I’m trying to use the Nano DevKit with PCIe switch. According to other posts, I saw that I need to add the following entry in the PCIe nodes pci@1,0 & pci@2,0
nvidia,disable-clock-request;
(basically, where ever you find ‘nvidia,num-lanes’ entry, add the above one in the same node)
This should remove any dependency of providing REFCLK on CLKREQ signal.
My questions:
- Is this solution valid for all DevKits versions? I currently have A00 but I plan to purchase some new DevKits, for which I think that the revision is A02.
- Can you please point me to the dtsi file(s) which should be updated?
- Is this solution also valid for the production module B01?
Thanks,
Matan
