Using HPC-X on Cray Slingshot
I am trying to run my code on the Delta-AI system at NCSA.
I can run the code on up to all 4 GH200 GPUs on a single node, but when I try to run across multiple nodes, I get a series of UCX errors (“connection refused”).
I have tried numerous environment variable to no avail.
The system admins have told me they do not think that the nvhpc compiler that I installed locally from nvidia has built-in support for the slingshot network.
Is this correct? Is there some special ENV variables I can set to have the HPC-X in 24.11 work on a Cray Slingshot network?
– Ron
Hi Ron,
I double checked with some folks, but confirmed that the HPC-X we ship is only available for Mellanox interconnects. You or the NCSA folks will need to see if they can build you a NVHPC enabled MPI that works with Slingshoot.
-Mat
Thanks for the info!
How does it work on a local system or within a node?
– Ron
The interconnect is only needed when going across the network.
