Using Mac as host machine for NVIDIA jetson nano j1020
Does anyone know here if I can use Mac as a host machine to import my deep learning code in NVIDIA Jetson Nano j1020? or it only needs Linux as a host machine?
Can I run SDK manager on macOS?
Thank you in advance
Welcome to the forums! This topic belongs in the Jetson forums. I have moved it over for you.
You must use a physical Ubuntu Linux Machine - the required version should match the version on the Jetson module. For Jetson Nano you are stuck at Jetpack 4 and Ubuntu 18.04 as Jetson Nano (not Orin Nano!) will not get any software updates.
Virtual machines won’t work reliable.
Linux machines other and amd64/x86-64 architecture won’t work.
A small machine with something like an Atom J4125 is enough - you don’t need a big i7 or Ryzen for flashing.
Thank you for your kind helps
It is clear for me now
