hello,
i trained my own ssd-mobilnet model from jetson inference and it worked fine on jetson nano.
i tested opencv haarcascade alone on jetson nano and it worked fine.
i tried to merge both of them in one code but its not working.
this is the code iam using: opencv-detectnet.txt (1.5 KB)
ERROR:
[OpenGL] failed to create X11 Window.
jetson.utils – no output streams, creating fake null output
and only opencv window is showing with the detection bounding box of opencv only.
i tried it but i had an error with opencv
ERROR: ImportError: /usr/lib/aarch64-linux-gnu/libgomp.so.1: cannot allocate memory in static TLS block
i solved it with this command on terminal: export LD_PRELOAD=/usr/lib/aarch64-linux-gnu/libgomp.so.1
