Using nvdisasm to show line numbers and register usage
Hello, I have been using nvdisasm using the following options - nvdisasm -g -plr -lrm=narrow. I have the following questions -
  1. I can only make -g or -plr -lrm=narrow work at a given time, i.e., if supplied together, -g is ignored. What am I doing wrong here?
  2. How can I format the output of -plr? Using -plr -lrm=narrow, I get a massive amount of gap between the instructions and the register usage column, e.g. -
If no superior alternative is offered, you could always remove white space from lines by piping the output of nvdisasm through the cut utility program. If you are on Windows, it is available as part of Cygwin.
hmmm
I took the simpleMultiCopy.cu sample code, compiled it as:
nvcc simpleMulticopy.cu -cubin -lineinfo -o s.o
and then did:
nvdisasm -g -plr -lrm=narrow s.o
and got this:
<snip>
//--------------------- .text._Z9incKernelPiS_ii  --------------------------
        .section        .text._Z9incKernelPiS_ii,"ax",@progbits
        .sectioninfo    @"SHI_REGISTERS=12"
        .align  32
        // |       GPR        | PRED   |
        // |    000000000011  |        |
        // |  # 012345678901  |  # 01  |
        .global         _Z9incKernelPiS_ii                                           // |                  |        |
        .type           _Z9incKernelPiS_ii,@function                                 // |                  |        |
        .size           _Z9incKernelPiS_ii,(.L_x_7 - _Z9incKernelPiS_ii)             // |                  |        |
        .other          _Z9incKernelPiS_ii,@"STO_CUDA_ENTRY STV_DEFAULT"             // |                  |        |
_Z9incKernelPiS_ii:        // |                  |        |
.text._Z9incKernelPiS_ii:                                                            // |                  |        |
        /*0008*/                   MOV R1, c[0x0][0x20] ;                            // |  1  ^            |        |
        /*0010*/         {         MOV R6, c[0x0][0x154] ;                           // |  3 ^:    ^       |        |
        /*0018*/                   S2R R0, SR_CTAID.X         }                      // |  3 ^:    ^       |        |
        /*0028*/         {         ISETP.GE.AND P0, PT, R6, 0x1, PT ;                // |  4 ::^   v       |  1 ^   |
        /*0030*/                   S2R R2, SR_TID.X         }                        // |  4 ::^   v       |  1 ^   |
        /*0038*/                   XMAD.MRG R3, R0.reuse, c[0x0] [0x8].H1, RZ ;      // |  5 v::^  :       |  1 :   |
        /*0048*/                   XMAD R2, R0.reuse, c[0x0] [0x8], R2 ;             // |  5 v:x:  :       |  1 :   |
        /*0050*/                   XMAD.PSL.CBCC R0, R0.H1, R3.H1, R2 ;              // |  5 x:vv  :       |  1 :   |
        /*0058*/                   ISETP.GE.OR P0, PT, R0, c[0x0][0x150], !P0 ;      // |  3 v:    :       |  1 x   |
        /*0068*/                   NOP ;                                             // |  3 ::    :       |  1 :   |
        /*0070*/                   NOP ;                                             // |  3 ::    :       |  1 :   |
        /*0078*/               @P0 EXIT ;                                            // |  3 ::    :       |  1 v   |
        /*0088*/                   SHL R4, R0.reuse, 0x2 ;                           // |  4 v:  ^ :       |        |
        /*0090*/                   IADD32I R5, R6, -0x1 ;                            // |  5 ::  :^v       |        |
        /*0098*/                   SHR R0, R0, 0x1e ;                                // |  5 x:  :::       |        |
        /*00a8*/                   IADD R2.CC, R4, c[0x0][0x148] ;                   // |  6 ::^ v::       |        |
        /*00b0*/                   ISETP.GE.U32.AND P0, PT, R5, 0x3, PT ;            // |  6 ::: :v:       |  1 ^   |
        /*00b8*/                   IADD.X R3, R0, c[0x0][0x14c] ;                    // |  6 v::^: :       |  1 :   |
        /*00c8*/                   IADD R4.CC, R4, c[0x0][0x140] ;                   // |  6 ::::x :       |  1 :   |
        /*00d0*/                   IADD.X R5, R0, c[0x0][0x144] ;                    // |  7 v::::^:       |  1 :   |
        /*00d8*/         {         LOP32I.AND R0, R6, 0x3 ;                          // |  7 ^:::::v       |  1 v   |
        /*00e8*/              @!P0 BRA `(.L_x_0)         }                           // |  7 ^:::::v       |  1 v   |
        /*00f0*/                   IADD R6, -R0, c[0x0][0x154] ;                     // |  7 v:::::^       |        |
        /*00f8*/                   ISETP.GT.AND P0, PT, R6, RZ, PT ;                 // |  7 ::::::v       |  1 ^   |
        /*0108*/              @!P0 BRA `(.L_x_1) ;                                   // |  7 :::::::       |  1 v   |
        /*0110*/                   ISETP.GT.AND P1, PT, R6, 0xc, PT ;                // |  7 ::::::v       |  1  ^  |
        /*0118*/         {         PSETP.AND.AND P0, PT, PT, PT, PT ;                // |  7 :::::::       |  2 ^v  |
        /*0128*/              @!P1 BRA `(.L_x_2)         }                           // |  7 :::::::       |  2 ^v  |
        /*0130*/                   PSETP.AND.AND P0, PT, !PT, PT, PT ;               // |  7 :::::::       |  1 ^   |
.L_x_3:        // |  8 ::::::::      |  1 :   |
        /*0138*/         {         IADD32I R6, R6, -0x10 ;                           // |  8 ::vv::x^      |  1 :   |
        /*0148*/                   LDG.E R7, [R2]         }                          // |  8 ::vv::x^      |  1 :   |
        /*0150*/                   IADD32I R7, R7, 0x1 ;                             // |  8 :::::::x      |  1 :   |
        /*0158*/                   STG.E [R4], R7 ;                                  // |  8 ::::vv:v      |  1 :   |
        /*0168*/                   LDG.E R8, [R2] ;                                  // |  8 ::vv::: ^     |  1 :   |
        /*0170*/                   IADD32I R9, R8, 0x1 ;                             // |  9 ::::::: v^    |  1 :   |
        /*0178*/                   STG.E [R4], R9 ;                                  // |  8 ::::vv:  v    |  1 :   |
        /*0188*/                   LDG.E R8, [R2] ;                                  // |  8 ::vv::: ^     |  1 :   |
        /*0190*/                   IADD32I R10, R8, 0x1 ;                            // |  9 ::::::: v ^   |  1 :   |
        /*0198*/                   STG.E [R4], R10 ;                                 // |  8 ::::vv:   v   |  1 :   |
        /*01a8*/                   LDG.E R8, [R2] ;                                  // |  8 ::vv::: ^     |  1 :   |
        /*01b0*/                   IADD32I R11, R8, 0x1 ;                            // |  9 ::::::: v  ^  |  1 :   |
        /*01b8*/                   STG.E [R4], R11 ;                                 // |  8 ::::vv:    v  |  1 :   |
        /*01c8*/                   LDG.E R8, [R2] ;                                  // |  8 ::vv::: ^     |  1 :   |
        /*01d0*/                   IADD32I R7, R8, 0x1 ;                             // |  9 :::::::^v     |  1 :   |
        /*01d8*/                   STG.E [R4], R7 ;                                  // |  8 ::::vv:v      |  1 :   |
        /*01e8*/                   LDG.E R8, [R2] ;                                  // |  8 ::vv::: ^     |  1 :   |
        /*01f0*/                   IADD32I R9, R8, 0x1 ;                             // |  9 ::::::: v^    |  1 :   |
        /*01f8*/                   STG.E [R4], R9 ;                                  // |  8 ::::vv:  v    |  1 :   |
        /*0208*/                   LDG.E R8, [R2] ;                                  // |  8 ::vv::: ^     |  1 :   |
        /*0210*/                   IADD32I R10, R8, 0x1 ;                            // |  9 ::::::: v ^   |  1 :   |
        /*0218*/                   STG.E [R4], R10 ;                                 // |  8 ::::vv:   v   |  1 :   |
        /*0228*/                   LDG.E R8, [R2] ;                                  // |  8 ::vv::: ^     |  1 :   |
        /*0230*/                   IADD32I R11, R8, 0x1 ;                            // |  9 ::::::: v  ^  |  1 :   |
        /*0238*/                   STG.E [R4], R11 ;                                 // |  8 ::::vv:    v  |  1 :   |
        /*0248*/                   LDG.E R8, [R2] ;                                  // |  8 ::vv::: ^     |  1 :   |
        /*0250*/                   IADD32I R7, R8, 0x1 ;                             // |  9 :::::::^v     |  1 :   |
        /*0258*/                   STG.E [R4], R7 ;                                  // |  8 ::::vv:v      |  1 :   |
        /*0268*/                   LDG.E R8, [R2] ;                                  // |  8 ::vv::: ^     |  1 :   |
        /*0270*/                   IADD32I R9, R8, 0x1 ;                             // |  9 ::::::: v^    |  1 :   |
        /*0278*/                   STG.E [R4], R9 ;                                  // |  8 ::::vv:  v    |  1 :   |
        /*0288*/                   LDG.E R8, [R2] ;                                  // |  8 ::vv::: ^     |  1 :   |
        /*0290*/                   IADD32I R10, R8, 0x1 ;                            // |  9 ::::::: v ^   |  1 :   |
        /*0298*/                   STG.E [R4], R10 ;                                 // |  8 ::::vv:   v   |  1 :   |
        /*02a8*/                   LDG.E R8, [R2] ;                                  // |  8 ::vv::: ^     |  1 :   |
        /*02b0*/                   IADD32I R11, R8, 0x1 ;                            // |  9 ::::::: v  ^  |  1 :   |
        /*02b8*/                   STG.E [R4], R11 ;                                 // |  8 ::::vv:    v  |  1 :   |
        /*02c8*/                   LDG.E R8, [R2] ;                                  // |  8 ::vv::: ^     |  1 :   |
        /*02d0*/                   IADD32I R7, R8, 0x1 ;                             // |  9 :::::::^v     |  1 :   |
        /*02d8*/                   STG.E [R4], R7 ;                                  // |  8 ::::vv:v      |  1 :   |
        /*02e8*/                   LDG.E R8, [R2] ;                                  // |  8 ::vv::: ^     |  1 :   |
        /*02f0*/                   IADD32I R9, R8, 0x1 ;                             // |  9 ::::::: v^    |  1 :   |
        /*02f8*/                   STG.E [R4], R9 ;                                  // |  8 ::::vv:  v    |  1 :   |
        /*0308*/                   LDG.E R8, [R2] ;                                  // |  8 ::vv::: ^     |  1 :   |
        /*0310*/                   ISETP.GT.AND P1, PT, R6, 0xc, PT ;                // |  8 ::::::v :     |  2 :^  |
        /*0318*/                   IADD32I R10, R8, 0x1 ;                            // |  9 ::::::: v ^   |  2 ::  |
        /*0328*/                   STG.E [R4], R10 ;                                 // |  8 ::::vv:   v   |  2 ::  |
        /*0330*/                   LDG.E R8, [R2] ;                                  // |  8 ::vv::: ^     |  2 ::  |
        /*0338*/                   IADD32I R11, R8, 0x1 ;                            // |  9 ::::::: v  ^  |  2 ::  |
        /*0348*/                   STG.E [R4], R11 ;                                 // |  8 ::::vv:    v  |  2 ::  |
        /*0350*/               @P1 BRA `(.L_x_3) ;                                   // |  7 :::::::       |  2 :v  |
.L_x_2:        // |  7 :::::::       |  2 ::  |
        /*0358*/                   ISETP.GT.AND P1, PT, R6, 0x4, PT ;                // |  7 ::::::v       |  2 :^  |
        /*0368*/              @!P1 BRA `(.L_x_4) ;                                   // |  7 :::::::       |  2 :v  |
        /*0370*/         {         PSETP.AND.AND P0, PT, !PT, PT, PT ;               // |  8 ::vv:::^      |  1 ^   |
        /*0378*/                   LDG.E R7, [R2]         }                          // |  8 ::vv:::^      |  1 ^   |
        /*0388*/                   IADD32I R7, R7, 0x1 ;                             // |  8 :::::::x      |  1 :   |
        /*0390*/                   STG.E [R4], R7 ;                                  // |  8 ::::vv:v      |  1 :   |
        /*0398*/                   LDG.E R8, [R2] ;                                  // |  8 ::vv::: ^     |  1 :   |
        /*03a8*/                   IADD32I R9, R8, 0x1 ;                             // |  9 ::::::: v^    |  1 :   |
        /*03b0*/                   STG.E [R4], R9 ;                                  // |  8 ::::vv:  v    |  1 :   |
        /*03b8*/                   LDG.E R8, [R2] ;                                  // |  8 ::vv::: ^     |  1 :   |
        /*03c8*/                   IADD32I R10, R8, 0x1 ;                            // |  9 ::::::: v ^   |  1 :   |
        /*03d0*/                   STG.E [R4], R10 ;                                 // |  8 ::::vv:   v   |  1 :   |
        /*03d8*/                   LDG.E R8, [R2] ;                                  // |  8 ::vv::: ^     |  1 :   |
        /*03e8*/                   IADD32I R11, R8, 0x1 ;                            // |  9 ::::::: v  ^  |  1 :   |
        /*03f0*/                   STG.E [R4], R11 ;                                 // |  8 ::::vv:    v  |  1 :   |
        /*03f8*/                   LDG.E R8, [R2] ;                                  // |  8 ::vv::: ^     |  1 :   |
        /*0408*/                   IADD32I R7, R8, 0x1 ;                             // |  9 :::::::^v     |  1 :   |
        /*0410*/                   STG.E [R4], R7 ;                                  // |  8 ::::vv:v      |  1 :   |
        /*0418*/                   LDG.E R8, [R2] ;                                  // |  8 ::vv::: ^     |  1 :   |
        /*0428*/                   IADD32I R9, R8, 0x1 ;                             // |  9 ::::::: v^    |  1 :   |
        /*0430*/                   STG.E [R4], R9 ;                                  // |  8 ::::vv:  v    |  1 :   |
        /*0438*/                   LDG.E R8, [R2] ;                                  // |  8 ::vv::: ^     |  1 :   |
        /*0448*/                   IADD32I R10, R8, 0x1 ;                            // |  9 ::::::: v ^   |  1 :   |
        /*0450*/                   STG.E [R4], R10 ;                                 // |  8 ::::vv:   v   |  1 :   |
        /*0458*/                   LDG.E R8, [R2] ;                                  // |  8 ::vv::: ^     |  1 :   |
        /*0468*/                   IADD32I R6, R6, -0x8 ;                            // |  8 ::::::x :     |  1 :   |
        /*0470*/                   IADD32I R11, R8, 0x1 ;                            // |  9 ::::::: v  ^  |  1 :   |
        /*0478*/                   STG.E [R4], R11 ;                                 // |  8 ::::vv:    v  |  1 :   |
.L_x_4:        // |  7 :::::::       |  1 :   |
        /*0488*/                   ISETP.NE.OR P0, PT, R6, RZ, P0 ;                  // |  7 ::::::v       |  1 x   |
        /*0490*/              @!P0 BRA `(.L_x_0) ;                                   // |  7 :::::::       |  1 v   |
.L_x_1:        // |  8 ::::::::      |        |
<snip>
I didn’t seem to have trouble getting either the lineinfo or any “massive amount of gap” between instructions and register usage columns.
CUDA 12.2, linux
I too am on 12.2, on Linux. I don’t see the line numbers in your snippet. For reference, when I use only the -g flag with nvdisasm, I get the line numbers associated with the source code -
        /*44b0*/                   DMUL R2, R2, c[0x2][0x1138] ;
        //## File "CKUBMS_wrapper.cu", line 710
        /*44c0*/                   LEA R4, P0, R0, c[0x0][0x170], 0x3 ;
        /*44d0*/                   LEA.HI.X R5, R0, c[0x0][0x174], RZ, 0x3, P0 ;
        //## File "CKUBMS_wrapper.cu", line 703
        /*44e0*/                   DMUL R2, R2, R12 ;
        /*44f0*/                   STG.E.64 [R4.64], R2 ;
        //## File "CKUBMS_wrapper.cu", line 711
        /*4500*/                   EXIT ;
I agree the line info is missing. If you want to see both, I suggest filing a bug.
Here is ticket 4638434 conclusion.
The behavior is by design as adding debug line info with plr info can clobber the disasm output printing. We will add an info message as :
nvdisasm info : Options --print-line-info and its variants are ignored when printing register life range
to warn ‘-g’ is ignored in cases like this . This change will aim a future CUDA 12.x release soon . Hope this makes sense and thanks for reporting a ticket to us .
