Using IDictionary100 times - not in my code?
Continuing the discussion from Resolve "omni.usfphysicui.plugin":
 [Warning] [carb] Client omni.kit.viewport.legacy_gizmos has acquired [carb::dictionary::IDictionary v1.1] 100 times. Consider accessing this interface with carb::getCachedInterface() (Performance warning)
[Warning] [omni.hydratexture.plugin] '/Render/OmniverseKit/HydraTextures/omni_kit_widget_viewport_ViewportTexture_0' is not a Usd.RenderProduct and cannot be used, reseting to '/Render/OmniverseKit/HydraTextures/omni_kit_widget_viewport_ViewportTexture_0'
[Warning] [carb] Client omni.hydratexture.plugin has acquired [carb::dictionary::IDictionary v1.1] 100 times. Consider accessing this interface with carb::getCachedInterface() (Performance warning)
[Warning] [omni.hydra] Mesh '/World/robot/mir/MIR250/Body/Body' has corrupted data in primvar 'st': buffer size 4882428 doesn't match expected size 15416772 in faceVarying primvars
Using:
Isaac Sim 4.2.0-rc.17
Kit SDK 106.1.0
Client Library: 2.49.29
Let me know if you need a minimal script of my extension.
Are you experiencing any functional issues or limitations due to this warning? If so, could you please provide a minimal script or example that reproduces the issue? This will help us better understand the context and offer more targeted assistance. Additionally, knowing whether this is affecting performance or causing any specific errors would be helpful in diagnosing the problem. Thank you!
