Using pinned memory on orin platform,caused increase gpu memory usage
When Try to allocate pinned memory on Jetson Orin Platform,I found a huge gpu memory usage increasing ? Why ?
code for allocate about 4GB Memory
import torch
from typing import List
def _allocate_kv_cache(
) -> List[torch.Tensor]:
    """Allocates KV cache on the specified device."""
    kv_cache_shape = (4681, 2, 16, 4, 128)
    pin_memory = True
    kv_cache: List[torch.Tensor] = []
    for _ in range(28):
        # null block in CpuGpuBlockAllocator requires at least that
        # block to be zeroed-out.
        # We zero-out everything for simplicity.
        kv_cache.append(
            torch.zeros(kv_cache_shape,
                        dtype=torch.float16,
                        pin_memory=pin_memory,
                        device="cpu"))
    return kv_cache
_allocate_kv_cache()
Memory Usage After allocating:
And Why ?
Here are some suggestions for the common issues:
1. Performance
Please run the below command before benchmarking deep learning use case:
$ sudo nvpmodel -m 0
$ sudo jetson_clocks
2. Installation
Installation guide of deep learning frameworks on Jetson:
3. Tutorial
Startup deep learning tutorial:
4. Report issue
If these suggestions don’t help and you want to report an issue to us, please attach the model, command/step, and the customized app (if any) with us to reproduce locally.
Could you compare it to the case with pin_memory = False?
Since Jetson is a shared memory system, all the running processes can occupy the memory.
