• Hardware Platform Jetson
• DeepStream Version 5.0
• JetPack Version (valid for Jetson only) 4.4
Hi, so we have deployed the tlt peoplenet model on a site with 11 cameras and it is running a bit slow. We have played with lowering the resolution of the cameras, decreasing the fps to 8-10, setting the interval in pgie config. Obviously the greater the interval there is a decrease in the accuracy we observed above 2. Our next steps is to look into using int8 and dla as we are using the Xavier.
So, how do we create an int8-calibration file for the PeopleNet tlt model? Then i know you can specify enable-dla and that in config for deepstream app but how do i use dla and gpu, do i have to create multiple pgie’s and assign cameras to each?
