• Hardware Platform (Jetson / GPU) GPU
• DeepStream Version 6.0 (nvcr.io/nvidia/deepstream:6.0-devel)
Hi, I have a problem with GStreamer application written in C++.
I developed the app which runs custom analytic plugins on multiple RTSP streams.
The application is building the pipeline using rtspsrc
, uridecodebin
and nvvideoconvert
as a group of plugins before passing the data to nvstreammux
- next, there are a few analytic plugins and output.
The configuration works fine if the app is outputting video on the screen - only for debugging purposes.
I need to run it on a server without a display. So, I ran into problems - I cut off the part of the pipeline responsible for outputting video and replaced it with a fakesink
element. Then a strange thing happened:
None of the RTSP sources was able to connect. The same sources work fine when displaying on screen.
And there are the GStremer logs about the error:
0:00:01.530929294 5481 0x5629a6ad40a0 ERROR default gstrtspconnection.c:1004:gst_rtsp_connection_connect_with_response: failed to connect: Operation was cancelled
0:00:01.530942068 5481 0x5629a6ad40a0 ERROR rtspsrc gstrtspsrc.c:4702:gst_rtsp_conninfo_connect:<rtspsrc0> Could not connect to server. (Generic error)
0:00:01.530947899 5481 0x5629a6ad40a0 WARN rtspsrc gstrtspsrc.c:7469:gst_rtspsrc_retrieve_sdp:<rtspsrc0> error: Failed to connect. (Generic error)
0:00:01.530958100 5481 0x5629a6ad40a0 INFO GST_ERROR_SYSTEM gstelement.c:2145:gst_element_message_full_with_details:<rtspsrc0> posting message: Could not open resource for reading and writing.
0:00:01.530979254 5481 0x5629a6ad40a0 INFO GST_ERROR_SYSTEM gstelement.c:2172:gst_element_message_full_with_details:<rtspsrc0> posted error message: Could not open resource for reading and writing.
0:00:01.530991258 5481 0x5629a6ad40a0 WARN rtspsrc gstrtspsrc.c:7548:gst_rtspsrc_open:<rtspsrc0> can't get sdp
0:00:01.531004587 5481 0x5629a6ad40a0 INFO task gsttask.c:316:gst_task_func:<task0> Task going to paused
I was able to run the pipeline by changing the rtsp reading part (rtspsrc -> decodebin
to uridecodebin
), but it has a huge drawback for me - after changing the stream reading is not smooth anymore.
Could you help me, how could I run the app without display and keeping the pipeline with rtspsrc
and decodebin
