I am changing some working code repository that originally uses nppiResize_8u_C3R to use nppiResizeBatch_8u_C3R instead for advantages here NVIDIA 2D Image And Signal Performance Primitives (NPP): ResizeBatch. So far nppiResize_8u_C3R invokes without error but whenever the batched version is called with similar stride and pointer parameters it outputs an CUDA_EXCEPTION_14 (Warp Illegal Address). Code used below:
NppiSize getLargestSize(NppiSize first, NppiSize second)
NppiSize smallest{first.width, first.height};
if (second.height > first.height || first.height == 0) {
smallest.height = second.height;
if (second.width > first.width || first.width == 0) {
smallest.width = second.width;
return smallest;
int main()
cv::Mat image = cv::imread("./tests/data/persons.png");
int w = 4000;
int h = 4000;
int m_channels = 3;
cudaStream_t stream;
cudaStreamCreate(&stream);
int batchSize = 2;
std::vector<cv::Mat> images;
for (int i = 0; i < batchSize; i++) {
cv::Mat imgClone = image.clone();
// imgClone.resize(1000 + i * 1000);
images.emplace_back(imgClone);
int dstStep = 640 * m_channels;
NppiSize dstSize{.width = 640, .height = 640};
NppiRect dstRoi{.x = 0, .y = 0, .width = 640, .height = 640};
// MixedBufferBatch struct is on CPU
NppiResizeBatchCXR mixedBufferBatch[batchSize];
NppiSize largestSize = {0, 0};
// Pointers
void *m_inputBuffer;
void *m_resizedBuffer;
(cudaMalloc(reinterpret_cast<void **>(&m_inputBuffer), batchSize * w * h * m_channels));
(cudaMalloc(reinterpret_cast<void **>(&m_resizedBuffer), batchSize * 640 * 640 * m_channels));
auto *inbuf = (uchar *)(m_inputBuffer);
auto *outbuf = (uchar *)(m_resizedBuffer);
int idx = 0;
for (cv::Mat &image: images) {
largestSize = getLargestSize(largestSize, {image.cols, image.rows});
assert(image.elemSize() == 3);
size_t N = image.rows * image.cols * image.elemSize();
cudaMemcpyAsync(inbuf, image.data, N, cudaMemcpyHostToDevice, stream);
mixedBufferBatch[idx].nSrcStep = image.cols * image.elemSize();// * image.rows;
mixedBufferBatch[idx].nDstStep = dstStep;
mixedBufferBatch[idx].pSrc = inbuf;
mixedBufferBatch[idx].pDst = outbuf;
inbuf += N; // on GPU
outbuf += (640 * 640 * m_channels);
idx++;
cudaError_t err = cudaDeviceSynchronize();
if (err != cudaSuccess) {
std::cout << "[Before Resize] ERROR OCCURED: " << err <<"\n";
NppiRect largestSizeRect{.x = 0, .y = 0, .width = largestSize.width, .height = largestSize.height};
NppStatus resultStatus = nppiResizeBatch_8u_C3R(
largestSize, largestSizeRect, dstSize, dstRoi,
NPPI_INTER_LINEAR, mixedBufferBatch, images.size()
// NppStatus resultStatus =
// nppiResize_8u_C3R((unsigned char *) (m_inputBuffer), largestSize.width * m_channels, largestSize, largestSizeRect,
// (unsigned char *) (m_resizedBuffer), dstStep, dstSize, dstRoi,
// NPPI_INTER_LINEAR);
// The device encountered a load or store instruction on an invalid memory address.
// This leaves the process in an inconsistent state and any further CUDA work will
// return the same error. To continue using CUDA, the process must be terminated and relaunched.
std::cout << "[After resize] ERROR OCCURED: " << err <<"\n";
cv::Mat saveII(640, 640, CV_8UC3, cv::Scalar(10, 10, 10));
cudaMemcpy(saveII.data, m_resizedBuffer, 640 * 640*3, cudaMemcpyDeviceToHost);
(cudaStreamSynchronize(stream));
cv::imwrite("saveII.png", saveII);
cudaFree(m_inputBuffer);
cudaFree(m_resizedBuffer);
return 0;
If you uncomment the nppiResize_8u_C3R section instead of using nppiResizeBatch_8u_C3R function, you’ll see it doesn’t raise the 700 error and correctly outputs a resized RGB image as expected. Would appreciate any inputs on this peculiar issue.
OpenCV-Free version:
return smallest;
int main()
int w = 2000;
int h = 2000;
int m_channels = 3;
int batchSize = 4;
// Pointers
cudaMemset(m_inputBuffer, 1, 5012);
cudaMemset(m_inputBuffer, 2, batchSize * w * h * m_channels-5012);
auto *inbuf = reinterpret_cast<uchar *>(m_inputBuffer);
auto *outbuf = reinterpret_cast<uchar *>(m_resizedBuffer);
for (int idx=0;idx<batchSize;idx++) {
largestSize = getLargestSize(largestSize, {w, h});
size_t N = w * h * m_channels;
int srcStep = w * m_channels;
mixedBufferBatch[idx].nSrcStep = srcStep;
idx++;
//CUDA_EXCEPTION_14 (Warp Illegal Address)
// cuda-gdb backtrace:
//#0 0x0000555559a339e0 in void resizeNaiveBatchBy2Rows<unsigned char, 3u, SampleLinearImageBatchBy2Rows<unsigned char,
// 3> >(SampleLinearImageBatchBy2Rows<unsigned char, 3>,
// float, float, nppc::ClipRect, NppiRect, NppiResizeBatchCXR*, unsigned int)<<<(20,320,1),(128,1,1)>>> ()
NPPI_INTER_LINEAR, mixedBufferBatch, batchSize
// nppiResize_8u_C3R((uchar*)(m_inputBuffer), w * m_channels, largestSize, largestSizeRect,
// (uchar*)(m_resizedBuffer), 640 * 3, dstSize, dstRoi, NPPI_INTER_LINEAR);
std::cout << "ERROR OCCURED: " << err <<"\n";
if (resultStatus == NPP_RESIZE_NO_OPERATION_ERROR) {
std::cout << "No operation! \n";
return 0;
add_executable(test_npp_resize ./npp_resize_batch.cu)
target_link_libraries(test_npp_resize
PUBLIC
${CUDA_npp_LIBRARY}
${CUDA_nppi_LIBRARY}
${CUDA_LIBRARIES}
# ${OpenCV_LIBS}
