Dear support team,
I tried to use SRQ (shared receive queue) with RDMA raw ethernet, while initial test shows failed using the linux tool, such as example in https://community.mellanox.com/s/article/raw-ethernet-lat as following, remove --use-srq works as expected.
My question is does my connectX-5 card support SRQ + raw ethernet?
$ raw_ethernet_lat -d mlx5_0 -B xxxx -E yyy --client --use-srq
Min msg size for RawEth is 64B - changing msg size to 64
Send Latency Test
Dual-port : OFF Device : mlx5_0
Number of qps : 1 Transport type : IB
Connection type : RawEth Using SRQ : ON
TX depth : 1
RX depth : 512
Mtu : 1518[B]
Link type : Ethernet
GID index : 0
Max inline data : 236[B]
rdma_cm QPs : OFF
Data ex. method : Ethernet
MAC attached : xxx
error: Invalid argument
Couldn't attach QP
update: I also test enable SRQ at server side, doesn’t have luck.
$ raw_ethernet_lat -d mlx5_0 -B yyy -E xxx --server --use-srq
Send Latency Test
TX depth : 1
RX depth : 512
Mtu : 1518[B]
GID index : 0
rdma_cm QPs : OFF
MAC attached : 98:03:9B:77:DF:9E
Couldn't attach QP
