Hello there,
I want to use the cv2-module in Python whih the Jetson Nano has preinstalled. I can import it and check the version as well.
The problem is I need it within a virtual environment where the module isn’t found. Since I was not able to find any approporate solution for the problem, I would be very glad if someone could help me out.
I tried following command that I found:
cmake -D WITH_CUDA=ON -D CUDA_ARCH_BIN="5.3" -D CUDA_ARCH_PTX="" -D WITH_GSTREAMER=ON -D WITH_LIBV4L=ON -D BUILD_TESTS=OFF -D BUILD_PERF_TESTS=OFF -D BUILD_EXAMPLES=ON -D CMAKE_BUILD_TYPE=RELEASE -D CMAKE_INSTALL_PREFIX=/usr/local -D INSTALL_PYTHON_EXAMPLES=ON -D INSTALL_C_EXAMPLES=OFF -D OPENCV_EXTRA_MODULES_PATH=/home/nvidia/opencv_contrib-3.4.6/modules -D PYTHON3_EXECUTABLE=/home/nvidia/venv/bin/python PYTHON3_NUMPY_INCLUDE_DIRS=/home/nvidia/venv/lib/python3.6/site-packages/numpy/core/include/ BUILD_opencv_python3=yes -D PYTHON_PACKAGES_PATH=~/home/nvidia/venv/lib/python3.6/site-packages/ -D PYTHON_LIBRARY=/usr/lib/aarch64-linux-gnu/libpython3.6m.so ..
But this did not work and gave this error:
CMake Error: The source directory "/home" does not appear to contain CMakeLists.txt.
Specify --help for usage, or press the help button on the CMake GUI.
Any idea what could go wrong?
Thanks for the answers in advance!
