Using DINO model trained on TAO in DeepStream 6.0.1 and Jetson TX2
Description
Hello everyone. I’m having an issue to deploy DINO model on DeepStream 6.0.1. I am using deepstream-app with my configuration file to deploy the model. I trained the model on TAO and exported the onnx file with it. Everything works fine on my Desktop with an RTX 4070 but I’m trying make some inference tests on a Jetson TX2. On Jetson TX2 I’ m getting the following error:
Using winsys: x11
0:00:00.517462695 16896     0x1f8de0d0 INFO                 nvinfer gstnvinfer.cpp:638:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1914> [UID = 1]: Trying to create engine from model files
WARNING: [TRT]: onnx2trt_utils.cpp:366: Your ONNX model has been generated with INT64 weights, while TensorRT does not natively support INT64. Attempting to cast down to INT32.
WARNING: [TRT]: onnx2trt_utils.cpp:392: One or more weights outside the range of INT32 was clamped
WARNING: [TRT]: onnx2trt_utils.cpp:505: Your ONNX model has been generated with double-typed weights, while TensorRT does not natively support double. Attempting to cast down to float.
WARNING: [TRT]: ShapedWeights.cpp:173: Weights /model/backbone/backbone.0/body/patch_embed/conv_down/conv/conv.2/fc/fc.0/Transpose_output_0 has been transposed with permutation of (1, 0)! If you plan on overwriting the weights with the Refitter API, the new weights must be pre-transposed.
WARNING: [TRT]: ShapedWeights.cpp:173: Weights /model/backbone/backbone.0/body/patch_embed/conv_down/conv/conv.2/fc/fc.2/Transpose_output_0 has been transposed with permutation of (1, 0)! If you plan on overwriting the weights with the Refitter API, the new weights must be pre-transposed.
ERROR: [TRT]: ModelImporter.cpp:773: While parsing node number 79 [Mod -> "/model/backbone/backbone.0/body/levels.0/blocks.0/Mod_output_0"]:
ERROR: [TRT]: ModelImporter.cpp:774: --- Begin node ---
ERROR: [TRT]: ModelImporter.cpp:775: input: "/model/backbone/backbone.0/body/levels.0/blocks.0/Gather_1_output_0"
input: "/model/backbone/backbone.0/body/levels.0/blocks.0/Constant_4_output_0"
output: "/model/backbone/backbone.0/body/levels.0/blocks.0/Mod_output_0"
op_type: "Mod"
attribute {
  i: 0
  type: INT
ERROR: [TRT]: ModelImporter.cpp:776: --- End node ---
ERROR: [TRT]: ModelImporter.cpp:779: ERROR: builtin_op_importers.cpp:4870 In function importFallbackPluginImporter:
[8] Assertion failed: creator && "Plugin not found, are the plugin name, version, and namespace correct?"
ERROR: Failed to parse onnx file
ERROR: failed to build network since parsing model errors.
ERROR: failed to build network.
0:00:05.042142292 16896     0x1f8de0d0 ERROR                nvinfer gstnvinfer.cpp:632:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1934> [UID = 1]: build engine file failed
0:00:05.043127053 16896     0x1f8de0d0 ERROR                nvinfer gstnvinfer.cpp:632:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2020> [UID = 1]: build backend context failed
0:00:05.043173804 16896     0x1f8de0d0 ERROR                nvinfer gstnvinfer.cpp:632:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::initialize() <nvdsinfer_context_impl.cpp:1257> [UID = 1]: generate backend failed, check config file settings
0:00:05.043534730 16896     0x1f8de0d0 WARN                 nvinfer gstnvinfer.cpp:841:gst_nvinfer_start:<primary_gie> error: Failed to create NvDsInferContext instance
I tried to compile TensorRT OSS following the deploy tutorial in here. in the tutorial the cloned version is 21.03, but I couldn’t compile this version. I was only able to compile TensorRT OSS on branches release/8.0 and release/8.2. Then I replaced the libnvinfer_plugin but it led me to the same error above.
Is there anything I can do to run DINO on the TX2 with DeepStream ?
Environment
TensorRT Version: 8.2.1.9
GPU Type: Jetson TX2
JetPack Version: 4.6.4
CUDA Version: 10.2.300
CUDNN Version: 8.2.1.32
Operating System + Version: ubuntu 18.04 L4T - 32.7.4
Relevant Files
This is my config file:
[property]
gpu-id=0
offsets=123.675;116.28;103.53
net-scale-factor=0.0173520735728
labelfile-path=/home/itv-tx2/CodeWorkspace/deepstream-mestrado/labels-multi.txt
onnx-file=/home/itv-tx2/CodeWorkspace/deepstream-mestrado/model-multiclass.onnx
# model-engine-file=/home/fred/CodeWorkspace/deepstream-mestrado/model-multiclass.onnx_b1_gpu0_fp16.engine
batch-size=1
## 0=FP32, 1=INT8, 2=FP16 mode
network-mode=2
num-detected-classes=8
interval=0
gie-unique-id=1
output-blob-names=pred_boxes;pred_logits
infer-dims=3;544;960
cluster-mode=4
parse-bbox-func-name=NvDsInferParseCustomDDETRTAO
custom-lib-path=libnvds_infercustomparser_tao.so
[class-attrs-all]
pre-cluster-threshold=0.5
topk=300
Is the problem solved now?
TRT is part of Jetpack, so I think you don’t have to compile tensorrt by yourself if the Jetpack is installed properly.
DS-6.0.1 only support TRT 8.2.1
https://docs.nvidia.com/metropolis/deepstream/6.0.1/dev-guide/text/DS_Quickstart.html#platform-and-os-compatibility
This issue seems to be caused by the lack of operators in the trt.
Hello, @junshengy! Thank you for your reply!
I could not solve this problem, I tried to compile TensorRT in other versions to check whether these newer versions have the missing operators in TRT. On my dGPU environment, I got the TRT 8.5 version and DINO works fine, but DeepStream is also on a newer version (6.2).
So I’m assuming DINO won’t work on Jetson TX2, right ? Because the max version of DS the TX2 supports is 6.0.1. Can you confirm for me or is there another subtopic in this forum where I could get this information?
I think so. Perhaps adding the missing operators to TRT-8.2 can solve the problem, but there is no such solution at present.
