Using oneShot Example from tegra multimedia api
Iam running the oneShot example from tegra_multimedia_api sources on an imx290 camera sensor on a jetson nano board using l4t R32.2.1 . However when I want to view the resulting jpeg on windows the image is completely green.
Using gstreamer I can correctly stream the cameras video stream to VLC. What am I missing?
Iam using multimedia lib for Jetson Module TX1, though Iam not 100% sure if it could not be also a TX2. How can I find out? cat /etc/nv_tegra_release | head -n1 gives
# R32 (release), REVISION: 2.1, GCID: 16294929, BOARD: t210ref, EABI: aarch64, DATE: Tue Aug 13 04:28:29 UTC 2019
If you need further information please let me know.
Thanks for your help in advance
Kind regards, Steve
Ok, it looks like if I do 10 shots (with 100fps), in the last picture I can see something but it is very greenish, please check the attachment:
Any ideas whats going wrong here?
Thanks, Steve
Ok, I’ve found the problem. The capture request in the oneshot sample is allocated like this:
    Argus::UniqueObj<Argus::Request> request(
        iSession->createRequest(Argus::CAPTURE_INTENT_STILL_CAPTURE));
If I change to this:
        iSession->createRequest(Argus::CAPTURE_INTENT_VIDEO_SNAPSHOT));
I can get proper pictures.
Kind regards, Steve
Glad yo know you resolved the problem, thanks for the update!
