Using nsys
Software Version
DRIVE OS 6.0.10.0
[1]DRIVE OS 6.0.8.1
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
[1]Linux
QNX
other
Hardware Platform
[1]DRIVE AGX Orin Developer Kit (not sure its number)
other
SDK Manager Version
2.1.0
[1]other
Host Machine Version
other
Issue Description
Hi team, I want to profile my application using nsys. I ran the following command but I got the errors below
/opt/nvidia/nsight_systems/nsys profile ./gpu_process
Error String
Dear @akshay.tupkar ,
Are you able to run / usr/local/cuda-11.4/samples/1_Utilities/deviceQuery sample?
nvidia@tegra-ubuntu:~/olddata/target-linux-tegra-armv8$ ./nsys profile /usr/local/cuda-11.4/samples/1_Utilities/deviceQuery/deviceQuery
WARNING: CPU IP/backtrace sampling not supported, disabling.
Try the 'nsys status --environment' command to learn more.
WARNING: CPU context switch tracing not supported, disabling.
/usr/local/cuda-11.4/samples/1_Utilities/deviceQuery/deviceQuery Starting...
 CUDA Device Query (Runtime API) version (CUDART static linking)
Detected 1 CUDA Capable device(s)
Device 0: "Orin"
  CUDA Driver Version / Runtime Version          12.1 / 11.4
  CUDA Capability Major/Minor version number:    8.7
  Total amount of global memory:                 28954 MBytes (30360248320 bytes)
  (016) Multiprocessors, (128) CUDA Cores/MP:    2048 CUDA Cores
  GPU Max Clock rate:                            1275 MHz (1.27 GHz)
  Memory Clock rate:                             1275 Mhz
  Memory Bus Width:                              256-bit
  L2 Cache Size:                                 4194304 bytes
  Maximum Texture Dimension Size (x,y,z)         1D=(131072), 2D=(131072, 65536), 3D=(16384, 16384, 16384)
  Maximum Layered 1D Texture Size, (num) layers  1D=(32768), 2048 layers
  Maximum Layered 2D Texture Size, (num) layers  2D=(32768, 32768), 2048 layers
  Total amount of constant memory:               65536 bytes
  Total amount of shared memory per block:       49152 bytes
  Total shared memory per multiprocessor:        167936 bytes
  Total number of registers available per block: 65536
  Warp size:                                     32
  Maximum number of threads per multiprocessor:  1536
  Maximum number of threads per block:           1024
  Max dimension size of a thread block (x,y,z): (1024, 1024, 64)
  Max dimension size of a grid size    (x,y,z): (2147483647, 65535, 65535)
  Maximum memory pitch:                          2147483647 bytes
  Texture alignment:                             512 bytes
  Concurrent copy and kernel execution:          Yes with 2 copy engine(s)
  Run time limit on kernels:                     No
  Integrated GPU sharing Host Memory:            Yes
  Support host page-locked memory mapping:       Yes
  Alignment requirement for Surfaces:            Yes
  Device has ECC support:                        Disabled
  Device supports Unified Addressing (UVA):      Yes
  Device supports Managed Memory:                Yes
  Device supports Compute Preemption:            Yes
  Supports Cooperative Kernel Launch:            Yes
  Supports MultiDevice Co-op Kernel Launch:      Yes
  Device PCI Domain ID / Bus ID / location ID:   0 / 0 / 0
  Compute Mode:
     < Default (multiple host threads can use ::cudaSetDevice() with device simultaneously) >
deviceQuery, CUDA Driver = CUDART, CUDA Driver Version = 12.1, CUDA Runtime Version = 11.4, NumDevs = 1
Result = PASS
Generating '/tmp/nsys-report-9c7b.qdstrm'
[1/1] [========================100%] report3.nsys-rep
Generated:
    /home/nvidia/olddata/target-linux-tegra-armv8/report3.nsys-rep
Dear @SivaRamaKrishnaNV
I generated rep file using nsys, I want to confirm one thing,
What should I use to monitor cpu and gpu utilization of an application? Would you suggest me “tegrastats” or nsys?
Nsys would give you detail timeline view where as tegrastats just shows the utilisation percentage.
Does that you can generate nsys rep file for your sample. If not, please share the sample code to repro.
Could you please provide any update? Can we close the topic?
