Using IMX135
I am trying to use imx135_v4l2 driver. To do so, I made the necessary modifications in kernel and flash the board. I install the imx135_v4l2 driver and then what I need to do, should I install tegra_camera if so when I install the tegra_camera it automatically installs the ov5693_v4l2.ko and it does not use imx135_v4l2? Also at which point does it should create /dev/video0 file?
Redundant post, it’s under discussed at https://devtalk.nvidia.com/default/topic/961156/imx135-on-tx1/
