Is there any problem to understand that “follow the nvme guidance but change the device node name to your sdcard node”?
It feels like you are not able to understand this comment during the whole discussion.
before putting rootfs on sdcard
I am testing it on usbtosata ssd.
Thank you.
You can try that * Flashing to a USB Drive section…
Actually they are doing almost the same things as nvme drive… but just replace the nvme node to usb device…
Is it normal for rootfs to appear under /media/?
manager@manager-desktop:~$ df -h
Filesystem Size Used Avail Use% Mounted on
/dev/mmcblk0p1 14G 4.9G 8.2G 37% /
none 1.7G 0 1.7G 0% /dev
tmpfs 2.0G 4.0K 2.0G 1% /dev/shm
tmpfs 2.0G 20M 2.0G 1% /run
tmpfs 5.0M 4.0K 5.0M 1% /run/lock
tmpfs 2.0G 0 2.0G 0% /sys/fs/cgroup
tmpfs 396M 12K 396M 1% /run/user/120
/dev/sda1 458G 4.7G 430G 2% /media/307497f5-9d3a-4024-b244-fcccd47d8414
tmpfs 396M 0 396M 0% /run/user/1000
Thank you very much.
That is the mount point… It does not matter.
