can you please let me know which of the command can process .raw file through hardware isp not software isp.
while I was checking nvmimg_cc -h this command does not save or reprocess .raw file
nvmipp_raw -h this command does not reprocess raw.
nvmimg_cap -h this command also does not reprocess.
Can you help here.
I am looking to reprocess raw through hardware isp.
I have been going through these documents for a while, but these documents don’t show me how do I re-process .raw through nvmipp_raw
I can capture raw and jpg using nvmipp_raw but I am not able to " reprocess" captured raws.
if nvmipp_raw is capable of reprocessing can you please provide the command.
Can you please provide the command to reprocess raw images through xavier .nvmippfile does work but the output is dark as the ouput is not tone mapped.
can you please check with the team or tuning team . they would be using the reprocessing option.
