Sometimes I see curious things, like a variable turning into a pointer…
Are they being passed as an argument in a subroutine? Fortran defaults to passing by reference which gdb may show as a pointer.
or a Boolean being some large number instead of .true. or .false.
LOGICAL can be represented as an integer where 0 is false and non-zero is true. This might be what you’re seeing.
And if I don’t use -g to compile, gdb still seems to think it can debug with source, even though it does not work.
Yes, you can debug applications that are not compiled with -g. Granted, the dwarf symbols wont be there so it may not be too useful, but it’s possible. It can be useful when trying to get a traceback from a binary without needing to recompile with dwarf generation enabled.
Note that PGI will include a minimal amount of dwarf info in the binary, mostly used for profiling, so some symbols may be there, but just not as complete as if you were to add -g.
OK, thank you. I did not consider the idea of a subroutine argument looking like a pointer in the gdb
I got thrown off a little with the .true. and .false. because at times I would see just that, and other times a non zero number, though I guess it was working as it should.
