Hi, I’m modifying the deepstream-test1 app to use my own int8 tensorrt engine. The model takes input in NHWC format but the app expects input in the NCHW format.
INFO: [Implicit Engine Info]: layers num: 5
0 INPUT kFLOAT image_arrays:0 640x640x3
1 OUTPUT kINT32 num_detections 0
2 OUTPUT kFLOAT detection_boxes 1024x4
3 OUTPUT kFLOAT detection_scores 1024
4 OUTPUT kFLOAT detection_classes 1024
0:00:08.703674449 4915 0x558fe32520 ERROR nvinfer gstnvinfer.cpp:613:gst_nvinfer_logger: NvDsInferContext[UID 1]: Error in NvDsInferContextImpl::preparePreprocess() <nvdsinfer_context_impl.cpp:874> [UID = 1]: RGB/BGR input format specified but network input channels is not 3
• Hardware Platform Jetson
• DeepStream Version 5.0
• JetPack Version 4.4
• TensorRT Version 7.2
• Issue Type questions
• Requirement details Ability to shift from NCHW input format to NHWC format in deepstream-test1 app
In general, Deepstream expected NCHW format.
Which model format do you use?
For the uff-based model, there is a configure to specify NCHW or NHWC input.
https://docs.nvidia.com/metropolis/deepstream/dev-guide/text/DS_plugin_gst-nvinfer.html
More, which Jetson do you use?
I followed this example:
I had used automl link to get the saved pb file which i used to generate the onnx. The engine i finally got is hence in the NHWC format.
I’m using Jetson NX.
Thanks for the feedback.
The sample is to demonstrate how to convert/run a TF efficientdet with TensorRT.
We will check if it is possible to integrate with Deepstream.
Please noted the sample requires a TensoRT v8.0 (JetPack 4.6) package.
But the Deepstream package for JetPack 4.6 is not available yet.
The sample had option to use older plugins with --legacy_plugins
flag. I’m using:
If deepstream can’t use nhwc, then can you suggest how i could add a transpose layer at the input stage either in the onnx using graphsurgeon etc or in the tensorRT engine directly. I see that tensorRT has a transpose layer but I’m having difficulty in adding that to the existing engine.
https://docs.nvidia.com/deeplearning/tensorrt/api/python_api/infer/Graph/Layers.html#ishufflelayer
Just want to confirm the environment first.
Do you use TensorRT 7.1.3, the default version in JetPack 4.4?
$ cat /usr/include/aarch64-linux-gnu/NvInferVersion.h
I’m really sorry for the confusion. Yes, the tensorRT version is 7.1.3.
It was a different machine with 7.2.1.6
You can convert an NCHW model with the create_onnx.py script directly.
Would you mind giving it a try?
$ python create_onnx.py \
--input_shape '1,3,512,512' \
--saved_model /path/to/saved_model \
--onnx /path/to/model.onnx
I’ll do this and post an update.
Does it work with the NCHW model?
Following your suggestion gave some errors in the engine building process. Output using trtexec:
[09/16/2021-20:26:49] [E] [TRT] /home/DV_RA/torch_to_trt/onnx-tensorrt/ModelImporter.cpp:685: While parsing node number 2 [Conv → “efficientnet-lite4/stem/tpu_batch_normalization/FusedBatchNormV3:0”]:
[09/16/2021-20:26:49] [E] [TRT] /home/DV_RA/torch_to_trt/onnx-tensorrt/ModelImporter.cpp:686: — Begin node —
[09/16/2021-20:26:49] [E] [TRT] /home/DV_RA/torch_to_trt/onnx-tensorrt/ModelImporter.cpp:687: input: “preprocessor/mean:0_1”
input: “efficientnet-lite4/stem/conv2d/Conv2D_weights_fused_bn”
input: “efficientnet-lite4/stem/conv2d/Conv2D_bias_fused_bn”
output: “efficientnet-lite4/stem/tpu_batch_normalization/FusedBatchNormV3:0”
op_type: “Conv”
attribute {
ints: 1
ints: 1
type: INTS
attribute {
ints: 2
ints: 2
type: INTS
attribute {
ints: 3
ints: 3
type: INTS
attribute {
s: “SAME_UPPER”
type: STRING
attribute {
i: 0
type: INT
[09/16/2021-20:26:49] [E] [TRT] /home/DV_RA/torch_to_trt/onnx-tensorrt/ModelImporter.cpp:688: — End node —
[09/16/2021-20:26:49] [E] [TRT] /home/DV_RA/torch_to_trt/onnx-tensorrt/ModelImporter.cpp:691: ERROR: /home/DV_RA/torch_to_trt/onnx-tensorrt/builtin_op_importers.cpp:579 In function importConv:
[6] Assertion failed: nchan == -1 || kernelWeights.shape.d[1] * ngroup == nchan
[09/16/2021-20:26:49] [E] Failed to parse onnx file
[09/16/2021-20:26:49] [E] Parsing model failed
[09/16/2021-20:26:49] [E] Engine creation failed
[09/16/2021-20:26:49] [E] Engine set up failed
&&&& FAILED TensorRT.trtexec # trtexec --onnx=efficientdet-lite4_tf_iou05_080921.onnx --fp16 --saveEngine=a
Also, I found this. It’s however not useful for me as i don’t have a uff model.
Thanks for your testing.
We are checking this issue internally.
Will share more information with you later.
Thanks for your patience.
We test the sample with the efficientdet_d0_coco17_tpu-32 model.
After generating the NCHW model from create_onnx.py, we can successfully build it into TensorRT engine with the build_engine.py script.
$ python3 create_onnx.py --saved_model efficientdet_d0_coco17_tpu-32/saved_model --onnx model_NCHW.onnx --input_shape '1,3,512,512'
$ python3 build_engine.py --onnx model_NCHW.onnx --engine engine_NCHW.trt --precision fp16 --workspace 1
If you keep meeting the error, please upgrade the environment with JetPack4.6 and try it again.
