 7 (vblank0) min 2796 max 0 refs 1 (previous client : )
[ 568.473320] CMDP_OFFSET_0: 00000000
[ 568.473326] id 9 (dsi) min 496 max 0 refs 1 (previous client : )
[ 568.473328] CMDP_CLASS_0: 00000000
[ 568.473334] CHANNELSTAT_0: 00000000
[ 568.473338] id 11 (vblank1) min 31559 max 0 refs 1 (previous client : )
[ 568.473340] The CDMA sync queue is empty.
[ 568.473354]
channel 2 - 15830000.se
[ 568.473358] NvHost basic channel registers:
[ 568.473361] id 21 (17000000.gp10b_507) min 115846 max 115846 refs 1 (previous client : )
[ 568.473364] CMDFIFO_STAT_0: 00002040
[ 568.473370] CMDFIFO_RDATA_0: 92cc3ca0
[ 568.473373] id 22 (17000000.gp10b_506) min 192 max 192 refs 1 (previous client : )
[ 568.473378] CMDP_OFFSET_0: 00000000
[ 568.473383] CMDP_CLASS_0: 00000000
[ 568.473386] id 23 (17000000.gp10b_505) min 60492 max 60492 refs 1 (previous client : 17000000.gp10b_505)
[ 568.473388] CHANNELSTAT_0: 00000000
[ 568.473393] The CDMA sync queue is empty.
[ 568.473397] id 24 (17000000.gp10b_504) min 8 max 8 refs 1 (previous client : )
[ 568.473407]
channel 3 - 15840000.se
[ 568.473410] id 25 (17000000.gp10b_503) min 2686 max 2686 refs 1 (previous client : 17000000.gp10b_503)
[ 568.473413] NvHost basic channel registers:
[ 568.473419] CMDFIFO_STAT_0: 00002040
[ 568.473423] id 28 (17000000.gp10b_502) min 14 max 14 refs 1 (previous client : )
[ 568.473425] CMDFIFO_RDATA_0: 01005142
[ 568.473434] id 29 (17000000.gp10b_501) min 7940 max 7940 refs 1 (previous client : )
[ 568.473436] CMDP_OFFSET_0: 00000000
[ 568.473442] CMDP_CLASS_0: 00000000
[ 568.473445] id 30 (17000000.gp10b_500) min 36 max 36 refs 1 (previous client : 17000000.gp10b_500)
[ 568.473448] CHANNELSTAT_0: 00000000
[ 568.473452] The CDMA sync queue is empty.
[ 568.473458] id 31 (17000000.gp10b_499) min 10820 max 10820 refs 1 (previous client : )
[ 568.473464]
channel 6 - 15600000.isp
[ 568.473469] NvHost basic channel registers:
[ 568.473472] id 32 (15600000.isp_nvcamera-daemon_0) min 18640 max 18644 refs 4 (previous client : 17000000.gp10b_498)
[ 568.473474] CMDFIFO_STAT_0: 00004000
[ 568.473480] CMDFIFO_RDATA_0: 004e0041
[ 568.473484] id 33 (15600000.isp_nvcamera-daemon_1) min 9286 max 9288 refs 4 (previous client : 17000000.gp10b_497)
[ 568.473488] CMDP_OFFSET_0: 00000050
[ 568.473493] CMDP_CLASS_0: 00000001
[ 568.473496] id 34 (15600000.isp_nvcamera-daemon_2) min 9270 max 9272 refs 4 (previous client : )
[ 568.473498] CHANNELSTAT_0: 00000000
[ 568.473507] id 35 (15600000.isp_nvcamera-daemon_3) min 9270 max 9272 refs 4 (previous client : )
[ 568.473515]
ffffffc15e7f4c00: JOB, syncpt_id=32, syncpt_val=18642, first_get=000004f0, timeout=10000, num_slots=19
[ 568.473517] id 36 (15600000.isp_nvcamera-daemon_4) min 64907 max 64916 refs 8 (previous client : )
[ 568.473527] id 37 (15600000.isp_nvcamera-daemon_5) min 9271 max 9272 refs 4 (previous client : )
[ 568.473536] GATHER at 5a708000+3c2c, 12 words
[ 568.473546] 20000001
[ 568.473547] id 42 (17000000.gp10b_494) min 2 max 2 refs 1 (previous client : )
[ 568.473560] 00006420 20000001 00006821
[ 568.473561] id 44 (15340000.vic_gst-launch-1.0_0) min 27798 max 27798 refs 1 (previous client : )
[ 568.473573] 20000001 00006c22 20000001
[ 568.473574] id 45 (17000000.gp10b_490) min 7 max 7 refs 1 (previous client : 15700000.vi_0)
[ 568.473586] 00007c23 20000001 00007425
[ 568.473587] id 47 (17000000.gp10b_488) min 2 max 2 refs 1 (previous client : 15700000.vi_1)
[ 568.473596] 200c0001 00000005
[ 568.473599] id 48 (17000000.gp10b_487) min 8 max 8 refs 1 (previous client : 15700000.vi_2)
[ 568.473608] GATHER at 5a708000+3c5c, 2 words
[ 568.473610] id 49 (17000000.gp10b_486) min 16 max 16 refs 1 (previous client : 150c0000.nvcsi_0)
[ 568.473619] 20000001 00000024
[ 568.473629] id 56 (17000000.gp10b_485) min 6 max 6 refs 1 (previous client : )
[ 568.473632]
channel 5 - 150c0000.nvcsi
[ 568.473637] NvHost basic channel registers:
[ 568.473639] id 57 (17000000.gp10b_484) min 6 max 6 refs 1 (previous client : )
[ 568.473643] CMDFIFO_STAT_0: 00002040
[ 568.473649] id 58 (17000000.gp10b_483) min 6 max 6 refs 1 (previous client : )
[ 568.473651] CMDFIFO_RDATA_0: 00000041
[ 568.473658] id 59 (17000000.gp10b_482) min 6 max 6 refs 1 (previous client : )
[ 568.473660] CMDP_OFFSET_0: 00000000
[ 568.473666] CMDP_CLASS_0: 00000001
[ 568.473668] id 60 (17000000.gp10b_481) min 6 max 6 refs 1 (previous client : )
[ 568.473671] CHANNELSTAT_0: 00000000
[ 568.473675] The CDMA sync queue is empty.
[ 568.473678] id 61 (15700000.vi_0) min 7 max 7 refs 2 (previous client : )
[ 568.473688] id 62 (15700000.vi_0) min 9367 max 9368 refs 4 (previous client : )
[ 568.473690]
channel 0 - 15700000.vi
[ 568.473694] NvHost basic channel registers:
[ 568.473698] id 63 (15700000.vi_1) min 9271 max 9272 refs 4 (previous client : )
[ 568.473701] CMDFIFO_STAT_0: 00002040
[ 568.473706] CMDFIFO_RDATA_0: 0000003d
[ 568.473709] id 64 (15700000.vi_2) min 9270 max 9272 refs 4 (previous client : )
[ 568.473713] CMDP_OFFSET_0: 00000000
[ 568.473718] id 65 (150c0000.nvcsi_0) min 20 max 20 refs 2 (previous client : )
[ 568.473720] CMDP_CLASS_0: 00000001
[ 568.473725] CHANNELSTAT_0: 00000000
[ 568.473730] The CDMA sync queue is empty.
[ 568.473738]
channel 4 - 15700000.vi
[ 568.473742] NvHost basic channel registers:
[ 568.473747] CMDFIFO_STAT_0: 0000001f
[ 568.473753] CMDFIFO_RDATA_0: 304e0005
[ 568.473760] CMDP_OFFSET_0: 00000050
[ 568.473765] CMDP_CLASS_0: 00000001
[ 568.473770] CHANNELSTAT_0: 00000000
[ 568.473784]
ffffffc15e7a4c00: JOB, syncpt_id=64, syncpt_val=9271, first_get=00000328, timeout=0, num_slots=6
[ 568.473799] GATHER at 5a718000+1d2c, 6 words
[ 568.473823] 304e0005 0000fd8b 00000024 304e0005 00002436 0000003f
[ 568.473832] GATHER at 5a718000+1d44, 26 words
[ 568.473918] 90000001 a0000401 00000000 90000001 a000404d 00000001 90000001 a0004020 00000000 90000003 a0004042 5a536000 00000000 00000001 90000001 a0004048 00000000 90000001 a000400a 00000000 90000001 a0004001 00000001 90000001 a0004007 00000003
[ 568.473926] GATHER at 5a718000+1dac, 2 words
[ 568.473936] 20000001 0000003e
[ 568.473947]
---- host general irq ----
[ 568.473954] sync_intc0mask = 0x00000001
[ 568.473960] sync_intmask = 0x50000003
[ 568.473964]
---- host syncpt irq mask ----
[ 568.473969]
---- host syncpt irq status ----
[ 568.473977] syncpt_thresh_cpu0_int_status(0) = 0x00000000
[ 568.473984] syncpt_thresh_cpu0_int_status(1) = 0x00000000
[ 568.473991] syncpt_thresh_cpu0_int_status(2) = 0x00000000
[ 568.473997] syncpt_thresh_cpu0_int_status(3) = 0x00000000
[ 568.474003] syncpt_thresh_cpu0_int_status(4) = 0x00000000
[ 568.474009] syncpt_thresh_cpu0_int_status(5) = 0x00000000
[ 568.474015] syncpt_thresh_cpu0_int_status(6) = 0x00000000
[ 568.474021] syncpt_thresh_cpu0_int_status(7) = 0x00000000
[ 568.474027] syncpt_thresh_cpu0_int_status(8) = 0x00000000
[ 568.474033] syncpt_thresh_cpu0_int_status(9) = 0x00000000
[ 568.474040] syncpt_thresh_cpu0_int_status(10) = 0x00000000
[ 568.474047] syncpt_thresh_cpu0_int_status(11) = 0x00000000
[ 568.474053] syncpt_thresh_cpu0_int_status(12) = 0x00000000
[ 568.474060] syncpt_thresh_cpu0_int_status(13) = 0x00000000
[ 568.474066] syncpt_thresh_cpu0_int_status(14) = 0x00000000
[ 568.474072] syncpt_thresh_cpu0_int_status(15) = 0x00000000
[ 568.474078] syncpt_thresh_cpu0_int_status(16) = 0x00000000
[ 568.474085] syncpt_thresh_cpu0_int_status(17) = 0x00000000
[ 568.474428] ---- channels ----
[ 568.474463]
[ 568.474468] NvHost basic channel registers:
[ 568.474477] CMDFIFO_STAT_0: 00002040
[ 568.474484] CMDFIFO_RDATA_0: 0194451b
[ 568.474493] CMDP_OFFSET_0: 00000000
[ 568.474499] CMDP_CLASS_0: 00000000
[ 568.474505] CHANNELSTAT_0: 00000000
[ 568.474510] The CDMA sync queue is empty.
[ 568.474525]
[ 568.474529] NvHost basic channel registers:
[ 568.474535] CMDFIFO_STAT_0: 00002040
[ 568.474541] CMDFIFO_RDATA_0: 92cc3ca0
[ 568.474549] CMDP_OFFSET_0: 00000000
[ 568.474554] CMDP_CLASS_0: 00000000
[ 568.474560] CHANNELSTAT_0: 00000000
[ 568.474564] The CDMA sync queue is empty.
[ 568.474579]
[ 568.474583] NvHost basic channel registers:
[ 568.474588] CMDFIFO_STAT_0: 00002040
[ 568.474594] CMDFIFO_RDATA_0: 01005142
[ 568.474601] CMDP_OFFSET_0: 00000000
[ 568.474606] CMDP_CLASS_0: 00000000
[ 568.474612] CHANNELSTAT_0: 00000000
[ 568.474616] The CDMA sync queue is empty.
[ 568.474629]
[ 568.474633] NvHost basic channel registers:
[ 568.474639] CMDFIFO_STAT_0: 00004000
[ 568.474645] CMDFIFO_RDATA_0: 004e0041
[ 568.474653] CMDP_OFFSET_0: 00000050
[ 568.474658] CMDP_CLASS_0: 00000001
[ 568.474664] CHANNELSTAT_0: 00000000
[ 568.474698]
[ 568.474711] GATHER at 5a708000+3c2c, 12 words
[ 568.474759] 20000001 00006420 20000001 00006821 20000001 00006c22 20000001 00007c23 20000001 00007425 200c0001 00000005
[ 568.474770] GATHER at 5a708000+3c5c, 2 words
[ 568.474782] 20000001 00000024
[ 568.474796]
[ 568.474800] NvHost basic channel registers:
[ 568.474806] CMDFIFO_STAT_0: 00002040
[ 568.474812] CMDFIFO_RDATA_0: 00000041
[ 568.474820] CMDP_OFFSET_0: 00000000
[ 568.474825] CMDP_CLASS_0: 00000001
[ 568.474830] CHANNELSTAT_0: 00000000
[ 568.474834] The CDMA sync queue is empty.
[ 568.474845]
[ 568.474849] NvHost basic channel registers:
[ 568.474854] CMDFIFO_STAT_0: 00002040
[ 568.474860] CMDFIFO_RDATA_0: 0000003d
[ 568.474867] CMDP_OFFSET_0: 00000000
[ 568.474872] CMDP_CLASS_0: 00000001
[ 568.474877] CHANNELSTAT_0: 00000000
[ 568.474881] The CDMA sync queue is empty.
[ 568.474889]
[ 568.474892] NvHost basic channel registers:
[ 568.474898] CMDFIFO_STAT_0: 0000001f
[ 568.474903] CMDFIFO_RDATA_0: 304e0005
[ 568.474910] CMDP_OFFSET_0: 00000050
[ 568.474915] CMDP_CLASS_0: 00000001
[ 568.474920] CHANNELSTAT_0: 00000000
[ 568.474935]
[ 568.474944] GATHER at 5a718000+1d2c, 6 words
[ 568.474969] 304e0005 0000fd8b 00000024 304e0005 00002436 0000003f
[ 568.474977] GATHER at 5a718000+1d44, 26 words
[ 568.475064] 90000001 a0000401 00000000 90000001 a000404d 00000001 90000001 a0004020 00000000 90000003 a0004042 5a536000 00000000 00000001 90000001 a0004048 00000000 90000001 a000400a 00000000 90000001 a0004001 00000001 90000001 a0004007 00000003
[ 568.475072] GATHER at 5a718000+1dac, 2 words
[ 568.475083] 20000001 0000003e
[ 568.475094]
[ 568.475101] sync_intc0mask = 0x00000001
[ 568.475107] sync_intmask = 0x50000003
[ 568.475111]
[ 568.475115]
[ 568.475123] syncpt_thresh_cpu0_int_status(0) = 0x00000000
[ 568.475130] syncpt_thresh_cpu0_int_status(1) = 0x00000000
[ 568.475136] syncpt_thresh_cpu0_int_status(2) = 0x00000000
[ 568.475143] syncpt_thresh_cpu0_int_status(3) = 0x00000000
[ 568.475149] syncpt_thresh_cpu0_int_status(4) = 0x00000000
[ 568.475155] syncpt_thresh_cpu0_int_status(5) = 0x00000000
[ 568.475161] syncpt_thresh_cpu0_int_status(6) = 0x00000000
[ 568.475167] syncpt_thresh_cpu0_int_status(7) = 0x00000000
[ 568.475173] syncpt_thresh_cpu0_int_status(8) = 0x00000000
[ 568.475179] syncpt_thresh_cpu0_int_status(9) = 0x00000000
[ 568.475186] syncpt_thresh_cpu0_int_status(10) = 0x00000000
[ 568.475192] syncpt_thresh_cpu0_int_status(11) = 0x00000000
[ 568.475199] syncpt_thresh_cpu0_int_status(12) = 0x00000000
[ 568.475205] syncpt_thresh_cpu0_int_status(13) = 0x00000000
[ 568.475211] syncpt_thresh_cpu0_int_status(14) = 0x00000000
[ 568.475217] syncpt_thresh_cpu0_int_status(15) = 0x00000000
[ 568.475224] syncpt_thresh_cpu0_int_status(16) = 0x00000000
[ 568.475230] syncpt_thresh_cpu0_int_status(17) = 0x00000000
[ 570.024380] name=[nvhost_sync:32], current value=18640 waiting value=18641
[ 570.031365] ---- mlocks ----
[ 570.034431] 8: locked by channel 6
[ 570.039382] ---- syncpts ----
[ 570.042500] id 1 (disp_a) min 6 max 6 refs 1 (previous client : )
[ 570.048659] id 4 (disp_d) min 11664 max 11664 refs 1 (previous client : )
[ 570.055491] id 5 (disp_e) min 1 max 1 refs 1 (previous client : )
[ 570.061693] id 7 (vblank0) min 2796 max 0 refs 1 (previous client : )
[ 570.068164] id 9 (dsi) min 496 max 0 refs 1 (previous client : )
[ 570.074235] id 11 (vblank1) min 31655 max 0 refs 1 (previous client : )
[ 570.080943] id 21 (17000000.gp10b_507) min 115862 max 115862 refs 1 (previous client : )
[ 570.089074] id 22 (17000000.gp10b_506) min 192 max 192 refs 1 (previous client : )
[ 570.096704] id 23 (17000000.gp10b_505) min 60502 max 60502 refs 1 (previous client : 17000000.gp10b_505)
[ 570.106212] id 24 (17000000.gp10b_504) min 8 max 8 refs 1 (previous client : )
[ 570.113501] id 25 (17000000.gp10b_503) min 2686 max 2686 refs 1 (previous client : 17000000.gp10b_503)
[ 570.122821] id 28 (17000000.gp10b_502) min 14 max 14 refs 1 (previous client : )
[ 570.130285] id 29 (17000000.gp10b_501) min 7940 max 7940 refs 1 (previous client : )
[ 570.138044] id 30 (17000000.gp10b_500) min 36 max 36 refs 1 (previous client : 17000000.gp10b_500)
[ 570.147051] id 31 (17000000.gp10b_499) min 10820 max 10820 refs 1 (previous client : )
[ 570.154966] id 32 (15600000.isp_nvcamera-daemon_0) min 18640 max 18644 refs 4 (previous client : 17000000.gp10b_498)
[ 570.165521] id 33 (15600000.isp_nvcamera-daemon_1) min 9286 max 9288 refs 4 (previous client : 17000000.gp10b_497)
[ 570.175900] id 34 (15600000.isp_nvcamera-daemon_2) min 9270 max 9272 refs 4 (previous client : )
[ 570.184680] id 35 (15600000.isp_nvcamera-daemon_3) min 9270 max 9272 refs 4 (previous client : )
[ 570.193500] id 36 (15600000.isp_nvcamera-daemon_4) min 64907 max 64916 refs 8 (previous client : )
[ 570.202455] id 37 (15600000.isp_nvcamera-daemon_5) min 9271 max 9272 refs 4 (previous client : )
[ 570.211278] id 42 (17000000.gp10b_494) min 2 max 2 refs 1 (previous client : )
[ 570.218500] id 44 (15340000.vic_gst-launch-1.0_0) min 27804 max 27804 refs 1 (previous client : )
[ 570.227404] id 45 (17000000.gp10b_490) min 7 max 7 refs 1 (previous client : 15700000.vi_0)
[ 570.235753] id 47 (17000000.gp10b_488) min 2 max 2 refs 1 (previous client : 15700000.vi_1)
[ 570.244138] id 48 (17000000.gp10b_487) min 8 max 8 refs 1 (previous client : 15700000.vi_2)
[ 570.252486] id 49 (17000000.gp10b_486) min 16 max 16 refs 1 (previous client : 150c0000.nvcsi_0)
[ 570.261309] id 56 (17000000.gp10b_485) min 6 max 6 refs 1 (previous client : )
[ 570.268530] id 57 (17000000.gp10b_484) min 6 max 6 refs 1 (previous client : )
[ 570.275793] id 58 (17000000.gp10b_483) min 6 max 6 refs 1 (previous client : )
[ 570.283014] id 59 (17000000.gp10b_482) min 6 max 6 refs 1 (previous client : )
[ 570.290234] id 60 (17000000.gp10b_481) min 6 max 6 refs 1 (previous client : )
[ 570.297494] id 61 (15700000.vi_0) min 7 max 7 refs 2 (previous client : )
[ 570.304279] id 62 (15700000.vi_0) min 9367 max 9368 refs 4 (previous client : )
[ 570.311629] id 63 (15700000.vi_1) min 9271 max 9272 refs 4 (previous client : )
[ 570.318937] id 64 (15700000.vi_2) min 9270 max 9272 refs 4 (previous client : )
[ 570.326287] id 65 (150c0000.nvcsi_0) min 20 max 20 refs 2 (previous client : )
[ 570.335484] ---- channels ----
[ 570.338550]
[ 570.345029] NvHost basic channel registers:
[ 570.349215] CMDFIFO_STAT_0: 00002040
[ 570.352879] CMDFIFO_RDATA_0: 0194451b
[ 570.356547] CMDP_OFFSET_0: 00000000
[ 570.360250] CMDP_CLASS_0: 00000000
[ 570.363904] CHANNELSTAT_0: 00000000
[ 570.367571] The CDMA sync queue is empty.
[ 570.373078]
[ 570.379556] NvHost basic channel registers:
[ 570.383743] CMDFIFO_STAT_0: 00002040
[ 570.387406] CMDFIFO_RDATA_0: 92cc3ca0
[ 570.391073] CMDP_OFFSET_0: 00000000
[ 570.394777] CMDP_CLASS_0: 00000000
[ 570.398445] CHANNELSTAT_0: 00000000
[ 570.402108] The CDMA sync queue is empty.
[ 570.407617]
[ 570.414150] NvHost basic channel registers:
[ 570.418700] CMDFIFO_STAT_0: 00002040
[ 570.422447] CMDFIFO_RDATA_0: 01005142
[ 570.426195] CMDP_OFFSET_0: 00000000
[ 570.429949] CMDP_CLASS_0: 00000000
[ 570.433669] CHANNELSTAT_0: 00000000
[ 570.437378] The CDMA sync queue is empty.
[ 570.442933]
[ 570.449560] NvHost basic channel registers:
[ 570.453774] CMDFIFO_STAT_0: 00004000
[ 570.457463] CMDFIFO_RDATA_0: 004e0041
[ 570.461149] CMDP_OFFSET_0: 00000050
[ 570.464843] CMDP_CLASS_0: 00000001
[ 570.468525] CHANNELSTAT_0: 00000000
[ 570.472219]
[ 570.484055] GATHER at 5a708000+3c2c, 12 words
[ 570.488809] 20000001 00006420 20000001 00006821 20000001 00006c22 20000001 00007c23 20000001 00007425 200c0001 00000005
[ 570.499848] GATHER at 5a708000+3c5c, 2 words
[ 570.504479] 20000001 00000024
[ 570.509096]
[ 570.515841] NvHost basic channel registers:
[ 570.520052] CMDFIFO_STAT_0: 00002040
[ 570.523710] CMDFIFO_RDATA_0: 00000041
[ 570.527394] CMDP_OFFSET_0: 00000000
[ 570.531095] CMDP_CLASS_0: 00000001
[ 570.534780] CHANNELSTAT_0: 00000000
[ 570.538468] The CDMA sync queue is empty.
[ 570.544035]
[ 570.550493] NvHost basic channel registers:
[ 570.554702] CMDFIFO_STAT_0: 00002040
[ 570.558386] CMDFIFO_RDATA_0: 0000003d
[ 570.562079] CMDP_OFFSET_0: 00000000
[ 570.565762] CMDP_CLASS_0: 00000001
[ 570.569452] CHANNELSTAT_0: 00000000
[ 570.573135] The CDMA sync queue is empty.
[ 570.578688]
[ 570.585145] NvHost basic channel registers:
[ 570.589355] CMDFIFO_STAT_0: 0000001f
[ 570.593040] CMDFIFO_RDATA_0: 304e0005
[ 570.596731] CMDP_OFFSET_0: 00000050
[ 570.600413] CMDP_CLASS_0: 00000001
[ 570.604103] CHANNELSTAT_0: 00000000
[ 570.607765]
[ 570.619077] GATHER at 5a718000+1d2c, 6 words
[ 570.623719] 304e0005 0000fd8b 00000024 304e0005 00002436 0000003f
[ 570.630009] GATHER at 5a718000+1d44, 26 words
[ 570.634729] 90000001 a0000401 00000000 90000001 a000404d 00000001 90000001 a0004020 00000000 90000003 a0004042 5a536000 00000000 00000001 90000001 a0004048 00000000 90000001 a000400a 00000000 90000001 a0004001 00000001 90000001 a0004007 00000003
[ 570.656918] GATHER at 5a718000+1dac, 2 words
[ 570.661565] 20000001 0000003e
[ 570.666158]
[ 570.672903] sync_intc0mask = 0x00000001
[ 570.676764] sync_intmask = 0x50000003
[ 570.680457]
[ 570.687524]
[ 570.694780] syncpt_thresh_cpu0_int_status(0) = 0x00000000
[ 570.700202] syncpt_thresh_cpu0_int_status(1) = 0x00000000
[ 570.705628] syncpt_thresh_cpu0_int_status(2) = 0x00000000
[ 570.711043] syncpt_thresh_cpu0_int_status(3) = 0x00000000
[ 570.716470] syncpt_thresh_cpu0_int_status(4) = 0x00000000
[ 570.721891] syncpt_thresh_cpu0_int_status(5) = 0x00000000
[ 570.727316] syncpt_thresh_cpu0_int_status(6) = 0x00000000
[ 570.732733] syncpt_thresh_cpu0_int_status(7) = 0x00000000
[ 570.738157] syncpt_thresh_cpu0_int_status(8) = 0x00000000
[ 570.743573] syncpt_thresh_cpu0_int_status(9) = 0x00000000
[ 570.748994] syncpt_thresh_cpu0_int_status(10) = 0x00000000
[ 570.754495] syncpt_thresh_cpu0_int_status(11) = 0x00000000
[ 570.760003] syncpt_thresh_cpu0_int_status(12) = 0x00000000
[ 570.765510] syncpt_thresh_cpu0_int_status(13) = 0x00000000
[ 570.771046] syncpt_thresh_cpu0_int_status(14) = 0x00000000
[ 570.776612] syncpt_thresh_cpu0_int_status(15) = 0x00000000
[ 570.782134] syncpt_thresh_cpu0_int_status(16) = 0x00000000
[ 570.787642] syncpt_thresh_cpu0_int_status(17) = 0x00000000
[ 572.972131] host1x 13e10000.host1x: CaptureSchedule: syncpoint id 36 (15600000.isp_nvcamera-daemon_4) stuck waiting 64908, timeout=-1
[ 572.984290] ---- syncpts ----
[ 572.987284] id 1 (disp_a) min 6 max 6 refs 1 (previous client : )
[ 572.993630] id 4 (disp_d) min 11666 max 11666 refs 1 (previous client : )
[ 573.000512] id 5 (disp_e) min 1 max 1 refs 1 (previous client : )
[ 573.006722] id 7 (vblank0) min 2796 max 0 refs 1 (previous client : )
[ 573.013290] id 9 (dsi) min 496 max 0 refs 1 (previous client : )
[ 573.019395] id 11 (vblank1) min 31832 max 0 refs 1 (previous client : )
[ 573.026137] id 21 (17000000.gp10b_507) min 115870 max 115870 refs 1 (previous client : )
[ 573.034274] id 22 (17000000.gp10b_506) min 192 max 192 refs 1 (previous client : )
[ 573.041949] id 23 (17000000.gp10b_505) min 60512 max 60512 refs 1 (previous client : 17000000.gp10b_505)
[ 573.051475] id 24 (17000000.gp10b_504) min 8 max 8 refs 1 (previous client : )
[ 573.058778] id 25 (17000000.gp10b_503) min 2686 max 2686 refs 1 (previous client : 17000000.gp10b_503)
[ 573.068114] id 28 (17000000.gp10b_502) min 14 max 14 refs 1 (previous client : )
[ 573.075580] id 29 (17000000.gp10b_501) min 7940 max 7940 refs 1 (previous client : )
[ 573.083342] id 30 (17000000.gp10b_500) min 36 max 36 refs 1 (previous client : 17000000.gp10b_500)
[ 573.092366] id 31 (17000000.gp10b_499) min 10820 max 10820 refs 1 (previous client : )
[ 573.100289] id 32 (15600000.isp_nvcamera-daemon_0) min 18640 max 18644 refs 4 (previous client : 17000000.gp10b_498)
[ 573.110872] id 33 (15600000.isp_nvcamera-daemon_1) min 9286 max 9288 refs 4 (previous client : 17000000.gp10b_497)
[ 573.121232] id 34 (15600000.isp_nvcamera-daemon_2) min 9270 max 9272 refs 4 (previous client : )
[ 573.130088] id 35 (15600000.isp_nvcamera-daemon_3) min 9270 max 9272 refs 4 (previous client : )
[ 573.138892] id 36 (15600000.isp_nvcamera-daemon_4) min 64907 max 64916 refs 8 (previous client : )
[ 573.147889] id 37 (15600000.isp_nvcamera-daemon_5) min 9271 max 9272 refs 4 (previous client : )
[ 573.156680] id 42 (17000000.gp10b_494) min 2 max 2 refs 1 (previous client : )
[ 573.163943] id 44 (15340000.vic_gst-launch-1.0_0) min 27804 max 27804 refs 1 (previous client : )
[ 573.172815] id 45 (17000000.gp10b_490) min 7 max 7 refs 1 (previous client : 15700000.vi_0)
[ 573.181267] id 47 (17000000.gp10b_488) min 2 max 2 refs 1 (previous client : 15700000.vi_1)
[ 573.189857] id 48 (17000000.gp10b_487) min 8 max 8 refs 1 (previous client : 15700000.vi_2)
[ 573.198297] id 49 (17000000.gp10b_486) min 16 max 16 refs 1 (previous client : 150c0000.nvcsi_0)
[ 573.207150] id 56 (17000000.gp10b_485) min 6 max 6 refs 1 (previous client : )
[ 573.214423] id 57 (17000000.gp10b_484) min 6 max 6 refs 1 (previous client : )
[ 573.221700] id 58 (17000000.gp10b_483) min 6 max 6 refs 1 (previous client : )
[ 573.228987] id 59 (17000000.gp10b_482) min 6 max 6 refs 1 (previous client : )
[ 573.236253] id 60 (17000000.gp10b_481) min 6 max 6 refs 1 (previous client : )
[ 573.243533] id 61 (15700000.vi_0) min 7 max 7 refs 2 (previous client : )
[ 573.250344] id 62 (15700000.vi_0) min 9367 max 9368 refs 4 (previous client : )
[ 573.257677] id 63 (15700000.vi_1) min 9271 max 9272 refs 4 (previous client : )
[ 573.265004] id 64 (15700000.vi_2) min 9270 max 9272 refs 4 (previous client : )
[ 573.272336] id 65 (150c0000.nvcsi_0) min 20 max 20 refs 2 (previous client : )
[ 576.980196] host1x 13e10000.host1x: cdma_handle_timeout: timeout: 32 (15600000.isp_nvcamera-daemon_0) clientid 1, HW thresh 18640, done 18642
[ 576.992991] host1x 13e10000.host1x: cdma_handle_timeout: timeout: 33 (15600000.isp_nvcamera-daemon_1) clientid 1, HW thresh 9286, done 9287
[ 577.005600] host1x 13e10000.host1x: cdma_handle_timeout: timeout: 34 (15600000.isp_nvcamera-daemon_2) clientid 1, HW thresh 9270, done 9271
[ 577.018289] host1x 13e10000.host1x: cdma_handle_timeout: timeout: 35 (15600000.isp_nvcamera-daemon_3) clientid 1, HW thresh 9270, done 9271
[ 577.030901] host1x 13e10000.host1x: cdma_handle_timeout: timeout: 37 (15600000.isp_nvcamera-daemon_5) clientid 1, HW thresh 9271, done 9271
[ 577.043518] host1x 13e10000.host1x: cdma_handle_timeout: timeout: 36 (15600000.isp_nvcamera-daemon_4) clientid 1, HW thresh 64907, done 64907
[ 577.056293] ---- mlocks ----
[ 577.059196] 8: locked by channel 6
[ 577.064222] ---- syncpts ----
[ 577.067221] id 1 (disp_a) min 6 max 6 refs 1 (previous client : )
[ 577.073365] id 4 (disp_d) min 11666 max 11666 refs 1 (previous client : )
[ 577.080247] id 5 (disp_e) min 1 max 1 refs 1 (previous client : )
[ 577.086359] id 7 (vblank0) min 2796 max 0 refs 1 (previous client : )
[ 577.092864] id 9 (dsi) min 496 max 0 refs 1 (previous client : )
[ 577.098892] id 11 (vblank1) min 32077 max 0 refs 1 (previous client : )
[ 577.105543] id 21 (17000000.gp10b_507) min 115870 max 115870 refs 1 (previous client : )
[ 577.113683] id 22 (17000000.gp10b_506) min 192 max 192 refs 1 (previous client : )
[ 577.121298] id 23 (17000000.gp10b_505) min 60512 max 60512 refs 1 (previous client : 17000000.gp10b_505)
[ 577.130822] id 24 (17000000.gp10b_504) min 8 max 8 refs 1 (previous client : )
[ 577.138081] id 25 (17000000.gp10b_503) min 2686 max 2686 refs 1 (previous client : 17000000.gp10b_503)
[ 577.147575] id 28 (17000000.gp10b_502) min 14 max 14 refs 1 (previous client : )
[ 577.155136] id 29 (17000000.gp10b_501) min 7940 max 7940 refs 1 (previous client : )
[ 577.162943] id 30 (17000000.gp10b_500) min 36 max 36 refs 1 (previous client : 17000000.gp10b_500)
[ 577.172072] id 31 (17000000.gp10b_499) min 10820 max 10820 refs 1 (previous client : )
[ 577.180267] id 32 (15600000.isp_nvcamera-daemon_0) min 18640 max 18644 refs 4 (previous client : 17000000.gp10b_498)
[ 577.190822] id 33 (15600000.isp_nvcamera-daemon_1) min 9286 max 9288 refs 4 (previous client : 17000000.gp10b_497)
[ 577.201181] id 34 (15600000.isp_nvcamera-daemon_2) min 9270 max 9272 refs 4 (previous client : )
[ 577.210015] id 35 (15600000.isp_nvcamera-daemon_3) min 9270 max 9272 refs 4 (previous client : )
[ 577.218810] id 36 (15600000.isp_nvcamera-daemon_4) min 64907 max 64916 refs 8 (previous client : )
[ 577.227776] id 37 (15600000.isp_nvcamera-daemon_5) min 9271 max 9272 refs 4 (previous client : )
[ 577.236596] id 42 (17000000.gp10b_494) min 2 max 2 refs 1 (previous client : )
[ 577.243839] id 44 (15340000.vic_gst-launch-1.0_0) min 27804 max 27804 refs 1 (previous client : )
[ 577.253868] id 45 (17000000.gp10b_490) min 7 max 7 refs 1 (previous client : 15700000.vi_0)
[ 577.262374] id 47 (17000000.gp10b_488) min 2 max 2 refs 1 (previous client : 15700000.vi_1)
[ 577.270770] id 48 (17000000.gp10b_487) min 8 max 8 refs 1 (previous client : 15700000.vi_2)
[ 577.279248] id 49 (17000000.gp10b_486) min 16 max 16 refs 1 (previous client : 150c0000.nvcsi_0)
[ 577.288046] id 56 (17000000.gp10b_485) min 6 max 6 refs 1 (previous client : )
[ 577.295280] id 57 (17000000.gp10b_484) min 6 max 6 refs 1 (previous client : )
[ 577.302508] id 58 (17000000.gp10b_483) min 6 max 6 refs 1 (previous client : )
[ 577.309736] id 59 (17000000.gp10b_482) min 6 max 6 refs 1 (previous client : )
[ 577.316964] id 60 (17000000.gp10b_481) min 6 max 6 refs 1 (previous client : )
[ 577.324185] id 61 (15700000.vi_0) min 7 max 7 refs 2 (previous client : )
[ 577.330978] id 62 (15700000.vi_0) min 9367 max 9368 refs 4 (previous client : )
[ 577.338328] id 63 (15700000.vi_1) min 9271 max 9272 refs 4 (previous client : )
[ 577.345644] id 64 (15700000.vi_2) min 9270 max 9272 refs 4 (previous client : )
[ 577.352951] id 65 (150c0000.nvcsi_0) min 20 max 20 refs 2 (previous client : )
[ 577.362163] ---- channels ----
[ 577.365243]
[ 577.371770] NvHost basic channel registers:
[ 577.375971] CMDFIFO_STAT_0: 00002040
[ 577.379647] CMDFIFO_RDATA_0: 0194451b
[ 577.383325] CMDP_OFFSET_0: 00000000
[ 577.387001] CMDP_CLASS_0: 00000000
[ 577.390670] CHANNELSTAT_0: 00000000
[ 577.394341] The CDMA sync queue is empty.
[ 577.399842]
[ 577.406324] NvHost basic channel registers:
[ 577.410521] CMDFIFO_STAT_0: 00002040
[ 577.414196] CMDFIFO_RDATA_0: 92cc3ca0
[ 577.417875] CMDP_OFFSET_0: 00000000
[ 577.421569] CMDP_CLASS_0: 00000000
[ 577.425259] CHANNELSTAT_0: 00000000
[ 577.428960] The CDMA sync queue is empty.
[ 577.434460]
[ 577.441077] NvHost basic channel registers:
[ 577.445271] CMDFIFO_STAT_0: 00002040
[ 577.448938] CMDFIFO_RDATA_0: 01005142
[ 577.452610] CMDP_OFFSET_0: 00000000
[ 577.456278] CMDP_CLASS_0: 00000000
[ 577.459934] CHANNELSTAT_0: 00000000
[ 577.463601] The CDMA sync queue is empty.
[ 577.469157]
[ 577.475687] NvHost basic channel registers:
[ 577.479876] CMDFIFO_STAT_0: 00004000
[ 577.483542] CMDFIFO_RDATA_0: 004e0041
[ 577.487213] CMDP_OFFSET_0: 00000050
[ 577.490887] CMDP_CLASS_0: 00000001
[ 577.494573] CHANNELSTAT_0: 00000000
[ 577.498247]
[ 577.5
