Hello
I want to use Ethernet through the l4tbr0(Micro usb) interface without using an ethernet cable . Is there any way?
HOST PC : UBUNTU 18.04
docker0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
inet 172.17.0.1 netmask 255.255.0.0 broadcast 172.17.255.255
ether 02:42:08:04:2a:df txqueuelen 0 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 0 bytes 0 (0.0 B)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
enp0s20f0u2: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
ether 42:36:81:66:9f:d9 txqueuelen 1000 (Ethernet)
RX packets 87 bytes 9446 (9.4 KB)
enp0s20f0u2i5: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.55.100 netmask 255.255.255.0 broadcast 192.168.55.255
ether 2a:69:33:4f:4e:4e txqueuelen 1000 (Ethernet)
RX packets 1826 bytes 456537 (456.5 KB)
TX packets 1949 bytes 182228 (182.2 KB)
enp4s0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.0.196 netmask 255.255.255.0 broadcast 192.168.0.255
inet6 fe80::f7e8:eb85:2d6a:273b prefixlen 64 scopeid 0x20
ether d4:5d:64:b7:b4:0c txqueuelen 1000 (Ethernet)
RX packets 222451 bytes 286842579 (286.8 MB)
RX errors 0 dropped 733 overruns 0 frame 0
TX packets 56553 bytes 8304276 (8.3 MB)
device memory 0xa4100000-a41fffff
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10
loop txqueuelen 1000 (Local Loopback)
RX packets 11317 bytes 1081827 (1.0 MB)
TX packets 11317 bytes 1081827 (1.0 MB)
Xavier NX
ether 02:42:93:89:64:52 txqueuelen 0 (Ethernet)
eth0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
ether 48:b0:2d:07:67:a5 txqueuelen 1000 (Ethernet)
device interrupt 36
l4tbr0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.55.1 netmask 255.255.255.0 broadcast 192.168.55.255
inet6 fe80::2869:33ff:fe4f:4e4d prefixlen 64 scopeid 0x20
inet6 fe80::1 prefixlen 128 scopeid 0x20
ether 2a:69:33:4f:4e:4d txqueuelen 1000 (Ethernet)
RX packets 2716 bytes 237185 (237.1 KB)
TX packets 2339 bytes 511837 (511.8 KB)
loop txqueuelen 1 (Local Loopback)
RX packets 467 bytes 34778 (34.7 KB)
TX packets 467 bytes 34778 (34.7 KB)
rndis0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
RX packets 53 bytes 9401 (9.4 KB)
TX packets 423 bytes 63349 (63.3 KB)
usb0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet6 fe80::2869:33ff:fe4f:4e4f prefixlen 64 scopeid 0x20
ether 2a:69:33:4f:4e:4f txqueuelen 1000 (Ethernet)
RX packets 2663 bytes 227784 (227.7 KB)
TX packets 1671 bytes 604860 (604.8 KB)
