Using multi-stream
How can I use multistream on the agent? It seems like the interface still only allows for a singular rtsp stream to be uploaded. Should I open multiple windows? And if so, is multistream only supported for summarization and alerts or also chat?
If you want to set alerts on multiple live streams, you can open a second browser tab to the VSS UI and follow the same steps to connect an additional stream and set new alerts. Both tabs will show alert output and summarizations for their respective stream. Q&A is only supported currently if GRAG is disabled (Will be fully available in GA).
Thanks for the prompt response. That makes sense. So what does it mean that Q&A is only supported currently if Graph RAG is disabled?
For multi-stream, Q&A is currently not supported with graph RAG. We will fix for GA release.
