I successfully compiled the latest gstreamer version 1.17.1 using gst-build repo.
What I did then:
copied the compiled nvidia plugins to the build folder: cp /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnv* /home/jetson/gst-build/build/subprojects/nvidia/gst/
exported this folder so the gstreamer would pick them up successfully: export GST_PLUGIN_PATH=/home/jetson/gst-build/build/subprojects/nvidia/gst:$GST_PLUGIN_PATH
but when running my pipeline I see the error described in this issue that was fixed in 1.17 version, and I can see that when not using any nvidia plugin, the error does not appear.
One maintainer of gstreamer mentioned the nvidia plugins might be linking to wrong so files, but I can’t seem to debug this on my own, can you please help or provide fresh compiled plugins for the latest gstreamer version?
More debug lines:
[gst-master] jetson@xavier:~/gst-build$ ldd /home/jetson/gst-build/build/subprojects/nvidia/gst/libgstnvarguscamerasrc.so |grep gst
libgstbase-1.0.so.0 => /home/jetson/gst-build/build/subprojects/gstreamer/libs/gst/base/libgstbase-1.0.so.0 (0x0000007f9c6a9000)
libgstreamer-1.0.so.0 => /home/jetson/gst-build/build/subprojects/gstreamer/gst/libgstreamer-1.0.so.0 (0x0000007f9c566000)
libgstvideo-1.0.so.0 => /home/jetson/gst-build/build/subprojects/gst-plugins-base/gst-libs/gst/video/libgstvideo-1.0.so.0 (0x0000007f9c4b6000)
liborc-0.4.so.0 => /home/jetson/gst-build/build/subprojects/orc/orc/liborc-0.4.so.0 (0x0000007f9bdb8000)
[gst-master] jetson@xavier:~/gst-build$ ldd /home/jetson/gst-build/build/subprojects/nvidia/gst/libgstnvvideo4linux2.so |grep gst
libgstallocators-1.0.so.0 => /home/jetson/gst-build/build/subprojects/gst-plugins-base/gst-libs/gst/allocators/libgstallocators-1.0.so.0 (0x0000007f9c518000)
libgstreamer-1.0.so.0 => /home/jetson/gst-build/build/subprojects/gstreamer/gst/libgstreamer-1.0.so.0 (0x0000007f9c3d5000)
libgstvideo-1.0.so.0 => /home/jetson/gst-build/build/subprojects/gst-plugins-base/gst-libs/gst/video/libgstvideo-1.0.so.0 (0x0000007f9c325000)
libgstbase-1.0.so.0 => /home/jetson/gst-build/build/subprojects/gstreamer/libs/gst/base/libgstbase-1.0.so.0 (0x0000007f9be00000)
liborc-0.4.so.0 => /home/jetson/gst-build/build/subprojects/orc/orc/liborc-0.4.so.0 (0x0000007f9bd87000)
[gst-master] jetson@xavier:~/gst-build$ ldd /usr/lib/aarch64-linux-gnu/tegra/libnvdsbufferpool.so.1.0.0 |grep gst
libgstreamer-1.0.so.0 => /home/jetson/gst-build/build/subprojects/gstreamer/gst/libgstreamer-1.0.so.0 (0x0000007f7ec00000)
libgstvideo-1.0.so.0 => /home/jetson/gst-build/build/subprojects/gst-plugins-base/gst-libs/gst/video/libgstvideo-1.0.so.0 (0x0000007f7e9b1000)
libgstbase-1.0.so.0 => /home/jetson/gst-build/build/subprojects/gstreamer/libs/gst/base/libgstbase-1.0.so.0 (0x0000007f7e5bb000)
liborc-0.4.so.0 => /home/jetson/gst-build/build/subprojects/orc/orc/liborc-0.4.so.0 (0x0000007f7e542000)
[gst-master] jetson@xavier:~$ gst-launch-1.0 --version
gst-launch-1.0 version 1.17.1
GStreamer 1.17.1 (GIT)
Unknown package origin
(python3:9099): GStreamer-CRITICAL **: 17:09:48.277: gst_buffer_resize_range: assertion 'bufmax >= bufoffs + offset + size' failed
0:00:11.153302337 9099 0x35533b20 WARN v4l2src gstv4l2src.c:1000:gst_v4l2src_create:<v4l2src0> lost frames detected: count = 1 - ts: 0:00:00.543372695
(python3:9099): GStreamer-CRITICAL **: 17:09:48.283: gst_buffer_resize_range: assertion 'bufmax >= bufoffs + offset + size' failed
0:00:11.174094664 9099 0x35534540 WARN v4l2bufferpool gstv4l2bufferpool.c:1535:gst_v4l2_buffer_pool_dqbuf:<nvv4l2h264enc0:pool:src> Driver should never set v4l2_buffer.field to ANY
(python3:9099): GStreamer-CRITICAL **: 17:09:48.332: gst_buffer_resize_range: assertion 'bufmax >= bufoffs + offset + size' failed
0:00:11.208306680 9099 0x35533b20 WARN v4l2bufferpool gstv4l2bufferpool.c:1480:gst_v4l2_buffer_pool_dqbuf:<nvv4l2h264enc0:pool:sink> V4L2 provided buffer has bytesused 0 which is too small to include data_offset 0
0:00:11.208371257 9099 0x35533b20 WARN v4l2bufferpool gstv4l2bufferpool.c:1480:gst_v4l2_buffer_pool_dqbuf:<nvv4l2h264enc0:pool:sink> V4L2 provided buffer has bytesused 0 which is too small to include data_offset 0
0:00:11.208417306 9099 0x35533b20 WARN v4l2bufferpool gstv4l2bufferpool.c:1480:gst_v4l2_buffer_pool_dqbuf:<nvv4l2h264enc0:pool:sink> V4L2 provided buffer has bytesused 0 which is too small to include data_offset 0
We would suggest use default gstreamer 1.14.5, since NVIDIA plugins are built with this version and SQA tests are performed. Upgrading to later version may not work since the deviation in header file probably causes unknown issues.
We have build instrunctions in development guide. Please take a look and see if it helps your case.
The latest bug-fix release in the 1.14 series is 1.14.5 and was released on 29 May 2019.
This release is very old and webrtc plugin we need in our project does not work with that version, we’re not doing it just for fun…
So can you please change your strict policy about your product and either offer the plugin sources (which is impossible, I know) or provide compiled binaries for all new versions, since gstreamer is officially supported.
Thanks for the suggestion. We will check and evaluate the upgrade. Since this task requires certain engineering and SQA efforts to ensure NVIDIA plugins can work fine on new gstreamer release, we would need some time. Please note this. Thanks.
I also want to mention Ubuntu 20.04 has gstreamer 1.16.2 in the repo already, so making the plugins compatible would allow a very nice upgrade path for L4T in this use-case.
PS: Is it true that nvarguscamerasrc plugin sources are publicly available? Can you provide us the link?
I was able to compile both libgstnvarguscamerasrc.so and libgstnvvideo4linux2.so but this error is still there:
(gst-launch-1.0:12967): GStreamer-CRITICAL **: 19:06:45.684: gst_buffer_resize_range: assertion 'bufmax >= bufoffs + offset + size' failed
Thread 6 "v4l2src0:src" received signal SIGTRAP, Trace/breakpoint trap.
[Switching to Thread 0x7fb24f61e0 (LWP 12974)]
raise (sig=<optimized out>) at ../sysdeps/unix/sysv/linux/raise.c:50
50 ../sysdeps/unix/sysv/linux/raise.c: No such file or directory.
(gdb) info stack
#0 raise (sig=<optimized out>) at ../sysdeps/unix/sysv/linux/raise.c:50
#1 0x0000007fb7d66980 in g_logv () at /usr/lib/aarch64-linux-gnu/libglib-2.0.so.0
#2 0x0000007fb7d66b50 in g_log () at /usr/lib/aarch64-linux-gnu/libglib-2.0.so.0
#3 0x0000007fb7e8891c in gst_buffer_resize_range () at /usr/lib/aarch64-linux-gnu/libgstreamer-1.0.so.0
#4 0x0000007fb7e8c1fc in () at /usr/lib/aarch64-linux-gnu/libgstreamer-1.0.so.0
#5 0x0000007fb7e8dfc8 in gst_buffer_pool_release_buffer () at /usr/lib/aarch64-linux-gnu/libgstreamer-1.0.so.0
#6 0x0000007fb7e86198 in () at /usr/lib/aarch64-linux-gnu/libgstreamer-1.0.so.0
#7 0x0000007fb7ec25a0 in gst_mini_object_unref () at /usr/lib/aarch64-linux-gnu/libgstreamer-1.0.so.0
#8 0x0000007fb2e8d2ac in gst_buffer_unref () at /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvvideo4linux2.so
#9 0x0000007fb2e93690 in gst_v4l2_buffer_pool_process () at /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvvideo4linux2.so
#10 0x0000007fb2e9ea68 in gst_v4l2_video_enc_handle_frame () at /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstnvvideo4linux2.so
#11 0x0000007fb70924bc in () at /usr/lib/aarch64-linux-gnu/libgstvideo-1.0.so.0
#12 0x0000007fb7ec6208 in () at /usr/lib/aarch64-linux-gnu/libgstreamer-1.0.so.0
#13 0x0000007fb7ec7e10 in () at /usr/lib/aarch64-linux-gnu/libgstreamer-1.0.so.0
#14 0x0000007fb7ecf374 in gst_pad_push () at /usr/lib/aarch64-linux-gnu/libgstreamer-1.0.so.0
#15 0x0000007fb6ff72d4 in () at /usr/lib/aarch64-linux-gnu/libgstbase-1.0.so.0
#16 0x0000007fb7ec6208 in () at /usr/lib/aarch64-linux-gnu/libgstreamer-1.0.so.0
#17 0x0000007fb7ec7e10 in () at /usr/lib/aarch64-linux-gnu/libgstreamer-1.0.so.0
#18 0x0000007fb7ecf374 in gst_pad_push () at /usr/lib/aarch64-linux-gnu/libgstreamer-1.0.so.0
#19 0x0000007fb7fb7648 in () at /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstvideorate.so
#20 0x0000007fb6ff78c4 in () at /usr/lib/aarch64-linux-gnu/libgstbase-1.0.so.0
#21 0x0000007fb6ff71cc in () at /usr/lib/aarch64-linux-gnu/libgstbase-1.0.so.0
#22 0x0000007fb7ec6208 in () at /usr/lib/aarch64-linux-gnu/libgstreamer-1.0.so.0
#23 0x0000007fb7ec7e10 in () at /usr/lib/aarch64-linux-gnu/libgstreamer-1.0.so.0
#24 0x0000007fb7ecf374 in gst_pad_push () at /usr/lib/aarch64-linux-gnu/libgstreamer-1.0.so.0
#25 0x0000007fb6ff72d4 in () at /usr/lib/aarch64-linux-gnu/libgstbase-1.0.so.0
#26 0x0000007fb7ec6208 in () at /usr/lib/aarch64-linux-gnu/libgstreamer-1.0.so.0
#27 0x0000007fb7ec7e10 in () at /usr/lib/aarch64-linux-gnu/libgstreamer-1.0.so.0
#28 0x0000007fb7ecf374 in gst_pad_push () at /usr/lib/aarch64-linux-gnu/libgstreamer-1.0.so.0
#29 0x0000007fb6ff2cf4 in () at /usr/lib/aarch64-linux-gnu/libgstbase-1.0.so.0
#30 0x0000007fb7f016fc in () at /usr/lib/aarch64-linux-gnu/libgstreamer-1.0.so.0
#31 0x0000007fb7d898f8 in () at /usr/lib/aarch64-linux-gnu/libglib-2.0.so.0
#32 0x0000007fb7d88f64 in () at /usr/lib/aarch64-linux-gnu/libglib-2.0.so.0
#33 0x0000007fb7c744fc in start_thread (arg=0x7fffffdedf) at pthread_create.c:477
#34 0x0000007fb7bcef2c in thread_start () at ../sysdeps/unix/sysv/linux/aarch64/clone.S:78
(gdb)
Can it be that the error is hard-linked in libnvdsbufferpool.so? Is this one open source too?
@DaneLLL According to the GStreamer maintainers as per the link shared above there is a bug in libgstnvvideo4linux2. Could you confirm if there is the intention to fix it?
We don’t actually have clear steps to reproduce the error. If you can reproduce it on r32.4.3(Jetpack4.4), please share the steps so that we can do further check.
