Using opencv and pyaudio with one webcam
I’m trying to make a video streamer inferencing both image and audio at the same time. my web cam is Microsoft® LifeCam Cinema™ and pyaudio shows like this. “Microsoft® LifeCam Cinema™: USB Audio (hw:2,0)”
Microsoft® LifeCam Cinema™ (usb-3610000.xhci-2.1):
/dev/video0
lsusb
Bus 001 Device 004: ID 045e:075d Microsoft Corp. LifeCam Cinema
if opencv shows then I can’t get any of the audio input. How can I use this?
[ WARN:0] global /home/jetson/opencv4.4/opencv-4.4.0/modules/videoio/src/cap_gstreamer.cpp (1761) handleMessage OpenCV | GStreamer warning: Embedded video playback halted; module source reported: Could not read from resource.
[ WARN:0] global /home/jetson/opencv4.4/opencv-4.4.0/modules/videoio/src/cap_gstreamer.cpp (888) open OpenCV | GStreamer warning: unable to start pipeline
[ WARN:0] global /home/jetson/opencv4.4/opencv-4.4.0/modules/videoio/src/cap_gstreamer.cpp (480) isPipelinePlaying OpenCV | GStreamer warning: GStreamer: pipeline have not been created
ALSA lib confmisc.c:1281:(snd_func_refer) Unable to find definition ‘cards.tegra-hda-xnx.pcm.front.0:CARD=0’
ALSA lib conf.c:4528:(_snd_config_evaluate) function snd_func_refer returned error: No such file or directory
ALSA lib conf.c:5007:(snd_config_expand) Evaluate error: No such file or directory
ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM front
ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.rear
ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.center_lfe
ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.side
ALSA lib confmisc.c:1281:(snd_func_refer) Unable to find definition ‘cards.tegra-hda-xnx.pcm.surround51.0:CARD=0’
ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM surround21
ALSA lib confmisc.c:1281:(snd_func_refer) Unable to find definition ‘cards.tegra-hda-xnx.pcm.surround40.0:CARD=0’
ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM surround40
ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM surround41
ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM surround50
ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM surround51
ALSA lib confmisc.c:1281:(snd_func_refer) Unable to find definition ‘cards.tegra-hda-xnx.pcm.surround71.0:CARD=0’
ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM surround71
ALSA lib confmisc.c:1281:(snd_func_refer) Unable to find definition ‘cards.tegra-hda-xnx.pcm.iec958.0:CARD=0,AES0=4,AES1=130,AES2=0,AES3=2’
ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM iec958
ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM spdif
ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.modem
ALSA lib pcm.c:2495:(snd_pcm_open_noupdate) Unknown PCM cards.pcm.phoneline
ALSA lib pcm_dmix.c:990:(snd_pcm_dmix_open) The dmix plugin supports only playback stream
ALSA lib pcm_dmix.c:1052:(snd_pcm_dmix_open) unable to open slave
ALSA lib pcm_params.c:2162:(snd1_pcm_hw_refine_slave) Slave PCM not usable
Expression ‘parameters->channelCount <= maxChans’ failed in ‘src/hostapi/alsa/pa_linux_alsa.c’, line: 1514
Expression ‘ValidateParameters( inputParameters, hostApi, StreamDirection_In )’ failed in ‘src/hostapi/alsa/pa_linux_alsa.c’, line: 2818
File “recorder.py”, line 323, in
demo = Demo(args)
File “recorder.py”, line 118, in init
frames_per_buffer = self.frames_per_buffer)
File “/home/jetson/.local/lib/python3.6/site-packages/pyaudio.py”, line 750, in open
stream = Stream(self, *args, **kwargs)
File “/home/jetson/.local/lib/python3.6/site-packages/pyaudio.py”, line 441, in init
self._stream = pa.open(**arguments)
OSError: [Errno -9998] Invalid number of channels
Hi @doyido2,
Based on the information you have provided, it doesn’t look like tensorrt related issue.
Could you please post your query in the relevant forum.
Thank you.
