Using omni.isaac.ros2_bridge in Python
Isaac Sim Version
4.2.0
4.1.0
4.0.0
2023.1.1
2023.1.0-hotfix.1
Other (please specify):
Operating System
Ubuntu 22.04
Ubuntu 20.04
Windows 11
Windows 10
GPU Information
  • Model: NVIDIA RTX 3500 Ada Generation
  • Driver Version: Version: Version: 565.57.01
Topic Description
Detailed Description
Hello, I am trying to set everything up for a Python simulation. This means launching the environment, the robot, etc. I previously gave details of what I’m trying to do (check related issues).
When I run my code, the simulation environment opens but then crashes because of an issue with omni. Isaac.ros2_bridge, as you can see in Error Messages.
I am working within a conda environment.
Error Messages
[INFO] [1737040676.962118703] [locobot_node]: Initializing Isaac Sim...
[Warning] [omni.isaac.kit.simulation_app] Modules: ['omni.kit_app'] were loaded before SimulationApp was started and might not be loaded correctly.
[Warning] [omni.isaac.kit.simulation_app] Please check to make sure no extra omniverse or pxr modules are imported before the call to SimulationApp(...)
Starting kit application with the following args:  ['/home/ubuntu/anaconda3/envs/env_isaacsim/lib/python3.10/site-packages/isaacsim/exts/omni.isaac.kit/omni/isaac/kit/simulation_app.py', '/home/ubuntu/.local/share/ov/pkg/isaac-sim-4.2.0/apps/omni.isaac.sim.python.kit', '--/app/tokens/exe-path=/home/ubuntu/.local/share/ov/pkg/isaac-sim-4.2.0/kit', '--/persistent/app/viewport/displayOptions=3094', '--/rtx/materialDb/syncLoads=True', '--/rtx/hydra/materialSyncLoads=True', '--/omni.kit.plugin/syncUsdLoads=True', '--/app/renderer/resolution/width=1024', '--/app/renderer/resolution/height=768', '--/app/window/width=1440', '--/app/window/height=900', '--/renderer/multiGpu/enabled=True', '--/app/fastShutdown=True', '--ext-folder', '/home/ubuntu/.local/share/ov/pkg/isaac-sim-4.2.0/exts', '--ext-folder', '/home/ubuntu/.local/share/ov/pkg/isaac-sim-4.2.0/apps', '--/physics/cudaDevice=0', '--portable']
Passing the following args to the base kit application:  []
[Info] [carb] Logging to file: /home/ubuntu/.local/share/ov/pkg/isaac-sim-4.2.0/kit/logs/Kit/Isaac-Sim/4.2/kit_20250116_161757.log
2025-01-16 15:17:57 [0ms] [Warning] [omni.kit.app.plugin] No crash reporter present, dumps uploading isn't available.
[0.114s] [ext: omni.blobkey-1.1.2] startup
[0.114s] [ext: omni.kit.async_engine-0.0.1] startup
[0.395s] [ext: omni.stats-1.0.1] startup
[0.396s] [ext: omni.datastore-0.0.0] startup
[0.400s] [ext: omni.client-1.2.0] startup
[0.424s] [ext: omni.ujitso.default-1.0.0] startup
[0.425s] [ext: omni.gpu_foundation.shadercache.vulkan-1.0.0] startup
[0.427s] [ext: omni.hsscclient-1.1.1] startup
[0.427s] [ext: omni.assets.plugins-0.0.0] startup
[0.429s] [ext: omni.gpu_foundation-0.0.0] startup
[0.436s] [ext: carb.windowing.plugins-1.0.0] startup
[0.442s] [ext: omni.kit.renderer.init-0.0.0] startup
2025-01-16 15:17:59 [2,532ms] [Warning] [gpu.foundation.plugin] Skipping unsupported non-NVIDIA GPU: Intel(R) Graphics (RPL-S)
2025-01-16 15:17:59 [2,533ms] [Warning] [gpu.foundation.plugin] Skipping unsupported non-NVIDIA GPU: Intel(R) Graphics (RPL-S)
| Driver Version: 565.57.01     | Graphics API: Vulkan
| GPU | Name                             | Active | LDA | GPU Memory | Vendor-ID | LUID       |
|     |                                  |        |     |            | Device-ID | UUID       |
|     |                                  |        |     |            | Bus-ID    |            |
| 0   | NVIDIA RTX 3500 Ada Generation.. | Yes: 0 |     | 12282   MB | 10de      | 0          |
|     |                                  |        |     |            | 27bb      | 43620150.. |
|     |                                  |        |     |            | 1         |            |
| 1   | Intel(R) Graphics (RPL-S)        |        |     | 23831   MB | 8086      | 0          |
|     |                                  |        |     |            | a788      | 868088a7.. |
|     |                                  |        |     |            | 0         |            |
| OS: 22.04.5 LTS (Jammy Jellyfish) ubuntu, Version: 22.04.5, Kernel: 6.8.0-51-generic
| XServer Vendor: The X.Org Foundation, XServer Version: 12101004 (1.21.1.4)
| Processor: 13th Gen Intel(R) Core(TM) i9-13950HX | Cores: 24 | Logical: 48
| Total Memory (MB): 31774 | Free Memory: 19297
| Total Page/Swap (MB): 2047 | Free Page/Swap: 2047
[3.089s] [ext: omni.kit.pipapi-0.0.0] startup
[3.090s] [ext: omni.kit.pip_archive-0.0.0] startup
[3.090s] [ext: omni.pip.compute-1.4.0] startup
[3.090s] [ext: omni.pip.cloud-1.1.3] startup
[3.093s] [ext: omni.isaac.core_archive-2.3.0] startup
[3.093s] [ext: omni.materialx.libs-1.0.4] startup
[3.100s] [ext: omni.isaac.ml_archive-2.0.1] startup
[3.100s] [ext: omni.kit.telemetry-0.5.0] startup
[3.119s] [ext: omni.usd.config-1.0.4] startup
[3.124s] [ext: omni.gpucompute.plugins-0.0.0] startup
[3.125s] [ext: omni.usd.libs-1.0.1] startup
[3.295s] [ext: omni.iray.libs-0.0.0] startup
[3.301s] [ext: omni.mdl.neuraylib-0.2.8] startup
[3.304s] [ext: omni.mdl-55.0.1] startup
[3.330s] [ext: omni.kit.usd.mdl-1.0.1] startup
[3.445s] [ext: omni.kit.loop-isaac-1.2.0] startup
[3.445s] [ext: omni.kit.test-1.1.0] startup
[3.484s] [ext: omni.appwindow-1.1.8] startup
[3.489s] [ext: omni.kit.renderer.core-1.0.2] startup
[3.584s] [ext: omni.kit.renderer.capture-0.0.0] startup
[3.586s] [ext: omni.kit.renderer.imgui-1.0.1] startup
[3.653s] [ext: omni.ui-2.25.22] startup
[3.663s] [ext: omni.kit.mainwindow-1.0.3] startup
[3.664s] [ext: carb.audio-0.1.0] startup
[3.667s] [ext: omni.uiaudio-1.0.0] startup
[3.667s] [ext: omni.kit.uiapp-0.0.0] startup
[3.667s] [ext: omni.usd.schema.isaac-2.1.0] startup
[3.675s] [ext: omni.usd.schema.audio-0.0.0] startup
[3.679s] [ext: omni.usd.schema.anim-0.0.0] startup
[3.702s] [ext: omni.usd.schema.geospatial-0.0.0] startup
[3.705s] [ext: omni.usd.schema.semantics-0.0.0] startup
[3.708s] [ext: omni.usd.schema.omnigraph-1.0.0] startup
[3.715s] [ext: omni.anim.navigation.schema-106.1.0] startup
[3.718s] [ext: omni.usd.schema.scene.visualization-2.0.2] startup
[3.719s] [ext: omni.usd.schema.omniscripting-1.0.0] startup
[3.724s] [ext: omni.anim.graph.schema-106.1.0] startup
[3.730s] [ext: omni.usd.schema.physx-106.1.9] startup
[3.761s] [ext: omni.usd.schema.forcefield-106.1.9] startup
[3.767s] [ext: omni.graph.exec-0.9.4] startup
[3.768s] [ext: omni.kit.usd_undo-0.1.8] startup
[3.768s] [ext: omni.kit.actions.core-1.0.0] startup
[3.770s] [ext: omni.kit.exec.core-0.13.4] startup
[3.773s] [ext: omni.usd_resolver-1.0.0] startup
[3.776s] [ext: omni.kit.commands-1.4.9] startup
[3.779s] [ext: omni.activity.core-1.0.1] startup
[3.781s] [ext: omni.usd.core-1.4.1] startup
[3.785s] [ext: omni.resourcemonitor-105.0.1] startup
[3.786s] [ext: omni.kit.window.popup_dialog-2.0.24] startup
[3.789s] [ext: omni.timeline-1.0.10] startup
[3.790s] [ext: omni.kit.widget.nucleus_connector-1.1.9] startup
[3.792s] [ext: usdrt.scenegraph-7.5.0] startup
[3.830s] [ext: omni.kit.audiodeviceenum-1.0.1] startup
[3.832s] [ext: omni.hydra.usdrt_delegate-7.5.1] startup
[3.850s] [ext: omni.hydra.scene_delegate-0.3.3] startup
[3.855s] [ext: omni.usd-1.12.2] startup
[3.890s] [ext: omni.kit.menu.core-1.0.4] startup
[3.891s] [ext: omni.kit.collaboration.telemetry-1.0.0] startup
[3.892s] [ext: omni.kit.property.adapter.core-1.0.1] startup
[3.893s] [ext: omni.kit.menu.utils-1.5.27] startup
[3.900s] [ext: omni.kit.clipboard-1.0.4] startup
[3.900s] [ext: omni.kit.collaboration.channel_manager-1.0.12] startup
[3.901s] [ext: omni.kit.property.adapter.usd-1.0.1] startup
[3.902s] [ext: omni.kit.widget.options_menu-1.1.6] startup
[3.904s] [ext: omni.kit.widget.graph-1.12.15] startup
[3.907s] [ext: omni.kit.widget.searchfield-1.1.8] startup
[3.908s] [ext: omni.kit.widget.filter-1.1.4] startup
[3.909s] [ext: omni.kit.property.adapter.fabric-1.0.1] startup
[3.910s] [ext: omni.ui_query-1.1.4] startup
[3.910s] [ext: omni.kit.window.extensions-1.4.11] startup
[3.915s] [ext: omni.kit.usd.layers-2.1.36] startup
[3.923s] [ext: omni.kit.widget.context_menu-1.2.2] startup
[3.923s] [ext: omni.hydra.rtx.shadercache.vulkan-1.0.0] startup
[3.924s] [ext: omni.kit.notification_manager-1.0.9] startup
[3.926s] [ext: omni.kit.hotkeys.core-1.3.5] startup
[3.927s] [ext: omni.kit.context_menu-1.8.1] startup
[3.928s] [ext: omni.kit.widget.prompt-1.0.7] startup
[3.929s] [ext: omni.kit.helper.file_utils-0.1.8] startup
[3.930s] [ext: omni.kit.widget.nucleus_info-1.0.2] startup
[3.931s] [ext: omni.kit.widget.filebrowser-2.10.51] startup
[3.935s] [ext: omni.kit.search_core-1.0.5] startup
[3.935s] [ext: omni.kit.widget.path_field-2.0.10] startup
[3.936s] [ext: omni.ui.scene-1.10.3] startup
[3.940s] [ext: omni.kit.widget.search_delegate-1.0.5] startup
[3.941s] [ext: omni.kit.widget.options_button-1.0.3] startup
[3.942s] [ext: omni.kit.widget.browser_bar-2.0.10] startup
[3.942s] [ext: omni.volume-0.5.0] startup
[3.946s] [ext: omni.kit.window.filepicker-2.10.40] startup
[3.955s] [ext: omni.ujitso.processor.texture-1.0.0] startup
[3.956s] [ext: omni.kit.window.file_exporter-1.0.30] startup
[3.959s] [ext: omni.ujitso.client-0.0.0] startup
[3.959s] [ext: omni.kit.widget.stage-2.11.2] startup
[3.969s] [ext: omni.kit.widget.live_session_management.ui-1.0.1] startup
[3.970s] [ext: omni.kit.collaboration.presence_layer-1.0.9] startup
[3.972s] [ext: omni.hydra.rtx-1.0.0] startup
[3.992s] [ext: omni.inspect-1.0.1] startup
[3.994s] [ext: omni.kit.widget.searchable_combobox-1.0.6] startup
[3.995s] [ext: omni.kit.window.file_importer-1.1.12] startup
[3.996s] [ext: omni.kit.stage_template.core-1.1.22] startup
[3.997s] [ext: omni.kit.widget.settings-1.2.2] startup
[3.998s] [ext: omni.kit.window.file-1.3.54] startup
[4.001s] [ext: omni.kit.window.drop_support-1.0.3] startup
[4.001s] [ext: omni.kit.window.content_browser_registry-0.0.6] startup
[4.002s] [ext: omni.kit.window.preferences-1.6.0] startup
[4.008s] [ext: omni.kit.window.content_browser-2.9.18] startup
[4.020s] [ext: omni.kit.widget.live_session_management-1.2.20] startup
[4.022s] [ext: omni.kit.widget.text_editor-1.0.2] startup
[4.023s] [ext: omni.kit.hydra_texture-1.3.9] startup
[4.027s] [ext: omni.kit.viewport.legacy_gizmos-1.1.0] startup
[4.030s] [ext: omni.kit.raycast.query-1.0.5] startup
[4.036s] [ext: omni.kit.material.library-1.5.6] startup
[4.041s] [ext: omni.kit.widget.viewport-106.1.0] startup
[4.044s] [ext: omni.kit.viewport.registry-104.0.6] startup
[4.045s] [ext: omni.hydra.engine.stats-1.0.2] startup
[4.048s] [ext: omni.kit.widget.highlight_label-1.0.2] startup
[4.049s] [ext: omni.kit.viewport.window-107.0.6] startup
[4.064s] [ext: omni.kit.window.property-1.11.3] startup
[4.066s] [ext: omni.graph.core-2.179.2] startup
[4.069s] [ext: omni.graph.tools-1.79.0] startup
[4.085s] [ext: omni.kit.viewport.utility-1.0.17] startup
[4.085s] [ext: omni.kit.property.usd-4.2.8] startup
[4.092s] [ext: omni.debugdraw-0.1.3] startup
[4.096s] [ext: omni.graph-1.140.0] startup
[4.254s] [ext: omni.graph.ui-1.70.2] startup
[4.267s] [ext: omni.kvdb-106.1.9] startup
[4.271s] [ext: omni.graph.image.core-0.4.5] startup
[4.273s] [ext: omni.localcache-106.1.9] startup
[4.274s] [ext: omni.graph.image.nodes-1.1.0] startup
[4.278s] [ext: omni.usdphysics-106.1.9] startup
[4.283s] [ext: omni.physx.foundation-106.1.9] startup
[4.284s] [ext: omni.convexdecomposition-106.1.9] startup
[4.290s] [ext: omni.graph.nodes-1.146.1] startup
[4.300s] [ext: omni.physx.cooking-106.1.9] startup
[4.314s] [ext: omni.kit.primitive.mesh-1.0.17] startup
[4.318s] [ext: omni.physx-106.1.9] startup
[4.332s] [ext: omni.kit.stage_templates-1.2.5] startup
[4.335s] [ext: omni.isaac.version-1.1.0] startup
[4.335s] [ext: omni.kit.widget.material_preview-1.0.16] startup
[4.339s] [ext: omni.isaac.nucleus-0.3.1] startup
[4.340s] [ext: omni.physics.tensors-106.1.9] startup
[4.350s] [ext: omni.physx.stageupdate-106.1.9] startup
[4.354s] [ext: omni.graph.action_core-1.1.6] startup
[4.360s] [ext: omni.warp.core-1.2.1] startup
[4.440s] [ext: omni.physx.tensors-106.1.9] startup
[4.448s] [ext: omni.graph.scriptnode-1.20.1] startup
[4.449s] [ext: omni.kit.manipulator.viewport-107.0.0] startup
[4.452s] [ext: omni.graph.action_nodes-1.24.0] startup
[4.462s] [ext: omni.kit.ui_test-1.3.2] startup
[4.467s] [ext: omni.isaac.core-3.19.5] startup
[5.618s] [ext: omni.graph.visualization.nodes-2.1.1] startup
[5.624s] [ext: omni.graph.action-1.102.1] startup
[5.628s] [ext: omni.kit.window.cursor-1.1.2] startup
[5.633s] [ext: omni.isaac.ui-0.16.0] startup
[5.640s] [ext: omni.kit.viewport.menubar.core-106.1.0] startup
[5.660s] [ext: omni.kit.graph.delegate.default-1.2.2] startup
[5.662s] [ext: omni.syntheticdata-0.6.9] startup
[5.688s] [ext: omni.kit.graph.usd.commands-1.3.1] startup
[5.690s] [ext: omni.kit.graph.editor.core-1.5.3] startup
[5.693s] [ext: omni.kit.numpy.common-0.1.2] startup
[5.696s] [ext: omni.warp-1.2.1] startup
[5.702s] [ext: omni.kit.window.material_graph-1.8.18] startup
[5.746s] [ext: omni.isaac.dynamic_control-1.3.8] startup
[5.773s] [ext: omni.replicator.core-1.11.20] startup
2025-01-16 15:18:02 [5,752ms] [Warning] [omni.replicator.core.scripts.annotators] Annotator PostProcessDispatch is already registered, overwriting annotator template
Warp 1.2.1 initialized:
   CUDA Toolkit 11.8, Driver 12.7
   Devices:
     "cpu"      : "x86_64"
     "cuda:0"   : "NVIDIA RTX 3500 Ada Generation Laptop GPU" (12 GiB, sm_89, mempool enabled)
   Kernel cache:
     /home/ubuntu/.cache/warp/1.2.1
[5.926s] [ext: omni.isaac.lula-3.0.1] startup
[5.936s] [ext: omni.isaac.surface_gripper-1.0.1] startup
[5.940s] [ext: omni.isaac.core_nodes-1.16.3] startup
[5.963s] [ext: omni.isaac.motion_generation-7.1.0] startup
[5.987s] [ext: omni.isaac.manipulators-2.1.0] startup
[5.994s] [ext: omni.isaac.franka-0.4.1] startup
[5.998s] [ext: omni.kit.graph.widget.variables-2.1.0] startup
[6.008s] [ext: omni.kit.graph.delegate.modern-1.10.6] startup
[6.018s] [ext: omni.isaac.cortex-0.3.9] startup
[6.027s] [ext: omni.graph.window.core-1.113.1] startup
[6.063s] [ext: omni.isaac.wheeled_robots-2.3.3] startup
[6.091s] [ext: omni.isaac.cortex.sample_behaviors-1.0.6] startup
[6.095s] [ext: omni.graph.window.generic-1.26.0] startup
[6.127s] [ext: omni.isaac.menu-0.7.3] startup
[6.146s] [ext: omni.kit.widget.live-2.1.8] startup
[6.168s] [ext: omni.kit.actions.window-1.1.1] startup
[6.196s] [ext: omni.kit.widget.cache_indicator-2.0.10] startup
[6.333s] [ext: omni.kit.hotkeys.window-1.4.5] startup
[6.341s] [ext: omni.kit.ui.actions-1.0.2] startup
[6.350s] [ext: omni.kit.widget.stage_icons-1.0.5] startup
[6.353s] [ext: omni.kit.menu.common-1.1.7] startup
[6.359s] [ext: omni.kit.selection-0.1.4] startup
[6.363s] [ext: omni.isaac.kit-1.13.2] startup
[6.364s] [ext: omni.isaac.block_world-1.0.0] startup
[6.377s] [ext: omni.kit.window.stage-2.5.10] startup
[6.397s] [ext: omni.isaac.debug_draw-1.1.0] startup
[6.404s] [ext: omni.kit.menu.edit-1.1.24] startup
[6.412s] [ext: omni.kit.menu.file-1.1.14] startup
[6.414s] [ext: omni.kit.profiler.window-2.2.3] startup
[6.422s] [ext: omni.kit.menu.stage-1.2.5] startup
[6.424s] [ext: omni.isaac.occupancy_map-1.0.3] startup
[6.434s] [ext: omni.importer.mjcf-1.1.1] startup
[6.446s] [ext: omni.graph.window.action-1.28.0] startup
[6.454s] [ext: omni.kit.property.camera-1.0.8] startup
[6.457s] [ext: omni.kit.property.light-1.0.10] startup
[6.459s] [ext: omni.kit.property.geometry-1.3.1] startup
[6.463s] [ext: omni.hydra.scene_api-0.1.2] startup
[6.470s] [ext: omni.kit.property.audio-1.0.14] startup
[6.474s] [ext: omni.kit.property.render-1.1.2] startup
[6.476s] [ext: omni.kit.property.transform-1.5.9] startup
[6.481s] [ext: omni.kit.property.material-1.10.8] startup
[6.486s] [ext: omni.kit.widget.layers-1.8.0] startup
[6.497s] [ext: omni.kit.property.isaac-0.2.3] startup
[6.500s] [ext: omni.kit.property.bundle-1.3.1] startup
[6.502s] [ext: omni.sensors.nv.common-1.2.2-isaac-1] startup
[6.515s] [ext: omni.kit.property.layer-1.1.8] startup
[6.518s] [ext: omni.kit.stage_column.payload-2.0.0] startup
[6.521s] [ext: omni.isaac.scene_blox-0.1.2] startup
[6.523s] [ext: omni.sensors.nv.materials-1.2.1-isaac-1] startup
[6.526s] [ext: omni.sensors.nv.wpm-1.2.1-isaac-1] startup
[6.527s] [ext: omni.kit.viewport.actions-106.0.2] startup
[6.532s] [ext: omni.sensors.nv.lidar-1.2.2-isaac-1] startup
[6.538s] [ext: omni.sensors.nv.radar-1.2.1-isaac-1] startup
[6.545s] [ext: omni.kit.viewport.menubar.display-107.0.2] startup
[6.548s] [ext: omni.kit.manipulator.transform-104.7.4] startup
[6.552s] [ext: omni.kit.widget.toolbar-1.7.2] startup
[6.558s] [ext: omni.sensors.tiled-0.0.6] startup
[6.561s] [ext: omni.sensors.nv.ids-1.1.0-isaac-1] startup
[6.568s] [ext: omni.isaac.range_sensor-3.1.2] startup
[6.582s] [ext: omni.usdphysics.ui-106.1.9] startup
[6.608s] [ext: omni.physx.commands-106.1.9] startup
[6.610s] [ext: omni.kit.manipulator.tool.snap-1.5.11] startup
[6.618s] [ext: omni.isaac.sensor-12.9.1] startup
[6.676s] [ext: omni.kit.manipulator.selector-1.1.1] startup
[6.680s] [ext: omni.physx.ui-106.1.9] startup
[6.720s] [ext: omni.isaac.quadruped-2.0.1] startup
[6.728s] [ext: omni.kit.viewport.manipulator.transform-107.0.2] startup
[6.732s] [ext: omni.physx.demos-106.1.9] startup
[6.750s] [ext: omni.kit.property.physx-106.1.9] startup
[6.832s] [ext: omni.kit.widget.calendar-1.0.8] startup
[6.835s] [ext: omni.kit.manipulator.prim.core-107.0.4] startup
[6.841s] [ext: omni.fabric.commands-1.1.5] startup
[6.844s] [ext: omni.physx.vehicle-106.1.9] startup
[6.862s] [ext: omni.kit.widget.extended_searchfield-1.0.28] startup
[6.872s] [ext: omni.kit.manipulator.prim.fabric-107.0.3] startup
[6.875s] [ext: omni.kit.manipulator.prim.usd-107.0.2] startup
[6.877s] [ext: omni.kit.widget.timeline-105.0.1] startup
[6.880s] [ext: omni.kit.window.commands-0.2.6] startup
[6.883s] [ext: omni.physx.camera-106.1.9] startup
[6.895s] [ext: omni.kit.manipulator.camera-105.0.5] startup
[6.901s] [ext: omni.kit.viewport.menubar.camera-107.0.2] startup
[6.907s] [ext: omni.kit.manipulator.prim-107.0.0] startup
[6.908s] [ext: omni.kit.manipulator.selection-106.0.1] startup
[6.910s] [ext: omni.kit.window.toolbar-1.6.1] startup
[6.914s] [ext: omni.kit.stage_column.variant-1.0.13] startup
[6.916s] [ext: omni.kit.viewport.menubar.render-106.1.1] startup
[6.919s] [ext: omni.kit.viewport.menubar.settings-107.0.3] startup
[6.924s] [ext: omni.physx.cct-106.1.9] startup
[6.938s] [ext: omni.physx.graph-106.1.9] startup
[6.961s] [ext: omni.physx.supportui-106.1.9] startup
[6.994s] [ext: omni.physx.telemetry-106.1.9] startup
[7.001s] [ext: omni.graph.ui_nodes-1.26.0] startup
[7.013s] [ext: omni.kit.viewport.bundle-104.0.1] startup
[7.013s] [ext: omni.isaac.universal_robots-0.3.5] startup
[7.016s] [ext: omni.kit.window.console-0.2.13] startup
[7.036s] [ext: omni.kit.window.script_editor-1.7.6] startup
[7.041s] [ext: omni.kit.menu.create-1.0.16] startup
[7.045s] [ext: omni.graph.bundle.action-2.4.1] startup
[7.047s] [ext: omni.physx.bundle-106.1.9] startup
[7.048s] [ext: omni.rtx.window.settings-0.6.17] startup
[7.058s] [ext: omni.kit.window.status_bar-0.1.7] startup
[7.071s] [ext: omni.kit.window.title-1.1.5] startup
[7.073s] [ext: omni.replicator.isaac-1.15.2] startup
[7.116s] [ext: omni.replicator.replicator_yaml-2.0.6] startup
[7.164s] [ext: omni.rtx.settings.core-0.6.3] startup
[7.174s] [ext: omni.kit.viewport.menubar.lighting-106.0.2] startup
[7.183s] [ext: semantics.schema.editor-0.3.8] startup
[7.203s] [ext: semantics.schema.property-1.0.4] startup
[7.216s] [ext: omni.kit.viewport.rtx-104.0.1] startup
[7.217s] [ext: omni.isaac.utils-1.0.1] startup
[7.225s] [ext: omni.isaac.cloner-0.8.1] startup
[7.235s] [ext: omni.importer.urdf-1.14.1] startup
[7.285s] [ext: omni.kit.window.stats-0.1.6] startup
[7.291s] [ext: omni.isaac.sim.python-4.2.0] startup
[7.293s] Simulation App Starting
[9.397s] app ready
[10.486s] Simulation App Startup Complete
[INFO] [1737040688.477786897] [locobot_node]: Isaac Sim initialized successfully
[INFO] [1737040690.481551912] [locobot_node]: Setting up ROS 2 bridge...
[ERROR] [1737040690.602455836] [locobot_node]: Error setting up ROS 2 bridge: module 'omni.isaac.ros2_bridge' has no attribute 'IsaacROS2Bridge'
[WARN] [1737040690.602782946] [locobot_node]: Attempt 1 failed, retrying...
[ERROR] [1737040691.604409955] [locobot_node]: Error setting up ROS 2 bridge: module 'omni.isaac.ros2_bridge' has no attribute 'IsaacROS2Bridge'
[WARN] [1737040691.605231441] [locobot_node]: Attempt 2 failed, retrying...
[ERROR] [1737040692.606542354] [locobot_node]: Error setting up ROS 2 bridge: module 'omni.isaac.ros2_bridge' has no attribute 'IsaacROS2Bridge'
[WARN] [1737040692.607461460] [locobot_node]: Attempt 3 failed, retrying...
[ERROR] [1737040693.609344598] [locobot_node]: Initialization error: Failed to setup ROS 2 bridge after 3 attempts
  File "/home/ubuntu/stable_ws/install/stable_trail_robotic/lib/stable_trail_robotic/locobot_node.py", line 124, in <module>
    main()
  File "/home/ubuntu/stable_ws/install/stable_trail_robotic/lib/stable_trail_robotic/locobot_node.py", line 113, in main
    node = LocoBotNode()
  File "/home/ubuntu/stable_ws/install/stable_trail_robotic/lib/stable_trail_robotic/locobot_node.py", line 50, in __init__
    raise RuntimeError(f"Failed to setup ROS 2 bridge after {max_retries} attempts")
RuntimeError: Failed to setup ROS 2 bridge after 3 attempts
2025-01-16 15:18:13 [16,597ms] [Warning] [omni.graph.core.plugin] Could not find category 'Replicator:Annotators' for removal
2025-01-16 15:18:13 [16,597ms] [Warning] [omni.graph.core.plugin] Could not find category 'Replicator:Core' for removal
2025-01-16 15:18:13 [16,666ms] [Warning] [carb] Recursive unloadAllPlugins() detected!
Additional Information
What I’ve Tried
I tried to set the correct path in my bashrc file and created an activation file for conda with the right path to all necessary elements.
Here is what I added to the bashrc:
# Isaac Sim Environment Setup
export ISAAC_SIM_PATH="${HOME}/.local/share/ov/pkg/isaac-sim-4.2.0"
export ISAAC_SIM_EXT_PATH="${ISAAC_SIM_PATH}/exts"
export CARB_APP_PATH="${ISAAC_SIM_PATH}/kit"
export ISAAC_PATH="${ISAAC_SIM_PATH}"
# Update PATH and LD_LIBRARY_PATH for Isaac Sim
export PATH="${ISAAC_SIM_PATH}/python/bin:${PATH}"
export LD_LIBRARY_PATH="${ISAAC_SIM_PATH}/python/lib:${ISAAC_SIM_PATH}/exts:${LD_LIBRARY_PATH}"
export PYTHONPATH=$PYTHONPATH:$ISAAC_SIM_PATH/exts/omni.isaac.ros2_bridge
# ROS 2 specific variables needed for Isaac Sim
export RMW_IMPLEMENTATION=rmw_fastrtps_cpp
export ROS_VERSION=2
export ROS_DISTRO=humble  # You already have ROS setup, but Isaac needs this explicit
# ROS 2 and related tools setup
source /opt/ros/humble/setup.bash
source /usr/share/colcon_argcomplete/hook/colcon-argcomplete.bash
source /usr/share/gazebo/setup.sh
# ROS 2 configuration
export ROS_DOMAIN_ID=30 #TURTLEBOT3
export LDS_MODEL=LDS-02
# Source ROS 2 workspace if it exists
if [ -f ~/stable_ws/install/setup.bash ]; then
    source ~/stable_ws/install/setup.bash
fi
I also made sure to have the extension enabled in the code and to import Isaac sim before omni
       "ext_folder_prefix": [],
        "enabled_extensions": [
            "omni.isaac.ros2_bridge",
            "omni.kit.viewport-window",
            "omni.isaac.core",
            "omni.physx",
            "omni.physx.bundle"
Related Issues
Objective
Please check if the examples located at ~/.local/share/ov/pkg/isaac-sim-4.2.0/standalone_examples/api/omni.isaac.ros2_bridge run successfully.
