I am trying to run a FLIR boson using Deepstream. The camera is able to run with the ‘NV12’ format, however the camera applies gain in this format. The 'Y16 ’ format is the raw format.
When setting up config file with the resolution for 'Y16 ', the pipeline errors out. Any insight on how I can get deepstream to process 'Y16 ’ pixel format would be helpful.
The possible formats are GRAY16_LE and GRAY16_BE. May give it a try and check if it works. Since DeepStream SDK is based on gstreamer, would need to find out a working pipeline. The format is special and it probably is not supported in v4l2src yet.
