newkid
October 6, 2017, 11:36am
1
Hi!
I’m trying to specify the compiler for my nvcc.
$nvcc --version
Copyright (c) 2005-2017 NVIDIA Corporation
Built on Fri_Sep__1_13:16:23_CDT_2017
Cuda compilation tools, release 9.0, V9.0.175
$icpc --version
icpc (ICC) 17.0.4 20170411
Copyright (C) 1985-2017 Intel Corporation. All rights reserved.
To compile my main.cu file:
$ nvcc -o test main.cu -ccbin /usr/local/bin/icpc
nvcc fatal : The version ('90000') of the host compiler ('clang') is not supported
How could I work around this?
Best Regards,
Pranav
what is the result of
which icpc
are you on a mac? what OS is this?
newkid
October 6, 2017, 12:52pm
3
$ which icpc
/usr/local/bin/icpc
Yup! I’m on MacOSX version 10.12. OS Sierra.
I’d be happy if I could get help in configuring for g++ compiler as an alternate as well.
neither intel nor g++ are supported on MacOS for use with CUDA:
[url]CUDA Toolkit Documentation
clang is the only option
newkid
October 6, 2017, 1:20pm
5
My current clang is
$ cc --version
Apple LLVM version 9.0.0 (clang-900.0.37)
Target: x86_64-apple-darwin16.7.0
Thread model: posix
InstalledDir: /Library/Developer/CommandLineTools/usr/bin
I was trying to work around the incompatibility by either using intel or g++. However, the only option seems to be to downgrade to Apple LLVM version 8.1.0
Thanks for your help!
