Using Lambda functions in CUDA with template functions
I was trying to implement a Generic Class using Cuda for common algorithms like Reduce or Scan providing some pre processing such as a simple map inside the algorithm. This map operations are carried out before the actual reduce/scan algorithm. In order to realize this I was hoping to use the lambda functions. Following is the way I tried to implement this.
template<typename T> void __device__ ReduceOperationPerThread(T * d_in, T * d_out, unsigned int size)
    //Actual Reduce Algorithm Comes here
template<typename T, typename LAMBDA>
__global__ void ReduceWithPreprocessing(T * d_in, T * d_out, unsigned int size, LAMBDA lam)
    lam();
    ReduceOperationPerThread(d_in, d_out, size);
The helper function that invokes this kernel is created as follows,
void Reduce(T * d_in, T * d_out, unsigned int size, LAMBDA lam)
    // preparing block sizes, grid sizes
    // and additional logic for invoking the kernel goes here
    // with the Kernel invocation as following
    ReduceWithPreprocessing<T><<<gridSize, blockSize>>>(d_in, d_out, size, lam)
All of the above code is included in a source named Reduce.cu and the respective header is created as Reduce.h as following
// Reduce.h
void Reduce(T * d_in, T * d_out, unsigned int size, LAMBDA lam);
So at the end of the day the complete Reduce.cu looks like this,
// Reduce.cu
    lam();
void ReduceWPreprocessing(T * d_in, T * d_out, unsigned int size, LAMBDA lam)
But the problem I’m having is related to writing template functions in separate .h and .cu files
In normal cases where lambda functions are not used, what I used to do was adding all the possible implementations of the function with possible values for template parameter at the end of the .cu file as mentioned in https://isocpp.org/wiki/faq/templates#separate-template-fn-defn-from-decl-export-keyword, under FAQ - “How can I avoid linker errors with my template classes?”
// At the end of the Reduce.cu file
// Writing functions with possible template values
// For A normal Reduce function
template void Reduce<double>(double * d_in, double * d_out, unsigned int size);
template void Reduce<float>(float * d_in, float* d_out, unsigned int size);
template void Reduce<int>(int * d_in, int * d_out, unsigned int size)
But in this case possible value for template parameter LAMBDA cannot be predefined.
template void ReduceWPreprocessing<int>(int * d_in, int * d_out, unsigned int size, ??? lambda);
Is there another way to use lambda functions for this kind of applications?
The answer I got from stackoverflow was that there is no way to use the lambda functions along with the template parameters
I don’t think this question has anything to do with CUDA, does it?
How would you perform this in ordinary C++ ?
If you don’t know, maybe what you should do is remove the CUDA aspects of this question, and post it on a C++ forum like SO where there are approximately 5 Billion C++ programmers looking at it.
Oh, here’s your problem right here. Yeah, you can’t do that in C++. In C++, templates are incomplete types. They basically give the compiler enough information to someday generate a complete type but for the time being, the compiler can’t do much with a template. There’s no way to actually create a generic definition in a source file. Only specializations can be put into their own source file.
This means all your templated code needs to be in the header file.
To pass a lambda, be horribly insecure and just do this:
template <typename T, typename F>
auto map(T* array_of_data, F functor> -> T*;
map<int>([0, 1, 2], [](int i) -> int { return i + 1; });
@txbob,
If it was a normal c++ problem I would have implemented everything on header file. But in this case I cannot do that since the header might be included in a c++ source files where they are compiled by a default c++ compiler which doesn’t identify Cuda keywords
you can use two header files, or single file with checking the CUDA_ARCH:
#ifdef __CUDA_ARCH__
nvcc compiles here
#else
host compiles here
#endif
