Software Version
DRIVE OS 6.0.10.0
DRIVE OS 6.0.8.1
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
2.1.0
other
Host Machine Version
other
Issue Description
Hey all, I believe that it is possible to use the EOF fence from NvMediaIDE as a pre-fence to NvMedia2D, but I am getting some errors in setting up the right NvSciSyncObj
and some errors in getting the EOF from NvMediaIDE and/or inserting a pre-fence to NvMedia2D.
Steps Tried
What are the restrictions / steps in creating the NvSciSyncObj
? If both engines run from the same process, do we only need 1x NvSciSyncObj
shared between both engines? It seems to me that we can only register 1x NvSciSyncObj
allocated with a particular engine attributes, and doing otherwise would throw a NVMEDIA_STATUS_BAD_PARAMETER
(see below).
// Create attribute lists and fill it with engine attributes.
NvMediaIDEFillNvSciSyncAttrList(decoder, nvmedia_ide_attr_list, NVMEDIA_SIGNALER_WAITER));
NvMedia2DFillNvSciSyncAttrList(compositor, nvmedia_2d_attr_list, NVMEDIA_SIGNALER_WAITER));
// Reconcile above attributes list ==> Error here since both attributes are set.
NvSciSyncAttrListReconcile(unreconciled_attr_list, 2, &reconciled_attr_list, &conflict_list);
// Unable to proceed to allocate and register NvSciSyncObj.
If I were to use only the NvMediaIDE attributes to create the NvSciSyncObj
and then try to insert the fence to NvMedia2D, I also get a NVMEDIA_STATUS_BAD_PARAMETER
NvSciSyncAttrListReconcile(unreconciled_attr_list, 1, &reconciled_attr_list, &conflict_list);
NvMediaIDERegisterNvSciSyncObj(decoder, NVMEDIA_EOF_PRESYNCOBJ, sync_obj);
NvMediaIDESetNvSciSyncObjforEOF(decoder, sync_obj);
NvMediaIDEGetEOFNvSciSyncFence(decoder, sync_obj, &fence); // works.
NvMedia2DGetComposeParameters(compositor, &compositor_params);
NvMedia2DInsertPreNvSciSyncFence(compositor, compositor_params, &fence); // errors out.
Vice versa, if I were to allocate & register the NvSciSyncObj
with NvMedia2D, I would instead fail at NvMediaIDESetNvSciSyncObjforEOF
with the error NVMEDIA_STATUS_BAD_PARAMETER
. And if I don’t set the NvSciSyncObj
with NvMediaIDE, I am unable to retrieve the EOF fence from the decoder either.
NvMedia2DEFillNvSciSyncAttrList(compositor, nvmedia_2d_attr_list, NVMEDIA_SIGNALER_WAITER));
NvMedia2DRegisterNvSciSyncObj(compositor, NVMEDIA_EOF_PRESYNCOBJ, sync_obj);
// NvMediaIDERegisterNvSciSyncObj(decoder, NVMEDIA_EOF_PRESYNCOBJ, sync_obj); // not called since you can't register twice.
NvMediaIDESetNvSciSyncObjforEOF(decoder, sync_obj); // fails here.
NvMediaIDEGetEOFNvSciSyncFence(decoder, sync_obj, &fence); // fails here if i step registering & setting.
Question
Could you kindly share how to setup the NvSciSyncObj
and pass the fence from engine to engine? I assume this would be possible due to the topic here: How to shorten the image process time.
Thanks in advance!
Sam
