Hello, how can I access ObjectronWriter in Isaac Sim headless python script? And how should I actually use it? Can’t find any examples.
writer = rep.WriterRegistry.get("ObjectronWriter")
output_directory = args.data_dir
writer.initialize(output_dir=output_directory, bounding_box_3d_fast=True, bounding_box_2d_tight_fast=True, bounding_box_2d_loose_fast=True, camera_params=True, semantic_segmentation=True, rgb=True, distance_to_camera=True, bbox=True)
Error: 2024-02-27 16:28:06 [124,686ms] [Error] [__main__] Exception: No writer with name `ObjectronWriter` was found in registry.
File "/home/mona/.local/share/ov/pkg/isaac_sim-2023.1.1/extscache/omni.replicator.core-1.10.20+105.1.lx64.r.cp310/omni/replicator/core/scripts/writers.py", line 998, in get
raise WriterRegistryError(f"No writer with name `{writer_name}` was found in registry.")
omni.replicator.core.scripts.writers.WriterRegistryError: No writer with name `ObjectronWriter` was found in registry.
[125.001s] Simulation App Shutting Down
When I look at 10.10.4.1. Setting — Omniverse IsaacSim latest documentation I see it is listed as TODO?
