How does one use the I2C pins on the camera port?
I can use the I2C on the gpio via Python no problem, but how do I access them on the camera port?
Hello, GinDiamond:
Would you please give some details about your issues?
camera sensor attached to i2c bus can work.
br
ChenJian
The problem here is that I can’t get any CSI-2 camera other than the one supplied with the TX1 to work. I can’t set it up using I2C from the camera port, and I can’t get an image from it if I set it up using the J21 I2C port.
Can any other camera sensor other than the one supplied with the TX1 board work?
The onboard camera is the only camera that is supported on the TX1 at this time.
