Using NGC CLI with custom CA certificates
I’m trying to use the NGC CLI behind a corporate firewall which requires TLS clients to use a custom CA certificate. Most applications automatically use the custom file /etc/ssl/certs/ca-certificates.crt but the NGC CLI does not. How can I configure the NGC CLI to use this custom CA certificate/bundle?
Here is the error that I get.
./ngc --debug registry model list nvidia/tao/pretrained_detectnet_v2:*
Error querying external IP address: The DNS operation timed out after 5.005450248718262 seconds
Requesting URL (GET): https://api.ngc.nvidia.com/v2/models/nvidia/tao/pretrained_detectnet_v2/versions?page-size=1000&sort-order=SEMVER_DESC
    payload: None
    params: None
Connection failed; retrying... (Retries left: 5)
Connection failed: HTTPSConnectionPool(host='api.ngc.nvidia.com', port=443): Max retries exceeded with url: /v2/models/nvidia/tao/pretrained_detectnet_v2/versions?page-size=1000&sort-order=SEMVER_DESC (Caused by SSLError(SSLCertVerificationError(1, '[SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: self signed certificate in certificate chain (_ssl.c:1123)')))
Trying again.
