On our custom carrier board, DP0 port is set as HDMI and I try to use this as HDMI. I used tegra186-quill-p3310-1000-c03-00-dsi-hdmi-hdmi.dts and tegra186-quill-p3310-1000-c03-00-dsi-hdmi-dp.dts but there is not a progress. Linux cannot get EDID data from monitor.
dmesg output:
[ 8.677728] tegradc 15210000.nvdisplay: unblank
[ 8.677740] PD DISP0 index2 UP
[ 8.679407] PD DISP1 index3 UP
[ 8.679696] PD DISP2 index4 UP
[ 8.685530] Parent Clock set for DC plld2
[ 8.691062] edid invalid
[ 8.692961] edid invalid
[ 8.693065] edid invalid
[ 8.693149] tegradc 15210000.nvdisplay: hdmi: pclk:25200K, set prod-setting:prod_c_54M
[ 8.697190] scsi 2:0:0:0: Direct-Access SanDisk Ultra Fit 1.00 PQ: 0 ANSI: 6
[ 8.697898] sd 2:0:0:0: [sda] 60062500 512-byte logical blocks: (30.8 GB/28.6 GiB)
[ 8.699301] sd 2:0:0:0: [sda] Write Protect is off
[ 8.699305] sd 2:0:0:0: [sda] Mode Sense: 43 00 00 00
[ 8.700084] sd 2:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[ 8.707782] sda: sda1
[ 8.710147] sd 2:0:0:0: [sda] Attached SCSI removable disk
[ 8.884310] tegra-i2c 3190000.i2c: rx dma timeout txlen:28 rxlen:128
[ 8.884317] tegra-i2c 3190000.i2c: --- register dump for debugging ----
[ 8.884327] tegra-i2c 3190000.i2c: I2C_CNFG - 0x22c00
[ 8.884333] tegra-i2c 3190000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
[ 8.884339] tegra-i2c 3190000.i2c: I2C_FIFO_CONTROL - 0x1c
[ 8.884345] tegra-i2c 3190000.i2c: I2C_FIFO_STATUS - 0x800040
[ 8.884398] tegra-i2c 3190000.i2c: I2C_INT_MASK - 0x6c
[ 8.884408] tegra-i2c 3190000.i2c: I2C_INT_STATUS - 0x2
[ 8.884455] tegra-i2c 3190000.i2c: i2c transfer timed out addr: 0x50
You can also find full dmesg output attached.
I also changed tegra186-quill-p3310-1000-c03-00-dsi-hdmi-hdmi.dts with below parameters but had no effect.
//Enable Display Port
host1x {
//(HEADs)
nvdisplay@15200000 {
//Display Controller 0
status = "disabled";
//Specify where to send the output of this display controller
nvidia,dc-or-node = "/host1x/dsi";
nvdisplay@15210000 {
//Display Controller 1
status = "okay";
nvidia,dc-or-node = "/host1x/sor1";
nvdisplay@15220000 {
//Display Controller 2
status = "okay";
nvidia,dc-or-node = "/host1x/sor";
//Output Resources
sor {
//Serial Output Resource 0
status = "okay";
dp-display {
hdmi-display {
status = "okay";
panel-s-edp-uhdtv-15-6 {
smartdimmer {
dpaux@155c0000 {
//Display Port Aux For Channel 0 (Coupled with SOR0)
sor1 {
//Serial Output Resource 1
status = "okay";
dp-display {
//bootloader-status = "disabled";
hdmi-display {
status = "okay";
dsi@153000000 {
//Display Port Aux For Channel 1 (Coupled with SOR1)
dpaux@15040000 {
status = "okay";
//bootloader-status = "okay";
dmesg.txt (126 KB)
