I’m trying to get the nvarguscamerasrc
pipeline to run in openCV inside an anaconda (miniforge3) environment on the Jetson Nano 2GB.
I’ve succesfully used the script by mdegans your script to install opencv in the miniforge environment and face an issue when trying to access the camera. I think I’m very close, but there is one last error when executing the following line:
mypipeline = "nvarguscamerasrc sensor-id=0 !video/x-raw(memory:NVMM), width=(int)1920, height=(int)1080, framerate=(fraction)30/1 ! nvvidconv flip-method=0 ! video/x-raw, width=(int)960, height=(int)540, format=(string)BGRx ! videoconvert ! video/x-raw, format=(string)BGR ! appsink"
cv2.VideoCapture(mypipeline, cv2.CAP_GSTREAMER)
It gives the following error:
[ WARN:0] global /home/uc2/Downloads/opencv-4.5.2/modules/videoio/src/cap_gstreamer.cpp (854) open OpenCV | GStreamer warning: Error opening bin: no element "nvarguscamerasrc"
[ WARN:0] global /home/uc2/Downloads/opencv-4.5.2/modules/videoio/src/cap_gstreamer.cpp (597) isPipelinePlaying OpenCV | GStreamer warning: GStreamer: pipeline have not been created
Error: Unable to open camera
gstreamer should be installed properly and the shared library created with tis script is linked properly (at least it installed)… Did I miss anything? In the non pyhton environment (i.e. vanilla/preinstalled python3.6) python it works just fine:
(imswitch) uc2@uc2-desktop:~$ gst-launch-1.0 nvarguscamerasrc sensor_id=0 ! 'video/x-raw(memory:NVMM),width=1920, height=1080, framerate=30/1' ! nvvidconv flip-method=0 ! 'video/x-raw,width=960, height=540' ! nvvidconv ! nvegltransform ! nveglglessink -e
Setting pipeline to PAUSED ...
Using winsys: x11
Pipeline is live and does not need PREROLL ...
Got context from element 'eglglessink0': gst.egl.EGLDisplay=context, display=(GstEGLDisplay)NULL;
Setting pipeline to PLAYING ...
New clock: GstSystemClock
GST_ARGUS: Creating output stream
CONSUMER: Waiting until producer is connected...
GST_ARGUS: Available Sensor modes :
GST_ARGUS: 3264 x 2464 FR = 21,000000 fps Duration = 47619048 ; Analog Gain range min 1,000000, max 10,625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 3264 x 1848 FR = 28,000001 fps Duration = 35714284 ; Analog Gain range min 1,000000, max 10,625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1920 x 1080 FR = 29,999999 fps Duration = 33333334 ; Analog Gain range min 1,000000, max 10,625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1640 x 1232 FR = 29,999999 fps Duration = 33333334 ; Analog Gain range min 1,000000, max 10,625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1280 x 720 FR = 59,999999 fps Duration = 16666667 ; Analog Gain range min 1,000000, max 10,625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1280 x 720 FR = 120,000005 fps Duration = 8333333 ; Analog Gain range min 1,000000, max 10,625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: Running with following settings:
Camera index = 0
Camera mode = 2
Output Stream W = 1920 H = 1080
seconds to Run = 0
Frame Rate = 29,999999
GST_ARGUS: Setup Complete, Starting captures for 0 seconds
GST_ARGUS: Starting repeat capture requests.
CONSUMER: Producer has connected; continuing.
ERROR: from element /GstPipeline:pipeline0/GstNvArgusCameraSrc:nvarguscamerasrc0: Internal data stream error.
Additional debug info:
gstbasesrc.c(3055): gst_base_src_loop (): /GstPipeline:pipeline0/GstNvArgusCameraSrc:nvarguscamerasrc0:
streaming stopped, reason error (-5)
EOS on shutdown enabled -- waiting for EOS after Error
Waiting for EOS...
Same as in the terminal in the imswitch
environment.
>>> cv2.getBuildInformation()
General configuration for OpenCV 4.5.2 =====================================
Version control: unknown
Platform:
Timestamp: 2022-01-25T22:14:52Z
Host: Linux 4.9.253-tegra aarch64
CMake: 3.10.2
CMake generator: Unix Makefiles
CMake build tool: /usr/bin/make
Configuration: RELEASE
CPU/HW features:
Baseline: NEON FP16
C/C++:
Built as dynamic libs?: YES
C++ standard: 11
C++ Compiler: /usr/bin/c++ (ver 7.5.0)
C++ flags (Release): -fsigned-char -ffast-math -W -Wall -Werror=return-type -Werror=non-virtual-dtor -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wundef -Winit-self -Wpointer-arith -Wshadow -Wsign-promo -Wuninitialized -Wsuggest-override -Wno-delete-non-virtual-dtor -Wno-comment -Wimplicit-fallthrough=3 -Wno-strict-overflow -fdiagnostics-show-option -pthread -fomit-frame-pointer -ffunction-sections -fdata-sections -fvisibility=hidden -fvisibility-inlines-hidden -O3 -DNDEBUG -DNDEBUG
C++ flags (Debug): -fsigned-char -ffast-math -W -Wall -Werror=return-type -Werror=non-virtual-dtor -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wundef -Winit-self -Wpointer-arith -Wshadow -Wsign-promo -Wuninitialized -Wsuggest-override -Wno-delete-non-virtual-dtor -Wno-comment -Wimplicit-fallthrough=3 -Wno-strict-overflow -fdiagnostics-show-option -pthread -fomit-frame-pointer -ffunction-sections -fdata-sections -fvisibility=hidden -fvisibility-inlines-hidden -g -O0 -DDEBUG -D_DEBUG
C Compiler: /usr/bin/cc
C flags (Release): -fsigned-char -ffast-math -W -Wall -Werror=return-type -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wmissing-prototypes -Wstrict-prototypes -Wundef -Winit-self -Wpointer-arith -Wshadow -Wuninitialized -Wno-comment -Wimplicit-fallthrough=3 -Wno-strict-overflow -fdiagnostics-show-option -pthread -fomit-frame-pointer -ffunction-sections -fdata-sections -fvisibility=hidden -O3 -DNDEBUG -DNDEBUG
C flags (Debug): -fsigned-char -ffast-math -W -Wall -Werror=return-type -Werror=address -Werror=sequence-point -Wformat -Werror=format-security -Wmissing-declarations -Wmissing-prototypes -Wstrict-prototypes -Wundef -Winit-self -Wpointer-arith -Wshadow -Wuninitialized -Wno-comment -Wimplicit-fallthrough=3 -Wno-strict-overflow -fdiagnostics-show-option -pthread -fomit-frame-pointer -ffunction-sections -fdata-sections -fvisibility=hidden -g -O0 -DDEBUG -D_DEBUG
Linker flags (Release): -Wl,--gc-sections -Wl,--as-needed
Linker flags (Debug): -Wl,--gc-sections -Wl,--as-needed
ccache: NO
Precompiled headers: NO
Extra dependencies: dl m pthread rt
3rdparty dependencies:
OpenCV modules:
To be built: calib3d core dnn features2d flann gapi highgui imgcodecs imgproc ml objdetect photo python3 stitching ts video videoio
Disabled: world
Disabled by dependency: -
Unavailable: java python2
Applications: tests perf_tests examples apps
Documentation: NO
Non-free algorithms: YES
GUI:
GTK+: NO
OpenGL support: NO
VTK support: NO
Media I/O:
ZLib: /usr/lib/aarch64-linux-gnu/libz.so (ver 1.2.11)
JPEG: /usr/lib/aarch64-linux-gnu/libjpeg.so (ver 80)
WEBP: build (ver encoder: 0x020f)
PNG: /usr/lib/aarch64-linux-gnu/libpng.so (ver 1.6.34)
TIFF: /usr/lib/aarch64-linux-gnu/libtiff.so (ver 42 / 4.0.9)
JPEG 2000: build (ver 2.4.0)
OpenEXR: build (ver 2.3.0)
HDR: YES
SUNRASTER: YES
PXM: YES
PFM: YES
Video I/O:
DC1394: NO
FFMPEG: YES
avcodec: YES (57.107.100)
avformat: YES (57.83.100)
avutil: YES (55.78.100)
swscale: YES (4.8.100)
avresample: YES (3.7.0)
GStreamer: YES (1.14.5)
v4l/v4l2: YES (linux/videodev2.h)
Parallel framework: TBB (ver 2017.0 interface 9107)
Trace: YES (with Intel ITT)
Other third-party libraries:
Lapack: NO
Eigen: YES (ver 3.3.4)
Custom HAL: YES (carotene (ver 0.0.1))
Protobuf: build (3.5.1)
OpenCL: YES (no extra features)
Include path: /home/uc2/Downloads/opencv-4.5.2/3rdparty/include/opencl/1.2
Link libraries: Dynamic load
Python 3:
Interpreter: /home/uc2/miniforge3/envs/imswitch/bin/python3 (ver 3.7.12)
Libraries: /home/uc2/miniforge3/envs/imswitch/lib/libpython3.7m.so (ver 3.7.12)
numpy: /home/uc2/miniforge3/envs/imswitch/lib/python3.7/site-packages/numpy/core/include (ver 1.21.5)
install path: /home/uc2/miniforge3/envs/imswitch/lib/python3.7/site-packages/cv2/python-3.7
Python (for build): /home/uc2/miniforge3/envs/imswitch/bin/python3
Java:
ant: NO
JNI: NO
Java wrappers: NO
Java tests: NO
Install to: /home/uc2/miniforge3/envs/imswitch
Any ideas? Is there a missing gstreamer plugin I need to install in python?
